Old 1st March 2010, 21:06   #1  |  Link
tetsuo55
MPC-HC Project Manager
MPC-HC toolbar button skining support!
EDIT: we now have the toolbars on our wiki https://sourceforge.net/apps/trac/mp...Toolbar_images
Hello everyone,
Starting from nightly build r1706 we now support skinning of the toolbar buttons.
play, pause, etc...
mpc-hc.exe will look inside the directory you placed it in for "toolbar.bmp" if found it will use that instead of the internal icons.
A short how to:
First select the height you want your icons to have (between 1 and 32 pixels)
Then multiply that height by 15 to determine the total width
Each icon itself is as wide as it is high
bitdepth can be <= 24, in which case RGB(255, 0, 255) is considered transparent or of bitdepth 32, in which case the alpha channel is used for transparency / gradients
Compression is NOT supported
Sample regular size toolbar.bmp:
Download:
http://www.mediafire.com/file/orttqy54mym/toolbar.bmp
Sample giant size toolbar.bmp:
Download:
http://www.mediafire.com/file/ezlhgwxderj/toolbar.bmp
Here is another example by one of the mpc-hc users:
http://forum.doom9.org/showthread.ph...21#post1379021
You can edit these samples to create your own skin, or design them from scratch following the above guidelines.
Please share your creations with the others on the forum.
tetsuo55 is offline   Reply With Quote
Old 1st March 2010, 23:45   #2  |  Link
Phaser
Nice to see skinning support...
I tried something quick to see how it works...
I worked with PNG files and then converted them to 32-bit BMP using AlphaConv.
DOWNLOAD (size 16)
DOWNLOAD (size 32)
If anyone is interested maybe I'll do some more. Looking forward to see other ideas and creations...
Phaser is offline   Reply With Quote
Old 1st March 2010, 23:49   #3  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Originally Posted by Phaser View Post
I tried something quick too see how it works...
Great, I like 32px one!
tetsuo55
Is it possible to make volume indicator skinable too?
EDIT: ohh, and slider too!
Old 2nd March 2010, 00:25   #4  |  Link
Inspector.Gadget
If anyone is interested ...
If that's "quick", I can't wait to see what you make with a bit more time. They both look great -clean and modern.
Inspector.Gadget is offline   Reply With Quote
Old 2nd March 2010, 01:19   #5  |  Link
Peuj
Peuj's Avatar
Nice work Phaser.
This should be also pushed on http://www.deviantart.com.
As there are a lot of "skinners" there, this could promote the creation of MPC-HC toolbars.
Peuj is offline   Reply With Quote
Old 2nd March 2010, 01:27   #6  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Too early imo. Maybe (hopefully) this thing will be upgraded for support skinning of the other things.
Old 2nd March 2010, 01:43   #7  |  Link
stax76
staxrip & mpv.net
would be great
I have a dream by Martin Luther King
one hundred years later...
We can never be satisfied...
With this faith...
Let freedom ring...
Old 2nd March 2010, 03:49   #8  |  Link
hdboy
tetsuo55
Love the bigger icons, but I've gotten used to using the keyboard for basic operation. I still use the trackbar so would love a bigger trackbar.
Win 7 x64, AMD Phenom II X6 1075T, nvidia 430GT, mpc-be x86
hdboy is offline   Reply With Quote
Old 2nd March 2010, 07:23   #9  |  Link
iron2000
Questioning User
I like this new function!
Thanks for making it possible!
Would like the seekbar to be updated too.
The style of the current one looks Win95-98 to me.
8 Pro x64 | i5-3470 | 8GB ram | GT430 | Xonar DX | MPC-HC x86
iron2000 is offline   Reply With Quote
Old 2nd March 2010, 09:17   #10  |  Link
Rain1
Rain1's Avatar
DOWNLOAD (size 16)
I <3 the size 16
Thanks so much for sharing that
Rain1 is offline   Reply With Quote
Old 2nd March 2010, 09:21   #11  |  Link
tetsuo55
The volume and seek bar's cannot be made skinnable without a massive refactoring of the gui code.
And if anyone considers doing that they might as well rewrite the gui in QT to make it not only faster but also completely skinnable (to the point that you could even change the gui to look like a star if you wanted to). That would also turn translation into a simple list of words(instead of the nightmarish .rc files we have now)
I do expect a patch that will let the volume bar grow in size to match the icon size.
Old 2nd March 2010, 09:54   #12  |  Link
Phaser
Here's some more:
DOWNLOAD (size 32)
DOWNLOAD (size 32)
Old 2nd March 2010, 10:06   #13  |  Link
lucamark
Gigibop!!!
Many thanks Phaser and whole developers team!!!
lucamark is offline   Reply With Quote
Old 2nd March 2010, 10:10   #14  |  Link
iron2000
Questioning User
Not sure about QT but are there more modern looking QT widgets?
Anyway I made a 3 simple toolbars using the GUI fx font:
Download
Also a 16px template:
Download
I prefer size 16px and either square or icon style :P
Old 2nd March 2010, 10:28   #15  |  Link
tetsuo55
ooh i like that 3rd one a lot!
Here is a sample of a modern looking QT skin
Old 2nd March 2010, 18:53   #16  |  Link
Razoola
Here's some more:
DOWNLOAD (size 32)
DOWNLOAD (size 32)
Im trying the crystal blue ones but they are appearing in black and white in the player.
I have found that if I open the player only(without movie) then they are black and white. As soon as I load a movie they go blue... Maybe a bug in the code?
Old 2nd March 2010, 19:32   #17  |  Link
Phaser
I don't think that's a bug... Maybe they're meant to be "black and white" when they are inactive...
Old 2nd March 2010, 20:39   #18  |  Link
Razoola
Ahh yes, I did not think of that. I think it would be better though to stay a set color for those icons
Old 3rd March 2010, 02:01   #19  |  Link
bobdynlan
Beyond the Corn Border
bobdynlan's Avatar
http://forum.doom9.org/showthread.ph...49#post1378249
This issue with custom windows themes could be fixed by instructing MPC-HC to get the final background color for the toolbar from HCU\Control Panel\Color\ButtonLight (i.e. 3D-Objects).
Skinning the progress bar could be done with standard controls using something like:
http://www.ucancode.net/CPP_Library_...VC-Article.htm (not the perfect example but others can be found)
Skinning the volume control - maybe using a standard "transparent" slider and paint the background around it:
http://www.codeguru.com/cpp/controls...icle.php/c5253
The current GUI its fast, its plain simple, but that does not mean it cannot be beautified a little without a redesign. No need to waste time on winamp-style bitmap skinning, should jump directly to OSD-style generated "skin".
bobdynlan is offline   Reply With Quote
Old 3rd March 2010, 18:23   #20  |  Link
sabret00the
Glad to see this, I made this post in the other thread.
Originally Posted by sabret00the View Post
I would like to see greater Windows 7 support. WMP12 has got everything right, from the transparency behind the controls, to the updated icons to to the fact that you can play/forward/pause/stop all from the task bar. I moved over to MPC because I felt that WMP was dated and didn't conform with the current needs of a media centric user, however now I'm starting to feel that about MPC. As much as it may be frowned upon, it's time to bring the GUI into the 21st century.
sabret00the is offline   Reply With Quote
icons, mpc-hc, toolbar
