19th September 2009, 20:09 | #2341 | Link |
All my templates are for creating files of 172 MB, including the Default Template, but the file at a time out with another 93 mb to 280 mb, I open the file file in MediaInfo is the bitrate of the video is very different in what was displayed in StaxRip unfortunately I did the donkey to delete the files, I'm currently converting the same files via script done in notepad (DirectShowSource + Virtualdub) to see if the problem is with Xvid, I convert the back end and send you the log. Thank you. Note: When I used Divx (6.8.0) worked properly, except the error at the end of the encode (in the same error that I reported on earlier), but the file is normal, without error and about the size as indicated .
20th September 2009, 00:49 | #2343 | Link |
Stax, did versions prior to 1.1.1.6 use VFW to open xvid as well? I think for newer versions of Windows such as Windows 7 Directshow may be the better course of action, since VFW is a relic of the Windows 3.1/9x days...
23rd September 2009, 18:30 | #2345 | Link |
1.1.1.7 beta
http://www.stax76.bplaced.net/files/....1.1.7_beta.7z
24th September 2009, 03:11 | #2346 | Link |
The Lazy One
Location: The TurokZone. Next Door are the heavens, hells, and on the backside the void
Thanks for the release stax. I got some problems though... I don't know how to load avs scripts up in staxrip and I am wondering if I do it in profiles and if I do how then? Also tried using SangNom I put this is script area "SangNom(1,48)" did I do something wrong as it didnt work.
24th September 2009, 06:43 | #2347 | Link |
Practising Schemer
Taxi still crashes after audio encoding when ffmpeg starts(as with files I sent you for 1.1.6) not sure what is happening there, I used same settings and different input and it worked fine.
Having a little absent minded problem I do I set staxrip to import chapters from input and apply to final file? @ turok did you right click on filters window and select edit. and add filter in format filter = filter(settings).anyOtherFilter(Settings) |
24th September 2009, 13:00 | #2348 | Link |
How do I set the resolution of a template? I try to convert a series of videos (Batch Conversion) from 720p to 720x400, but the Stax always changes to the resolution of 672x384.
24th September 2009, 13:41 | #2349 | Link |
@flebber
Sorry, I forgot to fix it, I'll do tommorow (no programming today). StaxRip don't extract chapters, it wasn't a issue in the past as DVD Decrypter did it, since then nobody made a request IIRC. @Havokdan StaxRip has a lot aspect ratio and resizing related options, please search and try to understand these options. (In the options dialog disable 'Auto resize image size'.
24th September 2009, 14:28 | #2351 | Link |
Practising Schemer
Would an option to be able to be added to add a chapter.txt file so Staxrip can use it. I could then use ChapterExtractor to create the files and simple plug the text files into staxrip
24th September 2009, 14:55 | #2352 | Link |
It's already there at 'Container Configuration'.
24th September 2009, 15:47 | #2354 | Link |
I'm not sure about the format, I'm not using chapters or subtitles and these features were added 5 years ago. In the 'Container Configuration' there is a feature to preview the command line.
25th September 2009, 12:12 | #2358 | Link |
I got this error when I encode in win7. The same project goes fine in xp. Any ideas?
I am using staxrip 1.1.1.7 and x264 ver1271 but I got the same error with all combinations of staxrip 1.1.1.1,1.1.1.4,1.1.1.7 and x264 versions 1201-1268. ------------------------------------------------------------ Error ------------------------------------------------------------ x264 Encoder failed with exit code -1073741819 avis [info]: 576x432 @ 25.00 fps (71730 frames) x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [info]: profile High, level 4.1 |
26th September 2009, 18:02 | #2359 | Link |
@thax
Welcome to the forum. It's likely not a StaxRip bug, please use google and the forum search to find a solution and if it don't help post to the AVC forum.
26th September 2009, 20:33 | #2360 | Link |
Since it's frequently asked I finally wrote a little guide on how to use AviSynth filters in StaxRip. The link to this guide can be found in the initial post of this thread.
@flebber I've uploaded a hotfix, the project you've sent me had a audio profile only accepting AC3 as input, you have to change this to accept wav when you force decoding. Your profiles had 6 channels so you will get a very large wav file! http://www.stax76.bplaced.net/files/...beta_hotfix.7z
gui, h.264, h.265, hevc, mkv, x264, x265 |
