18th August 2007, 08:20 | #683 | Link |
What exactly do I put in the gui's folder? The whole Aften folder (there's lots of stuff in there!). Or, just the Aften.exe which is in the Win32 subfolder? And also, where exactly do I pop it? In the Gui's main folder? Or in the Win32 subfolder? Or the "ansi" sub-subfolder? Sorry again for the newb questions!
22nd August 2007, 06:41 | #688 | Link |
Hi! Just want to clarify this: " I have substituted the FFmpeg MDCT implementation with the one from libvorbis, which is faster. " - Justin @ Aftenblog
Because I found out that the one from libvorbis is based on "The use of multirate filter banks for coding of high quality digital audio" by Sporer et al. But this paper was presented a very long time ago (1992). I am wondering why this has been chosen over other implementations and why there has been no updates since version 0.06 on this. If I am not mistaken, I think there are other more efficient methods, right? How does it compare against other mdct implementation in terms of speed and quality, why is it "faster" then? @wisodev and kurtnoise, i would just like to ask what you used to create the GUIs. (I am planning to create one that will operate stereo settings only) Thank you very much! |
22nd August 2007, 10:19 | #690 | Link | |
wisodev |
30th August 2007, 02:24 | #692 | Link |
Pajas Mentales...
sl1pkn07@SpinFlo:~/aplicaciones$ svn co https://aften.svn.sourceforge.net/svnroot/aften aften-0.07-svn
........ Revisión obtenida: 561 sl1pkn07@SpinFlo:~/aplicaciones$ cd aften-0.07-svn/ sl1pkn07@SpinFlo:~/aplicaciones/aften-0.07-svn$ cmake . -- Check for working C compiler: /usr/bin/gcc -- Check for working C compiler: /usr/bin/gcc -- works -- Check size of void* -- Check size of void* - done Please do an out-of-tree build: rm -f CMakeCache.txt; mkdir -p default; cd default; cmake ..; make CMake Error: in-tree-build detected -- Configuring done sl1pkn07@SpinFlo:~/aplicaciones/aften-0.07-svn$ use cmake version 2.4-patch 6 in Kubuntu X86_64 |
3rd September 2007, 02:04 | #695 | Link | |
Also, cpu-optimized versions of the libvorbis mdct were already out there ready to use. This wasn't part of the decision, but has been a definite advantage. I'm sure there are faster implementations out there. At one time DarkAvenger was doing some experiments using FFTW with Aften. It was a while ago, so I don't remember if it was any faster. |
10th September 2007, 05:00 | #696 | Link |
I just released Aften 0.0.8. Yes, I changed the version numbering. I hope it's not too confusing. I think the new versioning scheme will be easier to use. Anyway, here is the Changelog.
13th September 2007, 21:32 | #698 | Link | |
Thanks, wisodev
https://github.com/wieslawsoltes/wavtoac3encoder https://github.com/wieslawsoltes/BatchEncoder https://github.com/wieslawsoltes/SimpleWavSplitter Last edited by wisodev; 16th September 2007 at 13:22. |
13th September 2007, 21:38 | #699 | Link | |
