28th November 2006, 17:20 | #321 | Link |
Ah i c, thanks =) well what settings would you guys sugest for a 1.2 gb dvd rip of a movie? Should i deinterlace? What filter you guys think is the best? Is there anything else you would adjust? Thanks in advance
One more little sugestion i have, couls you include start and end time (computer time) and time taken to complete the job in the logfile? |
29th November 2006, 08:16 | #322 | Link | ||
HDConvertToX author
deinterlace: leave auto, if needed deinterlacer will be placed in, if not needed no worry filter: for a rip to x264 to 1.2gb... just a small filtering, leave the default removegrain(mode=2) resolution: leave auto, is probably always the "better" choice, let automkv do it's calculations and let it determine the width (again will be near full resolution..) BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
29th November 2006, 20:20 | #323 | Link |
OK ... i have problems encoding ts files with commercials in it ... sometimes the Channels are switched from AC3/3/2 to AC3 /2/0 i think ... Projectx is decoding the file right but i think beepipe is not working correctly here.
Converting the *.ac3 file to WAV 3/2 and then encode it with Nero AAC works correctly. Sample : http://member.file-upload.net/FoGBaV/film.rar This is the Batch i used in my Scripts to get the AC3 work correctly : @echo off For %%D In (.) Do Set localpath="%%~fD\tmp\final\film.ac3" start /low /wait /min .\exe\besweet\besweet -core( -input "tmp\film.ac3" -output "tmp\film_ac3.wav" -6chwav -logfile) -azid( -g max ) start /low /wait /min .\exe\besweet\neroaacenc.EXE -br 192000 -2pass -if tmp\film_ac3.wav -of tmp\final\film.ac3.mp4 del /Q tmp\film_ac3.wav I Don't know if this is ok to d oso ... but it worked in the past ...8) |
29th November 2006, 22:00 | #324 | Link |
HDConvertToX author
thanks for the link
i will try to "study" something BHH
29th November 2006, 23:23 | #325 | Link | |
Tahnks again for the feedback. Did a few more tests and another problem occured: I used all the standard settings to convert a dvd to mkv, 2 language tracks, two subtitle tracks, 1 movie track. Everything was done properly, except at the end i had no mkv file, but audio and video was encoded and is playable. I included a screenshot of all the files generated by automkv. Now the interesting thing is, that if I try encoding the dvd that automkv ripped before, and only select one audio track, then i do get an mkv file in the end. What the problem is i cant really tell though. Also I realized that the quality is a lot worse if i let automkv do everything by itself. Gona do some further testing on the quality part, but do you have any idea why i dont get an mkv file?
Heres the log: Quote:
30th November 2006, 00:50 | #326 | Link |
Retired, but still around
Buzzqw, do you have access to any dvr-ms files as created by Windows Media Center 2005?
AutoMKV is very close to being able to handle these files if the user first wraps them in a directshowsource script, but sometimes I get audio sync problems. These files are new to me, so I do not yet know the details. I could put one up for you like the other files if you are interested. Let me know.
How to Optimize Bitrate for CCE multipass |
30th November 2006, 06:14 | #327 | Link | |
Cheers, |
30th November 2006, 08:24 | #328 | Link |
HDConvertToX author
@crashed
D:\automkv\AutoMKV051\exe\matroska\mkvmerge.exe -o "D:\movie.mkv" --aspect-ratio 1:1.777778 --chapters "D:\automkv\AutoMKV051\exe\chapters.txt" "D:\movie.mp4" --language 1:eng "D:\audio.mp4" --language 1:deu "D:\audio2.mp4" "D:\movie.idx" with this command line i succesfully muxed (with mkvmerge update to 1.8.1) Try this: 1) from dos propmpt launch the same command line and spot the error 2) if fails try upgrading mkvtoolnx within \exe\matroska folder about dvr-ms i have to search around for this files, if someone could post a link... thanks BHH
30th November 2006, 16:26 | #330 | Link |
HDConvertToX author
please post para.lst and dvdinfo.txt (into automkv.exe folder)
BHH
30th November 2006, 18:50 | #331 | Link | ||
dvdinfo.txt i can find in the automkv.exe folder:
30th November 2006, 19:29 | #332 | Link | |
HDConvertToX author
(the files are in correct folders)
rip all sub failed due to angles i suppose... in that case is better to select both subtitles by using both SubTracks 1 & 2 Is for this reason that i added pgc selection... but rip all subs is a "backdoor" for select more subs than 2 ... i must check it... BHH
30th November 2006, 20:07 | #333 | Link |
Life's clearer in 4K UHD
Hi Buzz,
The AutoMKV link in your sig always seems to point to the last point you make in this thread.... Is it supposed to do this?
30th November 2006, 22:50 | #337 | Link |
Thanks Buzz
1st December 2006, 01:33 | #338 | Link | |
directshowsource("D:\temp\test.dvr-ms",fps=29.970,convertfps = true)
How to Optimize Bitrate for CCE multipass Last edited by DDogg; 1st December 2006 at 03:14. |
1st December 2006, 10:29 | #339 | Link |
HDConvertToX author
update NEW FULL PACKAGE
www.64k.it/andres/data/a/AutoMKV052.rar FIXED: non idle process xvid_encrow in second pass FIXED: "final muxed size" for avi container desn't appear FIXED: occasional crash on xvid 2 pass mode FIXED: XviD CQ mode encoding, changed bframe bias FIXED: rare combination that will lead to bad movie.avs when NO RESIZE, NO DEINT, NO FILTERS and NO COLORMATRIX is applyed FIXED: Subripping with angles (? beta) ADDED: AutoMKV now do its works creating a "temp" directory in destination folder. In this folder are created all temporay files, the muxed final ones will be in normal destination folder, with the log ADDED: "All Audio Tracks" for ifo input ADDED: ProjectX support for TS files, check in advanced settings ADDED: slighty changed the command line parameters (try from dos automkv.exe /? ), the first audio parameters can be now, or number of audio tracks or "all" (without quotes "") for encoding all audio tracks ADDED: support for dvr-ms (? beta) ADDED: total encoding time in log file UPDATE: Oggenc 2.8.3, CCT AAC, Matroska 1.8.1, TDeint, TIVTC happy encoding BHH
1st December 2006, 13:12 | #340 | Link |
aka XaS
Ehm, I must be doing something wrong with AutoMKV but I'll ask anyway :
- I choose my source (avi file) - I set my audio track to vorbis (q0) - I set resolution width to 528 - I set disk settings to 60 (I want a ~60MB file) - I choose the CQ-ASP_Q2_eq(crf) profile I'm asked to hit target filesize or not: I choose "Hit target filesize" ('cause I want to try this new CRF technique from the thread DDog started). - I set container to MKV and codec to X264. Then I click start, and several x264 windows open and close faster than buzz lightyear, and this goes on for ever... (I need to kill AutoMKV in the taskmanager). Result: no real encoding happens. The log seems to indicate that the source file wasn't opened correctly (movie length = 0). If a file potentially has a problem, it would be great if you could "check" for those eventualities and pop an error message somewhere instead of having x264 going on and on for ever Here's the log : Code:
12:42:28 0.52 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - - 12:42:28 Selected Input file: D:\_etienne\vidz\HackRoots22.avi 12:42:28 Selected Output dir: D:\_etienne\vidz\temp\ 12:42:28 Selected Container type: MKV 12:42:28 Selected Size: 60 12:42:28 Selected Slice: 1 12:42:28 Selected Encoder: X264 12:42:28 Selected Profile: CQ-ASP_Q2_eq(crf).xml 12:42:28 Selected Width: 528 12:42:28 Selected Resizer: SimpleResize (neutral soft) 12:42:28 Selected Filters: RemoveGrain(mode=2) 12:42:28 Selected Deinterlacer: AUTO 12:42:28 NeroAACEnc.exe not present 12:42:28 Enabled CRF/CQ autoresize with value 18 12:42:28 Track Language 1: HackRoots22.avi 12:42:28 Audio Codec 1: Ogg Vorbis 12:42:28 Audio Quality 1: 0 12:42:28 Selected Hit Media Size 12:42:30 Number of Frames: 12:42:30 Framerate: 12:42:30 Movie lenght in Seconds: 0 12:42:30 Movie Width: 12:42:30 Movie Height: 12:42:30 Avi engage mode not corrected, switched to AviSource 12:42:32 Number of Frames: 12:42:32 Framerate: 12:42:32 Movie lenght in Seconds: 0 12:42:32 Movie Width: 12:42:32 Movie Height: 12:42:32 Avi engage mode not corrected, switched to AviSource 12:42:34 Number of Frames: 12:42:34 Framerate: 12:42:34 Movie lenght in Seconds: 0 12:42:34 Movie Width: 12:42:34 Movie Height: 12:42:34 Avi engage mode not corrected, switched to AviSource 12:42:35 Number of Frames: 12:42:35 Framerate: 12:42:35 Movie lenght in Seconds: 0 12:42:35 Movie Width: 12:42:35 Movie Height: 12:42:35 Avi engage mode not corrected, switched to AviSource 12:42:37 Number of Frames: 12:42:37 Framerate: 12:42:37 Movie lenght in Seconds: 0 12:42:37 Movie Width: 12:42:37 Movie Height: 12:42:37 Avi engage mode not corrected, switched to AviSource 12:42:38 Number of Frames: 12:42:38 Framerate: 12:42:38 Movie lenght in Seconds: 0 12:42:38 Movie Width: 12:42:38 Movie Height: 12:42:38 Avi engage mode not corrected, switched to AviSource 12:42:40 Number of Frames: 12:42:40 Framerate: 12:42:40 Movie lenght in Seconds: 0 12:42:40 Movie Width: 12:42:40 Movie Height: 12:42:40 Avi engage mode not corrected, switched to AviSource In the temp directory, time.avs doesn't include the fps="" parameter to directshowsource(), and this gives me a "couldn't determine source framerate" error in avisynth (this is why the problem I stated above happens). I'll try to get my hands on something else to encode and see what it gives
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS Last edited by DarkZell666; 1st December 2006 at 13:15. Reason: edit: the preview stuff wasn't from AutoMKV, sorry :/ |
