5th February 2006, 00:32 | #281 | Link |
function "Redo Authoring!" and bug of PowerDVD
I tested with using "Redo Authoring!", and found the problem when replaying by PowerDVD5.
I think its cause is bug of PowerDVD, because there is no problem when replaying by other PC players(MediaPlayerClassic, JetAudioPlayer). Example: I created DVD-Video by DVDShrink Re-Author Mode, which has 3 titles and each title has 3 chapters. I edited it by function "Redo Authoring!" of dvdshrink_plugin_v2.0beta1, of which setting is default except for 'When the Previous Chapter button is pressed during playback of chapter 1..., jump to the last chapter of the precious title'. Problem: It is only when replaying by PowerDVD5. After jumping directly to other title (using right-click, not using Prev/Next button, etc.), (1)when pressing the Next Chapter button, jump to chapter 1 of title 1 from last chapter of all titles(1,2,3). (2)when pressing the Previous Chapter button, jump to last chapter of title 1 from chapter 1 of title 1. _(problem is only from title 1, but no problem from other titles(2,3)) Cause and the reason why I suspected(it may be different): I thought PowerDVD may reset the value of gprm as 0, when jumping directly (using right-click, not using Prev/Next button, etc.). So, (1)when pressing the Next Chapter button, at VMG_PGC_1, *** pre commands: 1 Set gprm(2) =(mov) 0 2 Set gprm(0) =(mov) sprm(4:Title number in volume) 3 Set gprm(0) +=(add) 1 4 if ( gprm(0) > gprm(1) ) then { Set gprm(0) =(mov) 1 } 5 LinkPGCN PGC 4 in line 4, if gprm(1)=0, always "gprm(0) > gprm(1)", so "gprm(0)=1", so title 1 is always replayed. And, (2) when pressing the Previous Chapter button, at VMG_PGC_3, *** pre commands: 1 Set gprm(2) =(mov) 0 2 Set gprm(0) =(mov) sprm(4:Title number in volume) 3 Set gprm(0) -=(add) 1 4 if ( gprm(0) < 1 ) then { Set gprm(0) =(mov) gprm(1) } 5 LinkPGCN PGC 4 in line 4, if gprm(1)=0, only when "gprm(0)=0"(i.e. must be replayed title 3 after 1), "gprm(0) = gprm(1) = 0", so title 1 is replayed after title 1. Method to solve: I copied the command of line 1 of FirstPlay ”Set gprm(1) =(mov) 3”,and pasted before line 1 of VMG_PGC_1,2,3. *** pre commands: 1 Set gprm(1) =(mov) 3 2 Set gprm(2) =(mov) 0 or 1 3 Set gprm(0) =(mov) sprm(4:Title number in volume) 4 *** 5 *** 6 LinkPGCN PGC 4 I tested it, so there was no problem. As menshioned at first, it is the problem of PowerDVD5, not of PgcEdit. Thanks. Last edited by jinjin_jp; 5th February 2006 at 00:43. |
5th February 2006, 01:38 | #282 | Link |
PgcEdit daemon
Thanks for the info, jinjin_jp.
In my authoring, gprm(1) holds the number of titles in the DVD. Since it's a DVDShrink reauthored DVD, it's also the number of titlesets. The gprm 1 is set only once, in the FP-PGC (but is read severat times, when it is needed to know the number of titles.) Therefore, this value should never change. There is obviously a big bug in PowerDVD. I suppose that right-clicking in PowerDVD calls a menu with an option to play any title, by number. Right? Maybe, as you think, it resets all GPRMs to 0 when doing so. Doesn't matter, IMO, because you should test it with the regular DVD controls, not with the software players specific features. Anyway, there are other bugs with PowerDVD, for example with the time seekbar, disabled when there is a Next, Prev or GoUpPGCN link pointing to the same PGC.
5th February 2006, 03:10 | #283 | Link | |||
But other software players except for PowerDVD have no problem. (I just tested only MediaPlayerClassic and JetAudioPlayer.) I replay the DISC on both DVD player(TV) and software player(PC), so I wanted to solve. Quote:
Edit(Add) I read these threads before. http://forum.doom9.org/showthread.ph...265#post683265 http://forum.doom9.org/showthread.ph...457#post683457 And I can use time seekbar of PowerDVD5, now. Last edited by jinjin_jp; 5th February 2006 at 03:46. |
5th February 2006, 12:06 | #284 | Link |
PgcEdit daemon
Right! It's WinDVD that has problem with the seek bar.
Anyway, use Media Player Classic. It is good, powerful, free, and has a well designed interface, not one of those horrible and incpmprehensible skins!
5th February 2006, 12:34 | #285 | Link |
It was found to solve PowerDVD itself.
There is another method of jumping to title/chapter which is to select from DVD browser like below. This method seems to have no problem. Edit(Add) (1)About directly jumping to title/chapter, ___after jumping to chapter 1 of any titles, the problem is occured. ___after jumping to chapter 2,3,,, of any titles, the problem isn't occured. (2)By setting PUOs to check "title play(4)", ___after directly jumping to chapter 1 in same title, the problem is solved. Last edited by jinjin_jp; 5th February 2006 at 15:59. |
6th February 2006, 18:54 | #286 | Link |
i'm having an issue where my previews no longer auto-start when in trace mode.
i can click on the cell and issue CTRL+P and the preview will start. but if i use RUN from the beginning, no previews will come. i have clicked 'automatically start preview playback' and 'use preview' are checked under the preview menu. |
6th February 2006, 19:29 | #287 | Link |
PgcEdit daemon
You must tick also "Open Preview Automatically When Playing a Cell".
7th February 2006, 12:41 | #289 | Link |
An application error occurred in PgcEdit0.6.3.1
Nice to meet you.
An application error occurred in PgcEdit0.6.3.1 I did Ripping with an FILE mode of DVDDecrypter. I connect a title in NeroRecod2 and compress it. When it makes New 'Play All' Title in PgcEdit0.6.3.1, it is an application error. Error log. invalid command name "AddBCDtime" invalid command name "AddBCDtime" while executing "AddBCDtime [string range $thiscellpbentry 4 7] $totalpbtime" (procedure "::utils::create_playall_pgc" line 107) invoked from within "::utils::create_playall_pgc" (menu invoke) I deleted PgcEdit0.6.3.1 after uninstallation, and New 'Play All' Title was made when I tried it in PgcEdit0.6.2 again. 0.6.3.1 and 0.6.2 are default setup, respectively. Will any setting be necessary in PgcEdit0.6.3.1? Thank you for your consideration |
7th February 2006, 14:07 | #290 | Link | |||
Spielberger
I made a quick test with scenarist - if you define previous and nextpgcn pointing to the same PGC there is no VTS_TMAPTI written. If you create a second pgc in a title you cant have a VTS_TMAPTI too. Presuming scenarist complies with the specs. Last edited by bigotti5; 7th February 2006 at 14:22. |
7th February 2006, 14:28 | #291 | Link |
PgcEdit daemon
PgcEdit 0.6.4 beta 1
That's right, Butterfly. I have found this bug, too, and it is already fixed in 0.6.4beta1.
Thanks for the bug report anyway!
7th February 2006, 14:42 | #292 | Link | ||
PgcEdit daemon
BTW, I understand now why the "Title Play or Search" PUO is set in many PGCs of commercial DVDs. Anyway, I will change the DVDShrink plugin to hardcode the number of titlesets. Pitty! Quote:
IMO, it is normal to remove the VTS_TMAPTI when the title is a true non-sequential title, with several non-dummy PGCs. But setting the Prev/Next/GoUp PGCN pointing to itself does not change the structure of the PGC at all, so, IMO, it should still be considered as sequential. And even if there are additional dummy PGCs in the same TTN, since all cells are defined in the same PGC, it should work, too. Also, I've found that setting a link to itself is accepted w/o the time seek problem with all standalone players I've tested so far. Do you have an information in DVD Demystified on this subject?
7th February 2006, 15:20 | #293 | Link |
PgcEdit daemon
DVDShrink plugin v2.0 beta2
OK, done. The modified DVD Shrink plugin (v2.0 beta 2) can be found here.
Jinjin JP, it should work with the right-click method in PowerDVD. However, I have not changed the Prev/Next/GoUp PGCN links method. If it's really a problem, I might add a new cell at the very beginning of each PGC, and another one at the end so that it should be possible to use the prev and next buttons without the links. But I have no solution to enable the return button to go back to the prev title w/o adding a GoUp link. Someone has an idea?
7th February 2006, 15:52 | #295 | Link |
@r0lZ
Thanks very much for the new ver. of DVDShrink plugin. It functions fine even when using PowerDVD. About GoUp, do you mean anything instead of GoUp link? If so, there is introduced about method which goes back to the prev title when RootMenu button is pressed. It needs edit command one-by-one, compareed with one-click operation of PgcEdit's. In DVDShrink plugin v2.0 beta2, displayed "When the Title button is pressed...", is it "the Title Menu" like v1.4? |
7th February 2006, 16:02 | #296 | Link | ||||
Spielberger
found this in Ralph LaBarge - Dvd Authoring and Production Quote:
A next or prev PGC link is only valid within the same title and Scenarist does not write a time map if you define a next- and/or a prev PGC regardless if it is the same PGC. Think scenarist is very close to the spec. |
7th February 2006, 16:52 | #297 | Link |
PgcEdit daemon
Thanks again, bigotti5.
Seems there is no way to use the prev/next/goup links w/o loosing some functionalities of the player. Maybe I'll write a DVDShrink plugin 3.0 later, with complient methods only. @jinjin_jp: Yes, using the Root menu button is a solution. But I don't like it, since this button is not supposed to jump back to the previous title. "When the Title button is pressed..." means "When the Title Menu button is pressed...", of course.
7th February 2006, 22:54 | #298 | Link |
Country Member
My main bugbear with PowerDVD v6 is that you have to turn subtitles on through it's right click menu (or the keyboard shortcut). It does not respond to a menu which eventually selects a valid stream in SPRM2. Anyone else see this problem?
Regards
Les Only use genuine Verbatim or Taiyo Yuden media. |
8th February 2006, 01:38 | #300 | Link |
Behavior of "next chapter" within last chapter
As you can read in this thread, I'm annoyed that my DVDs created with DVD Lab Pro will jump to something if the Next Chapter button is pressed when it's already in the last chapter of a title. It jumps to the beginning of some title, having nothing to do with the presentation order of the titles in the main menu.
First, does anyone know for sure what is the correct standard behavior? If this is a quirk of my Samsung player, and not widespread, I won't worry about it. Standard or not, if it affects all Samsungs, then I need to deal with it. Someone had suggested using DVDRemake to disable the button while in the last chapter. So I came here to ask: can I do that with PgcEdit? I can see it shows me a table of chapters ("cells") for a title, but I don't see any way to edit prohibited operations within a cell (I found one that appears to be global). Any suggestions? --John |
