Old 30th July 2011, 22:29   #2161  |  Link
Rat Killer
I have a large number of files where the video is fine but the audio is in the wrong format and both need to go into an mp4 container. At the moment I use the HD streams extractor to extract an h264 file and an ac3 (converted from aac) file. Then use the mp4 muxer to put them into the new container. One file at a time.
Is there any way to do a job like this in a more automated way like with the one click encoder without recoding the video?
Rat Killer is offline   Reply With Quote
Old 31st July 2011, 20:58   #2162  |  Link
Dal
Megui and DGAVCDecDI
Is there any chance that MeGui will support DGAVCDecDI?
Or is there a way to replace DGDecodeNV with DGAVCDecDI?
As it is now, when I try to open a h264 .ts file in file indexer, MeGui seems to use DGAVCIndex, which is old, and cannot demux multiple audio streams at once.
And when I index the file "manually" with DGAVCIndexDI.exe (creating a .dgi file), and try to open it with AVS Script Creator, I get this error:
AviSynth scrip error:
LoadPlugin: unable to load "<path to megui\tools\dgindexnv\DGDecodeNV.dll"
But that is natural since I don't have a Nvidia GFX card.
If there currently is no way to use DGAVCDecDI in MeGui, consider this a request
Thank you.
Dal is offline   Reply With Quote
Old 3rd August 2011, 22:27   #2163  |  Link
LeXXuz
21 years and counting...
LeXXuz's Avatar
Originally Posted by Zathor View Post
2041 [Audio Encoder] added 24 <--> 25 conversions
No more 'manual' conversions for me. Thank you!!!
LeXXuz is offline   Reply With Quote
Old 20th August 2011, 14:58   #2164  |  Link
meshaun
Hi guys..
Umm, I got MeGUI not responding in the 1-Click.
It shows Preprocessing for hours!!!
Nothing goes forward or anything but the preprocessing is just happening it seems
meshaun is offline   Reply With Quote
Old 20th August 2011, 15:51   #2165  |  Link
Zathor
Please post your log file.
Zathor is offline   Reply With Quote
Old 21st August 2011, 23:15   #2166  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
Would be wonderfull can encode h264 @10 bit using megui. Is possibly??
Thanks. ^^
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline   Reply With Quote
Old 23rd August 2011, 08:59   #2167  |  Link
LeXXuz
LeXXuz's Avatar
It would be great if the Audio Cutter supports AAC in MP4 container.
If that's too much effort, an automated demux, either after AAC encode with nero or before cutting would be great.
This would spare users to manually demux AAC streams before using the Audio Cutter.
Old 23rd August 2011, 10:48   #2168  |  Link
tebasuna51
tebasuna51's Avatar
Audio Cutter is bassed in BeSplit (abandoned), without support for containers.
Also don't support AC3/MP3 in AVI's, ...
But a Tool option to demux MP4, AVI, ... like HD Stream Extractor for MKV, M2TS,... can be usefull (even manually).
Old 25th August 2011, 09:36   #2169  |  Link
himan2001
An very old anoying Bug is back in megui/mkvtoolnix:
The created Videofiles for 24000/1001 contains again
the wrong framerate of 23975(!) instead 23976 or 24000/1001.
Only the final muxed container has the correct framerate:
eac3to-Demux-Sample:
MKV, 1 video track, 1 audio track, 0:42:28, 24p /1.001
1: h264/AVC, 720p23.975 (16:9)
"H.264 Video"
2: AC3, 5.1 channels, 448kbps, 48kHz
"English DD 5.1"
v01 The video bitstream is encoded in a non-standard framerate.
v01 The video bitstream framerate field doesn't match the container framerate.
...and in popcornhour the same infos.
This was fixed for while and now the old Framerate-Bug is back.
The problem comes up with creating the Videostream itself. mkvtoolnix later only remuxes the container with the correct framerate of 24000/1001 but not fixx the wrong Video-Framerate itself!
So when a user encode with "23.976", please make sure the Info is correctly written to the Videobitstream itself when encoding ;-)
himan2001 is offline   Reply With Quote
Old 25th August 2011, 10:30   #2170  |  Link
tebasuna51
tebasuna51's Avatar
the wrong framerate of 23975(!) instead 23976 or 24000/1001....
Remember use the AssumeFps(24000,1001) in the .avs script.
Old 25th August 2011, 11:12   #2171  |  Link
himan2001
This is a general problem for the wide masses ;-)
In the AVS Script the Framerate is set to 23.976 since very long time and the resulting File is 23975(!), so it is a new bug
Question: WHY is this 24000/1001-thing newly needed, when source is comming from BluRay ?
This setting was not needed in older Versions of MEGui and it was fixed in an older Vewrsion, but donīt remember, in which Version.
Old 25th August 2011, 18:10   #2172  |  Link
Zathor
Please provide the complete log file of the conversion process.
Old 25th August 2011, 18:28   #2173  |  Link
himan2001
DirectShowSource("BDsource.mkv", fps=23.976, audio=false, pixel_type="YV12")
Spline36Resize(1280,720,0,0,1920,1080)
Thatīs all. Since Years i use it, and with older Versions of Megui/mkvtoolnix the resulting "video.mkv" gehts 23.976
in the Header. Now Is 23.975 and is complained in poppy and eac3to and maybee more devices and demuxers.
I see the problem, that "Millions of Peoples" use the "Default-Scripts" since years, and now the "AssumeFPS(24000/1001) is needed ?
I think it makes more sense, when a source comes with "ntsc_film", then the resulting ES-Stream has the 24000/1001 correctly setted as "default", like in the old MeGui-Versions ;-)
Old 25th August 2011, 21:34   #2174  |  Link
tebasuna51
tebasuna51's Avatar
Use DirectShowSource("BDsource.mkv", audio=false, pixel_type="YV12").AssumeFps(24000,1001)
Is a DirectShow problem, not MeGUI or AviSynth.
Old 25th August 2011, 22:05   #2175  |  Link
himan2001
Why is this NOW a problem ? It worked a long long time without the "new" settings, but thx anyway.
Iīam not changed the decoder or avisynth or the directhsow.dll the last 2 years, but i made updates to Megui/mkvtoolnix, and now there is this problem (back again)...
This Problem WAS fixed in Megui, but canīt remember, why is now back.
I think itīs easier to handle this internaly as default.
I really see not the Problem to fixx 23975 -> 23976 finaly
There is only one real "ntsc_film" Frequency, so i see no problem to handle this always correctly without producing new non-standard filmrates ?
Hmmm...
Old 25th August 2011, 22:36   #2176  |  Link
AMED
AMED's Avatar
@himan2001
Try indexing your MKV with the file indexer in MEGUI.
A Man Eating Duck
AMED is offline   Reply With Quote
Old 26th August 2011, 11:38   #2177  |  Link
tebasuna51
tebasuna51's Avatar
The problem is related with the file to decode, not always appear.
@AMED, the same problem with ffms2.
Always put the explicit AviSynth statement AssumeFps
MeGUI add the needed AssumeFps with the Tool AVS Script Creator.
Old 27th August 2011, 18:18   #2178  |  Link
Zathor
2050 [Update] added check so that files can only be installed using the correct MeGUI build
2049 open avisynth script handling improved
2048 fixed spelling. Bug #3390630
2047 [x264] fixed maximum --rc-lookahead value. a value > 250 was possible in rare situations. Bug #3383262
Old 28th August 2011, 05:58   #2179  |  Link
meshaun
Why isn't there a option to Resize to a Higher resolution?
I have some Mobile videos in 320x and I want to resize those to 720x480.
Since the aviscript should be manually edited to make it resize, the calculations go wrong.
Why not make megui select the height automatically and enable options to maximize the resolution?
Old 31st August 2011, 21:57   #2180  |  Link
Zathor
Never tried it. What happens when you replace the exe files?
I assume the reason is that in most cases it makes no sense to upsize. But there should already be a feature request in the list.
I do not have DGAVCDecDI and therefore cannot add it.
