#1 | Link |
Help!!!!
Get Release Candidate 4. No new stuff will be added, only bugfixes. This is the full bundle. This gotta be the last RC.
The subject should attract a moderator or two ![]() ![]()
Cheers, dvd2svcd Last edited by dvd2svcd; 3rd November 2002 at 13:50. |
#2 | Link |
Thanks
Great "subject". I'm no moderator, but I think you should be striked for making me laugh so hard my stomach hurts.
![]() On you mark, get set, test...And they're off. |
#3 | Link |
Ingenium Diabolicus
Hello DVD2SVCD
![]() I'm testing your beta release with 3 dvd's so far (only one chpater). Everything works fine with default settings and normal VBR mode (with subtitles, of course, you know me ![]() I've tested also the new RoBa mode but it's not working perfectly. In these 3 DVD's i tested, only onde was successfully converted. CCE comes up with this error message: cce_encoding_init() failed Here is part of my log file (they are big now ![]() Trying to load the DVD Trying to load the DVD No need to authenticate (was already) - OK. Key found: E713B7964B -------------------------------------------------------- - 13-10-2002 17:05:19 - DVD to SVCD Conversion - DVD2SVCD ver. 1.1.0 build 1 BETA 3 -------------------------------------------------------- Initializing Initializing finished. -------------------------------------------------------- - 13-10-2002 17:05:21 - Analyzing subtitles -------------------------------------------------------- Subtitle found: StreamID: 0x24 Language: English Subtitle found: StreamID: 0x25 Language: Italiano Subtitle found: StreamID: 0x26 Language: Espaņol Subtitle found: StreamID: 0x21 Language: Italiano Subtitle found: StreamID: 0x22 Language: Espaņol Subtitle found: StreamID: 0x23 Language: Portugues Subtitle found: StreamID: 0x20 Language: English Executing subtitle selection/verification. Subtitle selection/verification accepted. 1 subtitle streams selected. Saving Subtitles ini file -------------------------------------------------------- - 13-10-2002 17:06:43 - Free on drive C: 19828.95 mb - Internal rip -------------------------------------------------------- Preparing vobfiles to be ripped: - D:\VIDEO_TS\VTS_01_1.vob - D:\VIDEO_TS\VTS_01_2.vob - D:\VIDEO_TS\VTS_01_3.vob - D:\VIDEO_TS\VTS_01_4.vob - D:\VIDEO_TS\VTS_01_5.vob - D:\VIDEO_TS\VTS_01_6.vob - D:\VIDEO_TS\VTS_01_7.vob Ripping: D:\VIDEO_TS\VTS_01_1.vob Ripping finished. Speed: 4330 -------------------------------------------------------- - 13-10-2002 17:07:35 - DVD2AVI -------------------------------------------------------- Creating DVD2AVI INI file: - C:\DVD2SVCD110Beta3\DVD2AVI\DVD2AVI.INI Variable settings: iDCT_Algorithm: 32-bit SSE MMX Executing DVD2AVI. Executing DVD2AVI. Commandline: "C:\DVD2SVCD110Beta3\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[C:\DVD2SVCD110Beta3\Movie\DVD2AVI_Project_file] -IF=[C:\DVD2SVCD110Beta3\Movie\VTS_01_1.vob] Framerate: 25000 DVD2AVI processing done. -------------------------------------------------------- - 13-10-2002 17:07:47 - Free on drive C: 19613.23 mb - Extracting the subtitles. -------------------------------------------------------- Subtitle extraction finished. Extracted these subtitles: SVCD Stream no: 1 Language: Portugues Num. of subs: 44 Saving Subtitle Timecodes. Permanent subtitles. Saving Subtitles ini file -------------------------------------------------------- - 13-10-2002 17:08:08 - Free on drive C: 19611.51 mb - AUDIO Extraction -------------------------------------------------------- Found AC3 stream id: 0x80 Filename: C:\DVD2SVCD110Beta3\Movie\Extracted_audio_1.ac3 Audio1 delay: -280 ms Audio extraction finished. -------------------------------------------------------- - 13-10-2002 17:08:23 - Free on drive C: 19599.27 mb - AUDIO conversion -------------------------------------------------------- Encoding Audio. Filename: C:\DVD2SVCD110Beta3\Movie\Extracted_audio_1.ac3 Executing BeSweet. Commandline: "C:\DVD2SVCD110Beta3\BeSweet\BeSweet.exe" -core( -input "C:\DVD2SVCD110Beta3\Movie\Extracted_audio_1.ac3" -output "C:\DVD2SV~1\Movie\Encoded_audio_1.mp2" -logfile "C:\DVD2SV~1\Movie\Encoded_audio_1.log" ) -azid( -L -3db -c normal -s surround -g max ) -ota( -d -280 ) -2lame( -e -b 224 -m s ) Audio conversion of C:\DVD2SVCD110Beta3\Movie\Extracted_audio_1.ac3 finished. Audio conversion finished. -------------------------------------------------------- - 13-10-2002 17:09:15 - Free on drive C: 19592.13 mb - Converting Pictures -------------------------------------------------------- Converting: C:\DVD2SVCD110Beta3\DefaultChangeCD.bmp Finished converting pictures -------------------------------------------------------- - 13-10-2002 17:09:21 - Free on drive C: 19591.34 mb - Video Encoding using Cinema Craft -------------------------------------------------------- Executing Cinema Craft Encoder. StreamSectors: 833937188 AudioSectors: 7727300 VideoPAPO: 12798432 ScanOffsetBytes: 8018 SeqAligningBytes: 509614 DVDBytes: 0 VideoEndHeader: 4 SubtitleSectors: 0 EmptySectors: 238.00 PictureSectors: 0.00 PureMPEGStream: 812893819.73 Seconds: 272.28 CalcMPEGStream: 812893819.73 Frames: 6682 CDSize: 800.00 Number of CDs: 1 Cut point 795.00 Variable Settings: Frames: 6682 Anti Noise Filter: Off Passes: 2 Image Quality: 10 VAF file creation: On Video Encoding Mode: RoBa Multipass VBR (a mix between 1-pass and multipass encoding) Min. bitrate: 300 Max. bitrate: 2530 Q. Factor: 5 Avg. Bitrate: 2230 Aspect Ratio: 16:9 (borders added, encoded as 4:3) ---AVS Begin--- LoadPlugin("C:\DVD2SV~1\MPEG2Dec\mpeg2dec.dll") LoadPlugin("C:\DVD2SV~1\AVISYN~1.DLL") mpeg2source("C:\DVD2SV~1\Movie\DVD2AV~1.D2V") BicubicResize(480,432,0.0,0.6) AddBorders(0,72,0,72) AvisynthSubtitler("C:\DVD2SV~1\Movie\subs\","permsubs.txt") ResampleAudio(44100) ----AVS End---- Closing program CCE Max Speed: 0.680 Video Encoding finished. Executing Cinema Craft Encoder. StreamSectors: 833937188 AudioSectors: 7727300 VideoPAPO: 12798432 ScanOffsetBytes: 8018 SeqAligningBytes: 509614 DVDBytes: 0 VideoEndHeader: 4 SubtitleSectors: 0 EmptySectors: 238.00 PictureSectors: 0.00 PureMPEGStream: 812893819.73 Seconds: 272.28 CalcMPEGStream: 812893819.73 Frames: 6682 CDSize: 800.00 Number of CDs: 1 Cut point 795.00 StreamSectors: 1666479976 AudioSectors: 7785400 VideoPAPO: 25694064 ScanOffsetBytes: 8018 SeqAligningBytes: 509614 DVDBytes: 0 VideoEndHeader: 8 SubtitleSectors: 0 EmptySectors: 238.00 PictureSectors: 300.00 PureMPEGStream: 1632482871.73 Seconds: 274.28 CalcMPEGStream: 1632482871.73 Frames: 6682 CDSize: 800.00 Number of CDs: 2 Cut point 795.00 StreamSectors: 2497628364 AudioSectors: 7841176 VideoPAPO: 38568132 ScanOffsetBytes: 8018 SeqAligningBytes: 509614 DVDBytes: 0 VideoEndHeader: 12 SubtitleSectors: 0 EmptySectors: 238.00 PictureSectors: 600.00 PureMPEGStream: 2450701411.73 Seconds: 276.28 CalcMPEGStream: 2450701411.73 Frames: 6682 CDSize: 800.00 Number of CDs: 3 Cut point 795.00 StreamSectors: 3327382352 AudioSectors: 7899276 VideoPAPO: 51420564 ScanOffsetBytes: 8018 SeqAligningBytes: 509614 DVDBytes: 0 VideoEndHeader: 16 SubtitleSectors: 0 EmptySectors: 238.00 PictureSectors: 900.00 PureMPEGStream: 3267544863.73 Seconds: 278.28 CalcMPEGStream: 3267544863.73 Frames: 6682 CDSize: 800.00 Number of CDs: 1197 Cut point 795.00 StreamSectors: -732231976 AudioSectors: 75667116 VideoPAPO: -12514788 ScanOffsetBytes: 8018 SeqAligningBytes: 509614 DVDBytes: 0 VideoEndHeader: 4792 SubtitleSectors: 0 EmptySectors: 238.00 PictureSectors: 359100.00 PureMPEGStream: -795906728.27 Seconds: 2666.28 CalcMPEGStream: -795906728.27 Frames: 6682 CDSize: 800.00 Number of CDs: 1198 Cut point 795.00 Variable Settings: Frames: 6682 Anti Noise Filter: Off Passes: 2 Image Quality: 10 VAF file creation: On Video Encoding Mode: RoBa Multipass VBR (a mix between 1-pass and multipass encoding) Min. bitrate: 300 Max. bitrate: 2530 Q. Factor: 5 Avg. Bitrate: -2389 Aspect Ratio: 16:9 (borders added, encoded as 4:3) ---AVS Begin--- LoadPlugin("C:\DVD2SV~1\MPEG2Dec\mpeg2dec.dll") LoadPlugin("C:\DVD2SV~1\AVISYN~1.DLL") mpeg2source("C:\DVD2SV~1\Movie\DVD2AV~1.D2V") BicubicResize(480,432,0.0,0.6) AddBorders(0,72,0,72) AvisynthSubtitler("C:\DVD2SV~1\Movie\subs\","permsubs.txt") ResampleAudio(44100) ----AVS End---- Please note the negative value in the Avg. Bitrate. Maybe this is the problem. I have attached the complete log. Hope i can continue helping you in the developing of this great program. You're the man ![]() Titvs (aka tito ![]() |
#4 | Link |
Yes, the RoBa method is quite unstable. All I can suggest is try using CCE 2.62 safemode, I believe Bach has had the most success with this. All in all I'd stick with the 4 pass VBR.
Edit: Yes, it is definatly not good with a negative Bitrate. Maybe I should disable RoBa and do some testing on it. (btw, roba is actually not meant for chapters, but complete dvd's, otherwise I fear as in your case that it will fail)
Cheers, dvd2svcd Last edited by dvd2svcd; 13th October 2002 at 18:35. |
#6 | Link |
Ingenium Diabolicus
Ok, i'll try to full encode one of those problematic DVD's and see if it goes succesfully.
Other thing, did you take a look at that Taxi 2 data regarding another subs issue? Well, i have a workaround for those weird DVD's: use of textsub.vdf and a SSA file ![]() ![]() Best regards, Titvs |
#8 | Link |
i just downloaded the new beta
![]() Edit: ok its 8:34 pm here i'm starting the first movie with the beta the movie i'm doing first off is called "Frailty" btw its a very good movie, a bit strange which in my eyes is always nice ![]()
http://biw.rult.at or #biw on efnet Last edited by chainsaw135; 14th October 2002 at 02:37. |
#10 | Link |
I really like the 'use frame selection'. Its perfect for the conversion of DVB-Streams.
Thanks. edit: Very handy feature... but: (I know, free pie...) ![]() Only a suggestion: Is it posible to expand the 'rip only' to 'rip & frame selection only'? If I do batch encoding I can't select the frames before starting the batch, so I have to do it after evry movie seperatly and my batch won't finish alone. Last edited by Labersack; 14th October 2002 at 09:15. |
#11 | Link | ||
Cheers, dvd2svcd Last edited by dvd2svcd; 14th October 2002 at 12:17. |
#12 | Link |
Old fart
I had to pipe in on Donnie Darko. Strange, but great movie. Real life brother and sister, play the brother and sister.
A quick neat note on that movie. The actor was on a talk show when he told the following story about his friends. Warning: Don't read on if you wish to see this movie spoiler in post. He said that at a premiere his friends where suppose to meet him afterwards. At the end of the movie after the main character dies one friend bent over to the other and in all seriousness said "I don't think he will be able to meet us now." His bud thought he really died. True story. Dumb friend. Great movie. Slow and plodding, but with so many layers of meaning. Was produced by Drew Barrymore. Mark
Oh no Mr. Bill! Last edited by markrb; 14th October 2002 at 14:35. |
#13 | Link |
Just finish my first movie with the new version.
Great. No problems at all. I didn't use anything special, just the unfilter. Changed only the filesize, and the max and min bitrates. It's really great to have the option to see where to cut it. Love it. I encoded this movie 2 times before, with the previous ver. And each time, ended up with a very big file. (never happened before). Bbmpeg would mux the first part, then I'd get an error. Something about floating point. Couldn't do it manually because the file was way too big. Both times. Second time it was a little smaller, but got the same error. Anyway, with this version I finally have it done. I'll do some more testing in the time to come. Great program, great features, great work. Thank you.
Welcome....to the real world. |
#14 | Link | |
![]() On another note, i did frailty last night it worked without a problem and so i dont have much to report on that note looking forward to the new release ![]()
http://biw.rult.at or #biw on efnet |
#15 | Link | |
lost in space
#16 | Link |
just dl b2 at work...then see this b3 post.
As we know from experience most newbies won't be changing default settings let alone advanced. Does anyone agree to these default settings? I admit there's little difference in changing these settings so perhaps it's a moot point and to no avail. Is there anywhere on earth people can still purchase 74min (740MB) cds? I haven't seen any at stores/online for about a year now. Default all to 800 perhaps. Then again leave it the way it is otherwise newbies wouldn't know the versatility. I personally do 1cd,2,3,4,5,6cd in the bitrate settings. If it ain't broke don't fix it? VCD-Settings.ini and SVCD-Settings.ini How about DVD-Settings.ini could Fletch perhaps come up with a nice template of settings to be included perhaps? Perhaps next release then. cce advanced settings default should be Intra DC decision should be 8 or AUTO. since SVCD are 2.6Mbps or less. "Specify the bit precision of the DC coefficient of the intra-block in Intra DC precision in the video settings screen. One of 8, 9 and 10 bits can be set here. In general the optimum settings cannot be determined since changes depend on the details of the picture and movement intensity. For pictures with intensive movement and fine bumps, a low number of bits is appropriate. For smooth pictures with little movement, a higher number of bits is appropriate. A low number of bits may be specified for use at a [blow bitrate up to 4Mbps[/b], and a high number of bits may be specified for use at a high bitrate. When Auto is selected, the precision varies according to quantization scale.For details, refer to the guides on MPEG-2. " Linear quantizer scale default should be unchecked "Setting quantization scale type There are two types of quantization scales: linear and non-linear. Linear quantization scale is a method used for MPEG-1, where the quantization scale is allocated linearly. To set the linear quantization scale, select Linear quantization scale in the video settings screen. However, the nonlinear quantization scale is recommended unless there is a special reason." default audio bitrate 128 bump to either 192 or 224 Will be experimenting a bunch with it in a couple of hours when I get home. Last edited by mrbass; 15th October 2002 at 03:35. |
#17 | Link |
I have enjoyed very much your new beta version of d2s. However I have two comments about subtitles.
When you select several subtitles, the end time code of the last bitmap for at least one the sub files is wrong. For instance, the last lines of two sub files for an encoded chapter using the last d2s beta are: en200088.bmp 00:12:25,43 00:12:26,34 136 40 284 488 es100088.bmp 00:12:25,43 01:59:59,89 104 40 300 488 In the current version the subtitles with start time code smaller than four seconds are trimmed and do not appear in the sub file because some standalone players cannot display them. Looking ahead, it would be convenient to include them in the sub file since they do not make any harm when using Winsubmux as subtitle muxer and in some moment might appear a program that shows subtitles on computers. Needle |
#19 | Link | |||||
![]() Quote:
Cheers, dvd2svcd |
#20 | Link | |||
oh yea...-shutdown and -exit work perfect now for rip only...also the dvd authentication problems seem to have vanished. Last edited by mrbass; 15th October 2002 at 10:15. |
