10th July 2016, 23:14 | #41 | Link |
Good, i'm happy that was something easy to fix! The info was in the readme on github but i forgot to add it on the first page.
Latest dev builds of AssFilterMod can be found here: https://www.mediafire.com/folder/w1w...s/AssFilterMod |
13th July 2016, 06:55 | #42 | Link |
I set the font to be franklin Gothic size 40. It still keep on displaying MS Sanserif. Is this possible to correct?
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR |
16th July 2016, 18:30 | #44 | Link | ||
I just wanted a directshow filter based on the library libass since its still actively developed and an easy project to work on.
17th July 2016, 23:30 | #45 | Link |
I'm glad that you started this project!
I stopped using XySubfilter a few years ago when I started upscaling my videos to 4K. It was buggy and very resource intensive at 2560x1440 and even worse at 4k rendering. (I upscale to 4k with madvr, mpc-hc and lav) Even the built in subtitle renders in MPC-HC and BE could not do 4K subs with out errors, crashes, etc. AssFilterMod is able to render 4k subs without crashing the video players that I use with my test videos. I do run into some slow downs if there is a lot of animated subs being displayed at the same time or larger, animated fonts being displayed. Not the render's fault, of course as a lot of resources are being used at 4k. I like consistency in my playback so I usually use 2560x1440 for the subs on my 4K up-scales. There is not a huge difference in quality, IMHO, between 4k and 2560x1440 rendered subs and it plays some of the more aggressive subtitles without losing frames. Plus, compared to internal sub renders at the same 2560 resolution, AssFilterMod looks better and doesn't use much more rendering power. At least now, I have the option to use 4k sub rendering if I so choose. I look forward to your continued development of this project! |
17th July 2016, 23:46 | #46 | Link |
Blitzker,
When setting font, does it have to be within the filter or player? I'm using mpc be and dsplayer. The font being used differ from time to time. I was thinking maybe there is something in the srt file it self. Im using windows 10 pro x64
20th July 2016, 12:33 | #48 | Link | |
How do I change this in the renderer? I use lav filter and madvr Sent from my iPhone using Tapatalk
20th July 2016, 19:28 | #49 | Link | |
Quality Checker
this for MPC-Like 1 - Go to "External Filters", press "Add Filters" and add all of: DirectVobSub, AssFilterMod and XySubFilter 2 - From the right side, change the preference of each of those filters to "Block" except AssFilterMod 3 - Set the preference of AssFilterMod to "Prefer" i hope this will help you
I love Doom9 Last edited by amayra; 20th July 2016 at 19:31. Reason: typo |
17th August 2016, 13:35 | #50 | Link |
Virtual_ManPL
Thank you very much for the AssFilterMod !
I did some quality comparison for subtitle renderers. For this I used file "[FTV-subs] Touhou - Bad Apple!! PV [960x720] v2.mkv" with "simple karaoke" (first track) subtitles. fullscreen mode in 1680x1050 resolution - AssFilterMod 0.2.1 [harfbuzz] http://i.imgur.com/j5GAnpl.png - AssFilterMod 0.2.1 [885515f] http://i.imgur.com/A4g0r3h.png - XySubFilter 3.1.0.746 BETA3 http://i.imgur.com/EdidGLE.png - MPC-HC 1.7.10.252 http://i.imgur.com/PeLFVAp.png - xy-VSFilter 3.0.0.306 http://i.imgur.com/9PQYnJ8.png windowed mode in enabled "Auto-zoom:" with set "Auto Fit" and "Auto fit factor:" set to "75%" in MPC-HC: - AssFilterMod 0.2.1 [harfbuzz] http://i.imgur.com/PXytcCs.png - AssFilterMod 0.2.1 [885515f] http://i.imgur.com/QEopXk9.png - XySubFilter 3.1.0.746 BETA3 http://i.imgur.com/03RDKlg.png - MPC-HC 1.7.10.252 http://i.imgur.com/ZqIAFiZ.png - xy-VSFilter 3.0.0.306 http://i.imgur.com/Aqkl0mY.png My opinions and observations: - xy-VSFilter isn't usable in this days, because of awful and terrible subtitle rendering quality - XySubFilter produces a little more sharper subtitles than MPC-HC - AssFilterMod produces sharpest subtitles, compared to XySubFilter, MPC-HC and xy-VSFilter - AssFilterMod [harfbuzz] produces a little more sharper subtitles than AssFilterMod Vertical subtitles are smaller in AssFilterMod (at least with this file), compared to XySubFilter, MPC-HC and xy-VSFilter. Is it a bug? |
17th August 2016, 23:35 | #51 | Link | |
What changed exactly with those builds I see nothing mentioned in the GIT. |
23rd August 2016, 23:24 | #55 | Link | |
Quality Checker
edit: sorry is moded Build
I love Doom9 Last edited by amayra; 23rd August 2016 at 23:47. Reason: nope |
2nd September 2016, 04:32 | #58 | Link | ||
Yes, it only work with embedded subtitles for now. I'll start to look into external subtitles when i get more time.
3rd September 2016, 01:06 | #60 | Link | |
I've made a new build based on harfbuzz with a not yet released version of libass. This fixes a problem with the drawing of outlines with some fonts. harfbuzz: http://imgur.com/20wSgYv harfbuzz_x1: http://imgur.com/iQx9lvV Works good for me but it needs more testing.
