25th November 2011, 01:20 | #62 | Link |
amtm did you ever think to improve the tool allowing insert silence or cut audio inside the file?
you add the points in the audio and the operations (add silence, remove audio, loop the audio) and he make all the changes in one pass...complete basic editing without recompression... there's nothing like this... eac3to allows to insert silence or remove audio in track but only one for pass (so with 5 editing i have to recreate 5 times the full file), your tool allows cuts and delay but no insert or cut in the middle, besplit only split the file in parts... I already create my own program to do that based on this tool but everytime i have to split & then join increasing the time and i can't compensate the not fixed delay... naturally it's not so easy to do but it could be a very useful tool... perfect for me... if you have time think about it...i try to look into the code but it's too much for my skills Last edited by phate89; 25th November 2011 at 01:44. |
25th November 2011, 12:47 | #63 | Link | |
different dts frames
One thought about delaycut vs eac3to.
For example. Look at this stream from BD. Try to decode it (by ArcSoft/Sonic/Nero) and then using delaycut add delay and retry decode. Then cut delay and retry again Can you add Blu-ray's dts frames to "default silent DTS frame" of delaycut? Last edited by TDiTP_; 25th November 2011 at 17:29. Reason: typo |
25th November 2011, 17:39 | #65 | Link | |
Addition to my previous post. If we talking about "Targeted BitRate"=1536: 1). Most of "Blu-ray DTS" (all that i saw, but can be exceptions) have 2012 bytes per frame. 2). All "core DTS" have 2012 bytes per frame. This is most important. At least for this we must have support for such frames in delaycut, which can add only 2013. 3). In DTS-HD M.A.S. when we select "Destination Format = DVD (.cpt)" we always get 2013 bytes per frame. If "Destination Format = Blu-ray disc (.dtshd)" we always get 2012 bytes per frame (in dts or "core dts"). Last edited by TDiTP_; 25th November 2011 at 17:46. |
26th November 2011, 22:59 | #66 | Link |
I found another couple of bugs.
1) Changes to the video FPS field don't cause the program to recalculate unless you change another field or change an checkbox. 2) The starting offset delay doesn't re-autopopulate / recalculate if re-opening the same file or changing the FPS. 3) Changing from frames to ms causes the starting offset delay to decrease each time you switch 4) The starting offset delay isn't subtracted from the cut file End setting so the output audio is too long Last edited by Stereodude; 28th November 2011 at 13:38. Reason: adding #4 |
28th November 2011, 12:15 | #67 | Link |
Pajas Mentales...
i have problems build in my archlinux
sl1pkn07@sL1pKn07 delaycut $ qmake -makefile delaycut.pro sl1pkn07@sL1pKn07 delaycut $ make g++ -m64 -Wl,-O1,--sort-common,--as-needed,-z,relro,--hash-style=gnu -Wl,-O1 -o delaycut -L/usr/lib -lQtGui -lQtCore -lpthread /usr/lib/gcc/x86_64-unknown-linux-gnu/4.6.2/../../../../lib/crt1.o: In function `_start': (.text+0x20): undefined reference to `main' collect2: ld devolvió el estado de salida 1 make: *** [delaycut] Error 1 sl1pkn07@sL1pKn07 delaycut $ Last edited by sl1pkn07; 28th November 2011 at 12:18. |
2nd December 2011, 19:00 | #68 | Link |
Posts: n/a
Sorry, I've been away for a bit. Will address the bugs this weekend. sl1pkn07 your build problems are due to their being two different configs in the pro file. You need to add a CONFIG+=Linux on your qmake line. I'll update the readme with information about building from source so that's more obvious.
4th December 2011, 13:00 | #71 | Link | |
you think it's possible to make a program like the one i described before? i'm trying to look at the C++ code to understand how it works and try to do it myself but is far too adanced for me... the first problem is that i have no clue how are composed the files... You think it's theorically possible? |
6th December 2011, 13:18 | #74 | Link |
Another suggestion to DelayCut improvment.
If we have a ac3 file with mixed content (for instance a TV capture with 5.1 frames from a movie and 2.0 frames from commercials), DelayCut show a message like: Time 00:00:20.032; Frame#= 627. Some basic parameters changed between Frame #1 and this frame But the output file remains invalid (a valid ac3 stream must contain only the same frametypes). Also the 'Num of frames' and 'Duration' are incorrect because the 'FrameSize' change. I suggest a flag with 3 options: 1) Ignore FrameType changes (like now) 2) Extract only frames like first FrameType. 3) Extract only 5.1 frames.
9th December 2011, 16:50 | #75 | Link | |
usually ads are 2.0 so will be removed automatically |
12th December 2011, 17:49 | #76 | Link |
Posts: n/a
Sorry guys I've been really bad about getting back to this. I've have written down all the suggestions on my TODO list. I really hope to get a new version out this weekend that at least addresses the last couple of bug reports before I get into implementing those new features. Just want to let you know that I am still monitoring this. The time leading up to this holiday has just been rather crazy.
13th December 2011, 10:05 | #77 | Link |
I searched long time for a tool to add silence and cut as described by phate89. Now I am using besplit to break the ac3 in parts, ac3to to add delay to each part o cut the beginning and ac3to to rejoin the fragments. It's automated (so, no extra work), but it's ugly.
And let me add another option to tebasuna51 flag to deal with mixed ac3 frames: 4) Force the track to be 5.1 or 2.0 (dropping channels or adding silence channels). It this is not possible without reencode, forget it. And, please, rememeber to add the new options to command line. Thanks for your work, and don't worry about time. |
14th December 2011, 04:39 | #80 | Link | |
To much job for a useless, for me, output.
