23rd October 2006, 13:32 | #161 | Link |
Retired, but still around
"ColorMatrix:invalid mode string!" for resmovie ColorMatrix("Rec.S170->Rec.601",hints=false)
How to Optimize Bitrate for CCE multipass |
23rd October 2006, 15:54 | #162 | Link |
HDConvertToX author
www.64k.it/andres/data/a/AutoMKV45.exe removed case of colormatrix that I HAVEN'T TESTED BECAUSE I HAVEN'T THE CORRECT SOURCE MATERIAL ! BHH P.S. sorry for this post but.... can you please chop a piece of mpeg and send me a link ?
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
23rd October 2006, 19:29 | #163 | Link |
Take a breath Sent.
23rd October 2006, 20:08 | #164 | Link |
Actually in reserve
Hi BHH,
Great work, you are updating quicker than I can test Don't get a coding overdose. Cheers. Did
Having a problem with AutoGK? Read & use the FAQ & MORE FAQ first Want to exchange on AutoGK? try doom10.org In reserve (inactive) for an undefined period of time. |
23rd October 2006, 20:35 | #165 | Link |
Life's clearer in 4K UHD
By-the-way....
Cheers
23rd October 2006, 21:01 | #166 | Link |
Glad you mentioned that. I've never even understood what it does, or is there for
Buzzqw, can you put fullbatch in the working dir when PPO is not checked? This would be helpful for debugging or crash.
How to Optimize Bitrate for CCE multipass Last edited by DDogg; 24th October 2006 at 04:11. |
24th October 2006, 16:42 | #168 | Link | ||||
HDConvertToX author
BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 Last edited by buzzqw; 24th October 2006 at 16:48. |
24th October 2006, 17:15 | #169 | Link | |
24th October 2006, 17:34 | #170 | Link | |
HDConvertToX author
BHH
24th October 2006, 17:45 | #171 | Link |
I just wanted to say thanks a lot, buzzqw (and the rest of you that have been helping out on this thread). This application is fantastic and just what I've been looking for!
A couple of things... I did read a few pages back that you're aware that having the UI completely vanish when you start a batch encode with the Queue is not ideal, but this hasn't changed. Is this still coming or did it drop off the radar? (It baffled me until I dug through this thread to find it mentioned.) Also, this is quite a bit less important, but it'd be nice. Is there any way that if you call AutoMKV with a file path as a command line argument that you could have it load up with that file pre-loaded as the Input file? This would be pretty cool for using Right Click --> Send to directly on the media files themselves in Windows Explorer (or from inside other media management applications). |
24th October 2006, 19:04 | #172 | Link |
I've actually now found a problem with encoding a certain video file using AutoMKV. When it gets to the DelayCut stage, the fixed1.mpa file it creates just keeps growing and growing until it uses up all of my available hard drive space. I had it grow to 170 GB for a one hour video clip one time and the second time it got to almost 70 GB before I stopped it. The process never ends...
The video I was test encoding was recorded by my HTPC by BeyondTV: Here is the DelayCut line from the AutoMKV log: Code:
12:27:38 DelayCut CMD: C:\Program Files\AutoMKV\exe\dgindex\Delaycut.exe -auto -out "C:\video\projects\fixed1.mpa" "C:\video\projects\movie T01 DELAY 102ms.mpa" Code:
[Input info] Bitrate=384 Actual rate=384.000000 Sampling Frec=48000 TotalFrames=169388 Bytesperframe=1152.0000 Filesize=195134976 FrameDuration= 24.0000 Framespersecond= 41.6667 Duration=01:07:45.312 Channels mode=Stereo LFE=LFE: Not present [Target info] StartFrame=-4 EndFrame=169387 NotFixedDelay= 6.0000 Duration=01:07:45.408 ====== PROCESSING LOG ====================== Time 00:44:48.312; Frame#= 112014. Unsynchronized frame...REWINDED 1148 bytes. Found new synch word Time 00:44:48.360; Frame#= 112016. Unsynchronized frame...REWINDED 1148 bytes. Found new synch word The video plays fine in MPC and doesn't seem to be out-of-sync. Other videos I've recorded with BeyondTV did encode fine with AutoMKV and MeGUI (though I don't know that I've tried this actual video file in MeGUI). Last edited by glynor; 24th October 2006 at 19:09. |
24th October 2006, 19:15 | #173 | Link |
glynor, nice to see another tester! I'm wondering if the same problem would show if you were to load that file in VdubMod, use directstream copy and create a new file to test with AutoMK? Or, file>open>check extended options and rekey the file? Just curious - and it might help buzzqw identify the problem if that fixes it.
/add: sorry, I just saw that was a mpeg file. He may need a snip link pm'ed to him.
How to Optimize Bitrate for CCE multipass Last edited by DDogg; 24th October 2006 at 19:23. |
24th October 2006, 19:35 | #174 | Link | |||
HDConvertToX author
can you cut a small part around the culprit , from 00:44:48.312 to 00:45:00:00 and post me a link where to download ? i hope to replicate the problem... and point jsoto to the problem TRY using this CUSTOM build www.64k.it/andres/data/a/AutoMKV46CRC.exe i added to delaycut command line the order to fix with silence CRC errors please report back! BHH
24th October 2006, 20:40 | #175 | Link |
1> was doing a manual crop [enable manual crop and resize]. The script redlined. Found I had to change crop line to: crop(movie,8,2,-6,-4) from crop(8,2,-6,-4)
2> having trouble loading an avs as source. It is sized as 640x352 and encodes with no problem in x263cli, however, if I try to play resmovie.avs which has imported this script I get the complaint about width must be divisible by 4. Code:
movie = Import("C:\640.avs") function Comptest(clip c, float percent) { frange=floor(14./(percent/100.)) Return SelectRangeEvery(c, frange, 14) } Comptest(2) Code:
DGDecode_mpeg2source("C:\VTS_01_1.d2v",info=3) ColorMatrix(hints=true) #blank deinterlace line crop(8, 4, -6, -4) LanczosResize(640,352) # Lanczos (Sharp) Code:
movie = Import("C:\SPR\spr640.avs") function Comptest(clip c, float percent) { frange=floor(14./(percent/100.)) Return SelectRangeEvery(c, frange, 14) } Comptest(2) return movie
How to Optimize Bitrate for CCE multipass Last edited by DDogg; 24th October 2006 at 21:36. |
24th October 2006, 21:40 | #176 | Link | |
Thanks for the change on the command line argument too! |
24th October 2006, 21:57 | #177 | Link |
As Decreed by Lord Julius
One more idea...
I noticed yesterday that I encoded a movie (after changing the movie name to something OTHER than 'movie') and the result was...nothing. I'm wondering if changing the default movie name in the UI isn't totally bug-free, and that there may be some case where the encoded video isn't seen because it has the wrong filename, or something like that. Has anyone else had problems with using something other than 'movie' in the name field?
25th October 2006, 08:15 | #178 | Link | |||
HDConvertToX author
Better: when using avs as source the width value "automatic" or any other value IS IGNORED in final encoding. Even if autoresize suggest, for example 640, the final movie.avs will be only "import ("ooo.avs") , without any resize applyed Anyway fixed avs import file Quote:
BHH
25th October 2006, 09:33 | #179 | Link |
I've found a small bug in v0.45 and v0.46-CRC.
Change the X264 profile to HQ-Slower and then click the drop down on the container, it will change the profile back to CE-mainprofile. if you try a similar thing with XVID, the Codec will change to X264 and the profile will change to CE-mainprofile. |
25th October 2006, 14:13 | #180 | Link |
HDConvertToX author
update 0.47 www.64k.it/andres/data/a/AutoMKV047.exe
ADDED: shutdown at end of encoding ADDED: is possible to specify input file on command line ADDED: fixcrc silence on mpa audio file (could be a temporary fix) ADDED: drag&drop on input string FIXED: In log window is present an horizontal bar, is also possible to write notes FIXED: Check DVD Drive FIXED: avs input file. NO filter and NO resize is applyed on this files @AMED isn't bug. On change of container i reset the codec/profiles status
