16th January 2006, 23:24 | #1282 | Link | |
clueless n00b
17th January 2006, 03:38 | #1286 | Link |
Yes, it just requests the frame and ignores it. Just as you said, for functions that write to files. This also includes 2pass scripts (eg DeDup and hybrid TIVTC). Perhaps 2pass AviSynth support should be added (it would allow for a better mode of IVTC'ing).
You might need to update your patch, but I'm not sure... actually, from your changelog, that doesn't seem to be the case. I would integrate your patch into CVS, but I don't have access to it (pending approval of a mod). If you use the SourceForge patch tracker (http://sourceforge.net/tracker/?grou...2&atid=798478), then it's easier for me to access and integrate, because I don't have to wait for a mod's approval. OTOH, you need a SF account to post patches there. |
17th January 2006, 04:12 | #1287 | Link |
developer wannabe
Forgot about mod approval -- I shouldn't use forum attachments, that's me being lazy. It's on SF now. Here's a link to the post with the changelist.
17th January 2006, 05:19 | #1290 | Link |
New CVS Update (it's a big one)
0.2.3.2031 17 Jan 2006 Added Richard Berg's contextmenu changes patch: Feature changes: - queueContextMenu - added Delete button - fixed logic so buttons are disabled when no items selected - changed order so most common items are toward the top - added hotkeys - audioOutput & videoOutput textboxes are now editable - drag-n-drop is now disabled unless the Input tab is selected - error messages related to audio & video job setup are now more helpful/detailed Refactoring changes: - new enum CodecType (works just like FileType) - rewrote verifyVideoSettings & assorted helper methods, called it whenever queueing a video job - ditto verifyAudioSettings Other changes: -added a contextmenustrip for the tray icon -minimize to tray hides the progress window -closing MeGUI while a job is running now calls abort instead of aborting manually -fixed menus for megui-x264 -fixed loading of avs and hfyu jobs -moved start/stop pause/play changes to a separate function |
17th January 2006, 09:25 | #1291 | Link |
clueless n00b
I think we should set up someting like this: automatic daily CVS exports that are zipped along with a compile-x264.bat and compile-full.bat which compile the x264 and full release respectively, then publish this somewhere. That way we don't have to worry about making releases, and even the most clueless people can compile their own builds (that's what the compile files are for.. if you have the runtime, you can compile). That way, there are no more cumbersome releases for us to do and people can always use the latest code.
17th January 2006, 12:05 | #1293 | Link | |
BeHappy/MeGUI developer
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
17th January 2006, 12:14 | #1294 | Link | |||
Job provide some facility to create encoder Code:
interface IJobHandlerFacility { IJobHandler CreateJobHandlerFor(IJob job) } interface IJob { IJobHandlerFacility HandlerFacility{get;} } ... job.HandlerFacility.CreateJobHandlerFor(job) ... or You can wrap this call into job too: abstract class Job:IJob { public IJobHandler CreateJobHandler() { (this as IJob).HandlerFacility.CreateJobHandlerFor(this) } } Quote:
17th January 2006, 12:19 | #1295 | Link | ||
clueless n00b
17th January 2006, 12:25 | #1296 | Link | |
17th January 2006, 13:15 | #1299 | Link | ||
clueless n00b
And in the end when you create a patch it's up to somebody with CVS access to integrate it..
17th January 2006, 13:20 | #1300 | Link | ||
Ok, You can provide me fresh sources. Then I will add my functionality and sent it back to You. And merging with CVS woud be You problem. Does You agree?
development, megui, not a help thread |
