Old 13th March 2014, 23:01   #19561  |  Link
jdobbs
Working disk:
00001.mpls refers to 00001.m2ts with no IGS
Non-working disc:
00001.mpls refers to 00021.m2ts with IGS
Just to be clear, was the IGS listed as a part of that M2TS, or was it referenced through a subpath entry?
Website: www.jdobbs.net
Old 13th March 2014, 23:40   #19562  |  Link
Patrick
Playlists attached
Originally Posted by Patrick View Post
I just backed up Terminator Salvation (DC), where you can select the extended or theater version of the movie to watch. As a result, the movie is heavily fragmented, with different segments for either version. I found that BD rebuilder erroneously shortens the duration of at least playlist 00301 of the movie from 24 to 16 seconds, even though the converted segment itself has the correct length. As a result, the movie does not play correctly (skipping 8 seconds of the segment).
Additional information: that disc seems to be rather demanding as to its file structure - all videos seems to have (an empty) secondary video track. Maybe that is the reason for BD Rebuilder having problems? BTW: At least one other playlist ist also affected. My guess would be that running this disc would reveal all sorts of hard to uncover problems? Good stress test ;-)
I also added the playlists of the original and after processing the disc with BD Rebuilder. Note the differences in playlist 00002.mpls
Patrick is offline   Reply With Quote
Old 13th March 2014, 23:53   #19563  |  Link
mparade
It was likely an interlaced VC-1 file and you are using DirectshowSource(). Normally the viewer will simply open the M2TS directly and play back the source. But there are some VC-1 sources that DirectshowSource() can't handle directly from within an M2TS. In that case the only way to view them is to extract them, create an MKV, and play the MKV.
So I guess what I'm saying is that it isn't a bug, it's a feature. The only other alternative is to say "I can't view this". So it's an annoying feature -- but one that is necessary.
As for the encoding issue -- I'd have to know more. How long did you let it run? What mode was it in? Have you tried more than one mode (DirectshowSource & LAVF)?
I am using 1-pass CRF. When I saw that BD-RB had started an infinite encoding process right then I stopped it. (The time I let the program running could take just a few minutes). I have tried both DirectshowSource and LAVF...and the results of how the encoding has started were different:
Using DirectShowSource BD-RB tells after extracting the streams: Source Video: MPEG-4 (AVC), Rate/Length: 23,976fps, 1 frame for the source, started reencoding with two-pass method inspite of that I am in CRF mode (I think due to the small frame number), but the frame number in the last information row directly under the overall progress bar seems to be correct: 76321. ETA: seems to be correct here.
Using LAVF BD-RB tells after extracting the streams: Source Video: MPEG-4 (AVC), Rate/Length: 23,976fps, 1 frame for the source, started reencoding with two-pass method inspite of that I am in CRF mode (I think due to the small frame number), and the frame number in the last information row directly under the overall progress bar seems not to be correct and equal to 1 as it counted firstly.
Furthermore, with LAVF BD-RB seems to be getting into an infinite encoding cycle. This can be read after "Frames:" under the overall progress bar "frame number here keep growing during encoding/000001". And one more thing to mention here: it cannot be read clearly, but it seems that the percentage values close to the current and overall progress bars keep growing as well. I read at the ETA: 00:-09:-
mparade is offline   Reply With Quote
Old 14th March 2014, 00:11   #19564  |  Link
Sharc
Screenshot here.
Not sure whether this answers your question.
Old 14th March 2014, 13:16   #19565  |  Link
jdobbs
Screenshot here.
Ahhh... the issue is in the STN table...
Old 14th March 2014, 14:36   #19566  |  Link
Sharc
Yes! That's what I tried to describe here. I just didn't know the meaning and significance of the STN Table, but your Ahhh.. sounds promising....
Actually it seems that all files/playlists which have non-Zero values in either of IG, sV, sA, PIP in the STN table are non-playable. (The exception is just the one which refers to 99001.m2ts/99002.m2ts which has a "1" for IG)
Old 14th March 2014, 16:54   #19567  |  Link
Ch3vr0n
i don't know if its related, but i posted about that rerun i did 2nd job also lacked pip video for DGDecNV
Ch3vr0n is offline   Reply With Quote
Old 14th March 2014, 17:05   #19568  |  Link
jdobbs
I'm going to look at it more closely, but I think I may change the way Quick-Play works, and make it work more like an imported BD does. The more I look at it the more I see the possibility of problems.
Old 14th March 2014, 19:57   #19569  |  Link
Weirdo
One more CRF error. 2-pass works fine.
[03-14-14] BD Rebuilder v0.46.14 (beta)
[20:51:22] Source:
  - Input BD size: 5.67 GB
  - Approximate total content: [01:41:58.061]
  - Target BD size: 1.00 GB
  - Windows Version: 6.2 [9200]
  - RESIZE 1080p to 720p enabled
  - Quality: High Quality (Default), CRF
  - Decoding/Frame serving: DirectShow
  - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640
[20:51:22] PHASE ONE, Encoding
 - [20:51:22] Processing: VID_00003 (1 of 8)
 - [20:51:22] Extracting A/V streams [VID_00003]
 - [20:51:38] Reencoding video [VID_00003]
   - Rate/Length: 23.976fps, 2,477 frames
 - [20:51:38] Performing CRF Prediction...
   - Analyzing  - [20:51:38] PredictAndEncode() 00053  2810
[20:51:42] - Aborted by user request
[Status]
LABEL=
VERSION=v0.46.14 (beta)
SOURCE_SIZE=6091957635
SOURCE_VIDEO_SIZE=6087628800
TARGET_SIZE=1073741824
REDUCTION=.175669874779487
RESIZE_1080=-1
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
SSIF_MODE=0
QUICK=0
ENCODE_STEP=1.5
[00003]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=68431854
Weirdo is offline   Reply With Quote
Old 14th March 2014, 21:13   #19570  |  Link
Weirdo
The logs from the previous disc, completed in 2-pass. The audio is out of sync (seems the video is slowed down).
[21:00:28] Source:
  - Auto Quality: High Quality (Default), Two Pass
[21:00:28] PHASE ONE, Encoding
 - [21:00:28] Processing: VID_00003 (1 of 8)
 - [21:00:28] Extracting A/V streams [VID_00003]
 - [21:00:40] Reencoding video [VID_00003]
   - Bitrate: 3,254 Kbs
 - [21:00:40] Reencoding: VID_00003, Pass 1 of 2
 - [21:01:43] Reencoding: VID_00003, Pass 2 of 2
 - [21:04:15] Video Encode complete
 - [21:04:15] Processing audio tracks
 - [21:04:15] Multiplexing M2TS
 - [21:04:22] Processing: VID_00005 (2 of 8)
 - [21:04:22] Extracting A/V streams [VID_00005]
 - [21:04:29] Reencoding video [VID_00005]
   - Source Video: MPEG-2, 1920x1080
   - Rate/Length: 23.976fps, 240 frames
   - Convert: 1280x720, 23.976fps, 240 frames
   - Bitrate: 5,118 Kbs
 - [21:04:29] Reencoding: VID_00005, Pass 1 of 2
 - [21:04:35] Reencoding: VID_00005, Pass 2 of 2
 - [21:04:41] Video Encode complete
 - [21:04:41] Processing audio tracks
 - [21:04:41] Multiplexing M2TS
 - [21:04:47] Processing: VID_00007 (3 of 8)
 - [21:04:47] Extracting A/V streams [VID_00007]
 - [21:05:10] Reencoding video [VID_00007]
   - Source Video: MPEG-2, 720x480
   - Rate/Length: 29.970fps, 54,194 frames
   - Bitrate: 753 Kbs
 - [21:05:10] Reencoding: VID_00007, Pass 1 of 2
 - [21:09:58] Reencoding: VID_00007, Pass 2 of 2
 - [21:18:46] Video Encode complete
 - [21:18:46] Processing audio tracks
 - [21:18:46] Multiplexing M2TS
 - [21:18:55] Processing: VID_00008 (4 of 8)
 - [21:18:55] Extracting A/V streams [VID_00008]
 - [21:19:03] Reencoding video [VID_00008]
   - Rate/Length: 29.970fps, 5,329 frames
   - Bitrate: 1,024 Kbs
 - [21:19:03] Reencoding: VID_00008, Pass 1 of 2
 - [21:19:32] Reencoding: VID_00008, Pass 2 of 2
 - [21:20:28] Video Encode complete
 - [21:20:28] Processing audio tracks
 - [21:20:28] Multiplexing M2TS
 - [21:20:35] Processing: VID_00009 (5 of 8)
 - [21:20:35] Extracting A/V streams [VID_00009]
 - [21:22:14] Reencoding video [VID_00009]
   - Rate/Length: 29.970fps, 88,636 frames
   - Bitrate: 1,118 Kbs
 - [21:22:15] Reencoding: VID_00009, Pass 1 of 2
 - [21:30:24] Reencoding: VID_00009, Pass 2 of 2
 - [21:49:01] Video Encode complete
 - [21:49:01] Processing audio tracks
   - Track 4352 (eng): Reencoding audio to AC3...
 - [21:49:46] Multiplexing M2TS
 - [21:49:58] Processing: VID_00010 (6 of 8)
 - [21:49:58] Extracting A/V streams [VID_00010]
 - [21:50:06] Reencoding video [VID_00010]
   - Rate/Length: 29.970fps, 8,739 frames
   - Bitrate: 730 Kbs
 - [21:50:06] Reencoding: VID_00010, Pass 1 of 2
 - [21:51:08] Reencoding: VID_00010, Pass 2 of 2
 - [21:52:56] Video Encode complete
 - [21:52:56] Processing audio tracks
 - [21:52:56] Multiplexing M2TS
 - [21:53:03] Processing: VID_00011 (7 of 8)
 - [21:53:03] Extracting A/V streams [VID_00011]
 - [21:53:14] Reencoding video [VID_00011]
   - Rate/Length: 29.970fps, 19,688 frames
   - Bitrate: 742 Kbs
 - [21:53:14] Reencoding: VID_00011, Pass 1 of 2
 - [21:55:14] Reencoding: VID_00011, Pass 2 of 2
 - [21:58:57] Video Encode complete
 - [21:58:57] Processing audio tracks
 - [21:58:57] Multiplexing M2TS
 - [21:59:04] Processing: VID_00012 (8 of 8)
 - [21:59:04] Extracting A/V streams [VID_00012]
 - [21:59:16] Reencoding video [VID_00012]
   - Rate/Length: 23.976fps, 2,400 frames
   - Bitrate: 3,249 Kbs
 - [21:59:16] Reencoding: VID_00012, Pass 1 of 2
 - [22:00:35] Reencoding: VID_00012, Pass 2 of 2
 - [22:03:42] Video Encode complete
 - [22:03:42] Processing audio tracks
 - [22:03:42] Multiplexing M2TS
[22:03:49]PHASE ONE complete
[22:03:49]PHASE TWO - Rebuild Started
 - [22:03:49] Rebuilding BD file Structure
[22:03:49] - Encode and Rebuild complete
 - WORKFILES folder removed.
[22:03:50] JOB:  finished.
[Status]
LABEL=
RESIZE_1080=-1
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
SSIF_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=8
REBUILD_COMPLETE=1
[00003]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
RATE=3254
SPLITS=1
NSIZE=68868096
FLINK=-1
MLINK=-1
[00005]
AUDIO=
PGS=
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=6888193
RATE=5118
SPLITS=1
NSTART=27000000
NEND=27450450
NSIZE=1726464
FLINK=0
MLINK=0
[00007]
AUDIO=1
PGS=
MSCAN=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=233778704
RATE=753
SPLITS=1
NSTART=27000000
NEND=108372289
NSIZE=249759744
FLINK=0
MLINK=0
[00008]
AUDIO=1
PGS=
MSCAN=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=29486905
RATE=1024
SPLITS=1
NSTART=27000000
NEND=35001493
NSIZE=30830592
FLINK=0
MLINK=0
[00009]
AUDIO=1
PGS=
MSCAN=2
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=543750620
RATE=1118
SPLITS=1
NSTART=27000000
NEND=160086951
NSIZE=549341184
FLINK=0
MLINK=0
[00010]
AUDIO=1
PGS=
MSCAN=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=36804666
RATE=730
SPLITS=1
NSTART=27000000
NEND=40121608
NSIZE=39395328
FLINK=0
MLINK=0
[00011]
AUDIO=1
PGS=
MSCAN=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=84034442
RATE=742
SPLITS=1
NSTART=27000000
NEND=56561531
NSIZE=89720832
FLINK=0
MLINK=0
[00012]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=66237605
RATE=3249
SPLITS=1
NSIZE=66668544
FLINK=-1
MLINK=-1
Old 14th March 2014, 21:31   #19571  |  Link
jdobbs
Is there a reason why the source name is missing from the log?
Old 14th March 2014, 21:45   #19572  |  Link
Weirdo
I removed it. Silent Running, though it's been modified with Clown_BD BD Copier. Main title removed, menus and everything else untouched. Disc plays ok on various players.
Old 14th March 2014, 22:10   #19573  |  Link
jdobbs
Sorry. But that is a preprocessed disc. I do not respond to reports on preprocessed discs. There's no way to tell what has happened to the disc before BD-RB encounters it. In my experience virtually all problems reported under these circumstances have gone away when reverting to the original.
Old 16th March 2014, 17:37   #19574  |  Link
TobiMan
I am trying to reencode Wall Street: Money never sleeps to a mkv-container, but as soon as the encoding starts, BD-Rebuilder aborts.
Here is what I tried until now:
- reinstalled all BD-Rebuilder stuff
- ripped the source on two different drives
- tried to process directly from the bluray disc without ripping
- used ffdshow or lavf for decoding
Here is the log:
[03.16.14] BD Rebuilder v0.46.14 (beta)
[13:39:58] Source:  WALL_STREET_2_00500
  - Input BD size: 29,61 GB
  - Approximate total content: [02:12:58.428]
  - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled
  - Mode: MKV Container, 1920x1080, 640Kbs DD5.1
  - Decoding/Frame serving: X264/LAVF
  - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640
  - Audio [5] set to default.
[13:40:02] PHASE ONE, Encoding
 - [13:40:02] Processing: VID_00800 (1 of 1)
 - [13:40:02] Extracting A/V streams [VID_00800]
 - [13:55:30] Reencoding video [VID_00800]
   - Rate/Length: 23,976fps, 191.291 frames
   - Bitrate: 7.131 Kbs
 - [13:55:30] Reencoding: VID_00800, Pass 1 of 2
  - Encode failed.  Aborting.
  - BD-Rebuilder v0.46.14 (beta)
  - Working Path Free Space: 282,61GB
  - AVISYNTH Version: 2.5.8.0, Ok
  - HAALI Splitter: 1.9.42.1, Ok
  - FFDSHOW: 4504, Ok
  - FFDSHOW VC-1 set to "wmv9", Ok
  - FFDSHOW MPEG2 set to "libavcodec":  Ok
  - FFDSHOW AVC set to "libavcodec":  Ok
  - AnyDVD settings check: Ok.
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[13:55:33] - Failed video encode, aborted
So my guess would be that x264 maybe has an issue. Is there a log of x264 to look in? My machine is not overclocked by the way.
Thanks for any help
Tobi
TobiMan is offline   Reply With Quote
Old 16th March 2014, 22:10   #19575  |  Link
Sharc
Originally Posted by TobiMan View Post
Here is the log:
  - FFDSHOW: 4504, Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
Thanks for any help
Tobi
Can you play the VID_xxxxx.avs script in the WORKFILES folder in e.g. MPC-HC?
Does this problem only happen with this disc?
If you suspect x264.exe you could exchange it by an older version just to try.
Old 17th March 2014, 18:22   #19576  |  Link
TobiMan
Hi Sharc
thanks for helping.
Playing the avs-file in MPC-HC displays the following error:
The first German line translates as follows (roughly...): an external component has caused an exception.
Here is the content of the avs-file:
#Created by BD Rebuilder - v0.46.14 (beta)
DirectshowSource("Z:\BDMV\STREAM\00800.m2ts", fps=23.976, framecount=191291, audio=false)
LoadPlugin("C:\Program Files (x86)\Multimedia\Codecs\SupTitle\SupTitle.dll")
SupTitle("D:\TEMP\BD_REBUILDER\WORKFILES\00800.track_9999.sup")
ConvertToYV12().AssumeFPS(24000,1001)
So something seems to be wrong concerning the subtitles. I deinstalled xy-subfilter to make sure it is not invoking the issue, but that did not help.
Any other ideas?
Edit: Got it... should have looked at line 3 too, silly me :-). Somehow suptitle kicked in, also I did not check the appropriate box. Nevertheless, I removed the path information from the BD-Rebuilder .ini file and everything is good!
Thanks for putting me in the right direction!
Old 17th March 2014, 19:00   #19577  |  Link
mparade
[03.17.14] BD Rebuilder v0.46.14 (beta)
[07:41:19] Source:  BAD_TEACHER
  - Input BD size: 41,37 GB
  - Approximate total content: [02:55:36.315]
  - Target BD size: 46,26 GB
  - Windows Version: 6.1 [7601]
  - MOVIE and MENUS mode enabled
  - Quality: Highest (Very Slow), CRF
[07:41:27] PHASE ONE, Encoding
  - [07:55:26] Processing: VID_00466 (90 of 172)
 - [07:55:26] Extracting A/V streams [VID_00466]
 - [07:55:34] Reencoding video [VID_00466]
   - Rate/Length: 23,976fps, 3*073 frames
 - [07:55:34] Encoding using constant rate factor.
 - [07:59:05] Video Encode complete
 - [07:59:05] Processing audio tracks
 - [07:59:05] Multiplexing M2TS
 - [07:59:11] Processing: VID_00467 (91 of 172)
 - [07:59:12] Extracting A/V streams [VID_00467]
 - [07:59:23] Reencoding video [VID_00467]
   - Rate/Length: 23,976fps, 5*161 frames
 - [07:59:23] Encoding using constant rate factor.
 - [08:05:39] Video Encode complete
 - [08:05:39] Processing audio tracks
 - [08:05:39] Multiplexing M2TS
 - [08:05:48] Processing: VID_00468 (92 of 172)
 - [08:05:48] Extracting A/V streams [VID_00468]
 - [08:06:00] Reencoding video [VID_00468]
   - Rate/Length: 23,976fps, 5*859 frames
 - [08:06:00] Encoding using constant rate factor.
 - [08:13:21] Video Encode complete
 - [08:13:21] Processing audio tracks
 - [08:13:21] Multiplexing M2TS
 - [08:13:28] Blanking: VID_00524 (93 of 172)
 - [08:13:29] Blanking: VID_00525 (94 of 172)
 - [08:13:29] Blanking: VID_00526 (95 of 172)
 - [08:13:29] Processing: VID_00800 (96 of 172)
 - [08:13:29] Extracting A/V streams [VID_00800]
 - [08:17:43] Reencoding video [VID_00800]
   - Rate/Length: 23,976fps, 140*448 frames
 - [08:17:44] Encoding using constant rate factor.
 - [11:02:34] Video Encode complete
 - [11:02:34] Processing audio tracks
   - Track 4356 (hun): Keeping original audio
 - [11:02:34] Multiplexing M2TS
 - [11:08:38] Processing: VID_00801 (97 of 172)
 - [11:08:38] Extracting A/V streams [VID_00801]
 - [11:08:45] Reencoding video [VID_00801]
   - Rate/Length: 23,976fps, 1*829 frames
 - [11:08:45] Encoding using constant rate factor.
 - [11:10:51] Video Encode complete
 - [11:10:51] Processing audio tracks
 - [11:10:51] Multiplexing M2TS
 - [11:10:56] Processing: VID_00802 (98 of 172)
 - [11:10:56] Extracting A/V streams [VID_00802]
 - [11:11:03] Reencoding video [VID_00802]
   - Rate/Length: 23,976fps, 1*782 frames
 - [11:11:03] Encoding using constant rate factor.
 - [11:13:01] Video Encode complete
 - [11:13:01] Processing audio tracks
 - [11:13:01] Multiplexing M2TS
 - [11:13:06] Processing: VID_00803 (99 of 172)
 - [11:13:06] Extracting A/V streams [VID_00803]
 - [11:13:13] Reencoding video [VID_00803]
   - Rate/Length: 23,976fps, 1*925 frames
 - [11:13:13] Encoding using constant rate factor.
 - [11:15:33] Video Encode complete
 - [11:15:33] Processing audio tracks
 - [11:15:33] Multiplexing M2TS
 - [11:15:39] Processing: VID_00804 (100 of 172)
 - [11:15:39] Extracting A/V streams [VID_00804]
 - [11:15:46] Reencoding video [VID_00804]
   - Rate/Length: 23,976fps, 2*291 frames
 - [11:15:46] Encoding using constant rate factor.
 - [11:18:19] Video Encode complete
 - [11:18:19] Processing audio tracks
 - [11:18:19] Multiplexing M2TS
 - [11:18:24] Processing: VID_00805 (101 of 172)
 - [11:18:24] Extracting A/V streams [VID_00805]
 - [11:18:31] Reencoding video [VID_00805]
   - Rate/Length: 23,976fps, 1*794 frames
 - [11:18:31] Encoding using constant rate factor.
 - [11:20:37] Video Encode complete
 - [11:20:37] Processing audio tracks
 - [11:20:37] Multiplexing M2TS
 - [11:20:42] Processing: VID_00806 (102 of 172)
 - [11:20:42] Extracting A/V streams [VID_00806]
 - [11:20:48] Reencoding video [VID_00806]
   - Rate/Length: 23,976fps, 1*225 frames
 - [11:20:48] Encoding using constant rate factor.
 - [11:22:04] Video Encode complete
 - [11:22:04] Processing audio tracks
 - [11:22:04] Multiplexing M2TS
 - [11:22:09] Processing: VID_00807 (103 of 172)
 - [11:22:09] Extracting A/V streams [VID_00807]
 - [11:22:15] Reencoding video [VID_00807]
   - Rate/Length: 23,976fps, 1*617 frames
 - [11:22:15] Encoding using constant rate factor.
 - [11:23:51] Video Encode complete
 - [11:23:52] Processing audio tracks
 - [11:23:52] Multiplexing M2TS
 - [11:23:57] Processing: VID_00808 (104 of 172)
 - [11:23:57] Extracting A/V streams [VID_00808]
 - [11:24:03] Reencoding video [VID_00808]
   - Rate/Length: 23,976fps, 1*633 frames
 - [11:24:03] Encoding using constant rate factor.
 - [11:25:41] Video Encode complete
 - [11:25:41] Processing audio tracks
 - [11:25:41] Multiplexing M2TS
 - [11:25:46] Processing: VID_00809 (105 of 172)
 - [11:25:46] Extracting A/V streams [VID_00809]
 - [11:25:52] Reencoding video [VID_00809]
   - Rate/Length: 23,976fps, 1*673 frames
 - [11:25:52] Encoding using constant rate factor.
 - [11:27:49] Video Encode complete
 - [11:27:49] Processing audio tracks
 - [11:27:49] Multiplexing M2TS
 - [11:27:54] Processing: VID_00810 (106 of 172)
 - [11:27:54] Extracting A/V streams [VID_00810]
 - [11:28:00] Reencoding video [VID_00810]
   - Rate/Length: 23,976fps, 1*624 frames
 - [11:28:00] Encoding using constant rate factor.
 - [11:29:42] Video Encode complete
 - [11:29:42] Processing audio tracks
 - [11:29:42] Multiplexing M2TS
 - [11:29:47] Processing: VID_00811 (107 of 172)
 - [11:29:47] Extracting A/V streams [VID_00811]
 - [11:29:53] Reencoding video [VID_00811]
   - Rate/Length: 23,976fps, 915 frames
 - [11:29:53] Encoding using constant rate factor.
 - [11:30:49] Video Encode complete
 - [11:30:49] Processing audio tracks
 - [11:30:49] Multiplexing M2TS
 - [11:30:53] Processing: VID_00812 (108 of 172)
 - [11:30:53] Extracting A/V streams [VID_00812]
 - [11:30:59] Reencoding video [VID_00812]
   - Rate/Length: 23,976fps, 1*430 frames
 - [11:30:59] Encoding using constant rate factor.
 - [11:32:31] Video Encode complete
 - [11:32:31] Processing audio tracks
 - [11:32:31] Multiplexing M2TS
 - [11:32:36] Processing: VID_00817 (109 of 172)
 - [11:32:36] Extracting A/V streams [VID_00817]
 - [11:32:50] Reencoding video [VID_00817]
   - Rate/Length: 23,976fps, 7*153 frames
 - [11:32:50] Encoding using constant rate factor.
 - [11:40:42] Video Encode complete
 - [11:40:42] Processing audio tracks
 - [11:40:42] Multiplexing M2TS
 - [11:40:50] Processing: VID_00818 (110 of 172)
 - [11:40:50] Extracting A/V streams [VID_00818]
 - [11:40:58] Reencoding video [VID_00818]
   - Rate/Length: 23,976fps, 2*257 frames
 - [11:40:58] Encoding using constant rate factor.
 - [11:43:30] Video Encode complete
 - [11:43:30] Processing audio tracks
 - [11:43:30] Multiplexing M2TS
 - [11:43:35] Processing: VID_00819 (111 of 172)
 - [11:43:35] Extracting A/V streams [VID_00819]
 - [11:43:41] Reencoding video [VID_00819]
   - Rate/Length: 23,976fps, 1*081 frames
 - [11:43:41] Encoding using constant rate factor.
 - [11:44:47] Video Encode complete
 - [11:44:47] Processing audio tracks
 - [11:44:47] Multiplexing M2TS
 - [11:44:52] Processing: VID_00820 (112 of 172)
 - [11:44:52] Extracting A/V streams [VID_00820]
 - [11:44:57] Reencoding video [VID_00820]
   - Rate/Length: 23,976fps, 841 frames
 - [11:44:57] Encoding using constant rate factor.
 - [11:45:44] Video Encode complete
 - [11:45:44] Processing audio tracks
 - [11:45:44] Multiplexing M2TS
 - [11:45:49] Processing: VID_00821 (113 of 172)
 - [11:45:49] Extracting A/V streams [VID_00821]
 - [11:45:54] Reencoding video [VID_00821]
 - [11:45:55] Encoding using constant rate factor.
 - [11:47:13] Video Encode complete
 - [11:47:13] Processing audio tracks
 - [11:47:13] Multiplexing M2TS
 - [11:47:18] Processing: VID_00822 (114 of 172)
 - [11:47:18] Extracting A/V streams [VID_00822]
 - [11:47:22] Reencoding video [VID_00822]
   - Rate/Length: 23,976fps, 193 frames
   - Bitrate: 5*620 Kbs
 - [11:47:22] Reencoding: VID_00822, Pass 1 of 2
 - [11:47:23] Reencoding: VID_00822, Pass 2 of 2
 - [11:47:25] Video Encode complete
 - [11:47:25] Processing audio tracks
 - [11:47:25] Multiplexing M2TS
 - [11:47:29] Processing: VID_00823 (115 of 172)
 - [11:47:29] Extracting A/V streams [VID_00823]
 - [11:47:35] Reencoding video [VID_00823]
   - Rate/Length: 23,976fps, 1*849 frames
 - [11:47:35] Encoding using constant rate factor.
 - [11:49:50] Video Encode complete
 - [11:49:50] Processing audio tracks
 - [11:49:50] Multiplexing M2TS
 - [11:49:55] Processing: VID_00824 (116 of 172)
 - [11:49:55] Extracting A/V streams [VID_00824]
 - [11:50:03] Reencoding video [VID_00824]
   - Rate/Length: 23,976fps, 2*377 frames
 - [11:50:03] Encoding using constant rate factor.
 - [11:52:35] Video Encode complete
 - [11:52:35] Processing audio tracks
 - [11:52:35] Multiplexing M2TS
 - [11:52:40] Processing: VID_00825 (117 of 172)
 - [11:52:40] Extracting A/V streams [VID_00825]
 - [11:52:46] Reencoding video [VID_00825]
   - Rate/Length: 23,976fps, 625 frames
 - [11:52:46] Encoding using constant rate factor.
 - [11:53:22] Video Encode complete
 - [11:53:22] Processing audio tracks
 - [11:53:22] Multiplexing M2TS
 - [11:53:27] Processing: VID_00826 (118 of 172)
 - [11:53:27] Extracting A/V streams [VID_00826]
 - [11:53:32] Reencoding video [VID_00826]
   - Rate/Length: 23,976fps, 865 frames
 - [11:53:32] Encoding using constant rate factor.
 - [11:54:24] Video Encode complete
 - [11:54:24] Processing audio tracks
 - [11:54:24] Multiplexing M2TS
 - [11:54:28] Processing: VID_00827 (119 of 172)
 - [11:54:28] Extracting A/V streams [VID_00827]
 - [11:54:34] Reencoding video [VID_00827]
   - Rate/Length: 23,976fps, 1*297 frames
 - [11:54:34] Encoding using constant rate factor.
 - [11:56:03] Video Encode complete
 - [11:56:03] Processing audio tracks
 - [11:56:03] Multiplexing M2TS
 - [11:56:08] Processing: VID_00828 (120 of 172)
 - [11:56:08] Extracting A/V streams [VID_00828]
 - [11:56:13] Reencoding video [VID_00828]
   - Rate/Length: 23,976fps, 1*057 frames
 - [11:56:13] Encoding using constant rate factor.
 - [11:57:37] Video Encode complete
 - [11:57:37] Processing audio tracks
 - [11:57:37] Multiplexing M2TS
 - [11:57:42] Processing: VID_00865 (147 of 172)
 - [11:57:42] Extracting A/V streams [VID_00865]
 - [11:57:46] Reencoding video [VID_00865]
   - Rate/Length: 23,976fps, 89 frames
   - Bitrate: 19*834 Kbs
 - [11:57:46] Reencoding: VID_00865, Pass 1 of 2
 - [11:57:48] Reencoding: VID_00865, Pass 2 of 2
 - [11:57:53] Video Encode complete
 - [11:57:53] Processing audio tracks
 - [11:57:53] Multiplexing M2TS
 - [11:57:57] Processing: VID_00866 (148 of 172)
 - [11:57:57] Extracting A/V streams [VID_00866]
 - [11:58:01] Reencoding video [VID_00866]
   - Rate/Length: 23,976fps, 1*053 frames
 - [11:58:02] Encoding using constant rate factor.
  - Working Path Free Space: 89,11GB
  - FFDSHOW: 4504, Ok
  - WIN7 preferred AVC CODEC:  Ok
  - WIN7 preferred VC-1 CODEC:  Ok
  - WIN7 preferred MPEG2 CODEC:  Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[11:58:03] - Failed video encode, aborted
If someone could help, it would be really appreciated.
Old 17th March 2014, 19:25   #19578  |  Link
Sharc
Try to open and play VID_00866.AVS which is in the WORKFILES folder in MPC-HC or VirtualDub.
Does it play?
Old 17th March 2014, 19:44   #19579  |  Link
mparade
Does it play?
First time it was being played back (just 3 frames included according to virtualdub). Second time Virtualdub error window: "DirectShowSource: couldn't open file..."and it refers to a 00866.mkv file which is not found by the system...
Edit: I am just trying DirectShowSource instead of LAVF.
I has solved the problem.
Old 19th March 2014, 04:37   #19580  |  Link
RobertM
Ran into a funny one today. Backing up 'Nebraska'. Everything processed well, but upon inspecting the result before burning there was no dialogue. There was some background music, in time with the video, but no voices and not much in the way of sound effects. I'm thinking it is because this movie has a DTS-HD 3.0 soundtrack, which is unusual these days. It sounded like it was just surround sound.
By default I have the 'Do not convert DTS to AC3' and 'Keep HD audio' options de-selected. So I ticked both of those options on and ran it again. Now the audio sounds fine.
Here's the log for the rebuild that yielded no dialogue:
[03/18/14] BD Rebuilder v0.46.05 (beta)
[09:20:27] Source:  NEBRASKA_00001
  - Input BD size: 33.58 GB
  - Approximate total content: [01:54:43.668]
  - Target BD size: 23.63 GB
  - MOVIE-ONLY mode enabled
  - Quality: High Quality (Default), Two Pass
  - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640
[09:20:29] PHASE ONE, Encoding
 - [09:20:29] Processing: VID_00351 (1 of 1)
 - [09:20:29] Extracting A/V streams [VID_00351]
 - [09:26:32] Reencoding video [VID_00351]
   - Rate/Length: 23.976fps, 165,043 frames
   - Bitrate: 26,565 Kbs
 - [09:26:32] Reencoding: VID_00351, Pass 1 of 2
 - [10:14:39] Reencoding: VID_00351, Pass 2 of 2
 - [12:49:23] Video Encode complete
 - [12:49:23] Processing audio tracks
[12:51:01]PHASE ONE complete
[12:51:01]PHASE TWO - Rebuild Started
 - [12:51:03] Rebuilding BD file Structure
[13:00:10] - Encode and Rebuild complete
[13:00:10] JOB: NEBRASKA finished.
RobertM is offline   Reply With Quote
