Old 28th March 2009, 20:57   #121  |  Link
Sharc
Encoding a DVD:
- Even though I selected Force DirectShowSource, DGindex was still used. Is this on purpose?
- When I select subtitles, the NONE should become unticked / disabled.
Old 28th March 2009, 21:14   #122  |  Link
Chengbin
buzzqw, why can't we just have a "save settings" button like AutoMKV? It is much more convenient than this hidden option thing.
Chengbin is offline   Reply With Quote
Old 28th March 2009, 22:39   #123  |  Link
buzzqw
HDConvertToX author
@SMD
near done...
http://www.64k.it/andres/data/hdconv...ertToX-SMD.exe
i have few question (feel free to link me thread) about
stream par ?
and container par : is this the same as "Display par" ?
thanks again for your priceless support!
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 28th March 2009, 22:45   #124  |  Link
flebber
Practising Schemer
@SMD
near done...
stream par ?
BHH
Wow this last update added a lot of polish to it.
flebber is offline   Reply With Quote
Old 28th March 2009, 23:03   #125  |  Link
flebber
Practising Schemer
I wasn't able to get this file to be analyzed by the new version.
General
Complete name : C:\Rip\Source Video\metalvideos2\As I Lay Dying - 94 Hours.mpeg
Format : MPEG-PS
File size : 30.9 MiB
Duration : 3mn 5s
Overall bit rate : 1 396 Kbps
Writing library : encoded by TMPGEnc (ver. 2.521.58.169)
Video
Format : MPEG Video
Format version : Version 1
Format settings, Matrix : Default
Duration : 3mn 5s
Bit rate mode : Constant
Bit rate : 1 075 Kbps
Nominal bit rate : 1 150 Kbps
Width : 352 pixels
Height : 240 pixels
Display aspect ratio : 4/3
Frame rate : 29.970 fps
Scan type : Progressive
Bits/(Pixel*Frame) : 0.425
Writing library : TMPGEnc 2.521.58.169
Audio
Format : MPEG Audio
Format profile : Layer 2
Duration : 3mn 5s
Bit rate : 224 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Resolution : 16 bits
It just paused a long while, then returned unable to calculate correct aspect ratio.
Old 28th March 2009, 23:45   #126  |  Link
Chengbin
HDConvertToX will not mux the encode after encoding has finished even though there is a line of command telling it to do it.
Also, when I specify a final file size, it uses that size for the video, not for the entire file like it should of had.
When will it automatically delete the temporary files? Why can't it be in a folder named temp like in AutoMKV?
When will the file extension bug fixed? When I specify x264+mp4, and choose a save location, the ending is in .avi. (The save file should be automatic)
Why is DGindex used for a H.264 file? Why does it have to extract the video file? For some reason it says my source video is in some non standard frame rate (the source's frame rate is 23.976)
Also, why is NeroAAC settings messed up. I set the quality to 4, which I assume is equivalent to 0.40 in AutoMKV. But the resulting file is much bigger (185Kbps than 110Kbps). What quality setting should I use for a quality equivalent to 0.40 and 0.50 in AutoMKV?
In the SMD version, the deinterlace function is gone.
For some reason, I can't encode using this GUI twice. I must delete and reextract the files to be able to encode again.
Pressing the anamorphic encoding button resets the resolution, which can be annoying sometimes.
Sometimes you can't get HDConvertToX to add DGAVCIndex to the queue, and without that it seems that you can't encode files.
I really want to use this GUI, because it is almost 3x faster than AutoMKV at encoding videos with MVDegrain 3, but there are too many faults on this right now that forces me to stick with AutoMKV for a long time. AutoMKV was just so damn simple, and that's what made it fantastic. All you need is 5 seconds (literally) to start encoding a video. In HDConvertToX right now, 50 seconds isn't enough. If this doesn't change, it will really piss me off when I start encoding anime, where I can encode 10 videos a day.
Old 29th March 2009, 00:20   #127  |  Link
Sharc
mod16.txt still seems to have no effect on cropping / resizing.
Old 29th March 2009, 00:58   #128  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
@SMD
i have few question (feel free to link me thread) about stream par? and container par : is this the same as "Display par" ?
"Stream Level PAR" and "Container Level PAR" offer different methods of re-shaping the video image during playback.
Containers such as .MP4, .AVI, .TS and .M2TS favour placing their PAR signalling at the "Video Stream Level" (ie: within the video stream).
Containers such as .MKV and .MOV favour placing their PAR signalling at the "Container Level" (and remove all traces of PAR signalling from the video stream).
As an experiment, if you use MKVMerge to mux this elementary .h264 video stream into the .MKV container, the video streams 64:45 (1.4222) PAR signalling will be removed and automatically re-allocated to the .MKV container as 1024x576 pixels.
Indeed, if you use MKVExtract to de-mux the elementary .h264 video stream and then run it thru' DGAVCIndex, it will not be able to detect any SAR (aka: PAR) signalling.
Old 29th March 2009, 07:36   #129  |  Link
Sharc
Queue Tab:
Remove job and Remove all job clears the list only, however it does not really remove or reset the job. When one presses Add to Queue, the new job is again added to the previous one which was apparently not cleared.
Old 29th March 2009, 08:14   #130  |  Link
Sharc
DVD Source:
When I load the .ifo and select the largest PGC, the movie duration, frame number etc are displayed correctly. However, audio and subs are only extracted for the 1st vob, and the program then just terminates.
When I load the first vob, the movie duration and frame number are displayed for the 1st vob only. However, audio, subs and video are extracted and encoded for the full movie (i.e. all vobs) as expected.
Old 29th March 2009, 09:16   #131  |  Link
buzzqw
HDConvertToX author
update to http://www.64k.it/andres/data/hdconv...rtToX-SMD2.exe
new shining layout. A BIG thanks to SeeMoreDigital!
HDConvertToX if not specified a tempary folder will create a "temp" folder in its folder and create temporary files here
save file extension will look at container selected
fixed nero aac bitrate
mod16.txt, mod8.txt, mod4.txt will also apply to crop values
@flebber
please open the analyze.avs in virtualdub, there is any errors ?
hdconverttox use directshowsource, so be sure to have installed a decoder (haali with mpeg/ps enabled and ffdshow with mpeg2/dvd decoding activated)
@Chengbin
in Utilities there is a "Make report" button. Use it
computing bitrate is different than automkv. a more precise bitrate will be present in future update
use the SDM2 update
use the SDM2 update
use the Make Report button
use the SMD2 update
check the "Video Encoder" panel
try the SMD2 update
otherwise use Make Report
only height is changed. and is due to new AR
use Make Report
@Sharc
use SMD2 update, now mod16 (or mod8) is used for autocrop too
about dvd/pgc
please post a make report of both job! thanks!!
remove job will remove only the last line of jobs, remove all job will delete all the queue.
@SMD
thanks again and again
i will look at this!
BHH
Old 29th March 2009, 09:43   #132  |  Link
Sharc
@Sharc
- SMD2 update
- mod16.txt copied into the main directory
- DVD source 720x576
=> Autocrop top 74 , bottom 74
This is not mod16 compliant, nor is the cropped and resized picture 720x300 mod16 compliant.
Old 29th March 2009, 09:55   #133  |  Link
buzzqw
HDConvertToX author
@Sharc
EDIT: please redownload SMD2 (autocrop mod16 is fixed for dvd source too)
thanks
BHH
Old 29th March 2009, 10:41   #134  |  Link
Sharc
mod16 is fine now. Thanks.
Queue:
Pressing Remove all job only clears the text in the joblist, it does not really purge the job. When I press Add to Queue afterwards, the old job re-appears again in the list, plus the new job is added to the previous job which should have been purged.
Edit:
Hmm, I guess I have to press Save Queue after Remove job or Remove all job to purge the history.
Old 29th March 2009, 11:08   #135  |  Link
buzzqw
HDConvertToX author
Sharc, please redownload SMD2 (for queue)
but.. truly, i am unable to replicate
BHH
Old 29th March 2009, 11:23   #136  |  Link
Sharc
It's the same, but now I noticed that it is only the subtitles command lines which are not purged and always get replicated.
Old 29th March 2009, 11:30   #137  |  Link
buzzqw
HDConvertToX author
@Sharc
last one, please again with SMD2
thanks!
BHH
Old 29th March 2009, 11:39   #138  |  Link
Sharc
OK, this problem is solved!
Old 29th March 2009, 12:08   #139  |  Link
Mtz
Mtz's Avatar
I see something wrong using SMD2:
"C:\Program Files\HDConvertToX\applications\mkvmerge.exe" -o "D:\Temp\buuz.mkv" --default-duration 0:23.976fps --aspect-ratio -1:2.3530 "D:\Temp\hdconverttox_kfp movie 17 subs srt-uncropped.h264" "D:\Temp\hdencodertoxvid-pid2.ac3" "D:\Temp\hdencodertoxvid-pid3.ac3" --language -1:eng "D:\Temp\hdencodertox__subs_4.srt" "D:\Temp\hdencodertox__subs_5.srt" "D:\Temp\hdencodertox__subs_6.srt" "D:\Temp\hdencodertox__subs_7.srt" "D:\Temp\hdencodertox__subs_8.srt" "D:\Temp\hdencodertox__subs_9.srt" "D:\Temp\hdencodertox__subs_10.srt" "D:\Temp\hdencodertox__subs_11.srt" "D:\Temp\hdencodertox__subs_12.srt" "D:\Temp\hdencodertox__subs_13.srt" "D:\Temp\hdencodertox__subs_14.srt" "D:\Temp\hdencodertox__subs_15.srt" "D:\Temp\hdencodertox__subs_16.srt" "D:\Temp\hdencodertox__subs_17.srt"
Using this test, the final MKV file is not created.
enjoy,
Mtz
Mtz is offline   Reply With Quote
Old 29th March 2009, 12:33   #140  |  Link
buzzqw
HDConvertToX author
it's not the problem, here is perfectly used
please launch from dos the string and post the exact error
BHH
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui
