19th October 2005, 10:48 | #21 | Link |
Pig on the wing
My last encode ended up with buffer underflow warnings in DVD Maestro.
Here's the last log entries: Code:
intra matrix used 8 16 19 22 26 27 29 34 16 16 22 24 27 29 34 37 19 22 26 27 29 34 34 38 22 22 26 27 29 34 37 40 22 26 27 29 32 35 40 48 26 27 29 32 35 40 48 58 26 27 29 34 38 46 56 69 27 29 35 38 46 56 69 83 non-intra matrix used 16 17 18 19 20 21 22 23 17 18 19 20 21 22 23 24 18 19 20 21 22 23 24 25 19 20 21 22 23 24 26 27 20 21 22 23 25 26 27 28 21 22 23 24 26 27 28 30 22 23 24 26 27 28 30 31 23 24 25 27 28 30 31 33 nr. of gops: 10053 nr. of frames: 139500 nr. of I-frames: 10053 nr. of P-frames: 36609 nr. of B-frames: 92838 average quant (non linear): 4.612 VBV underflows detected: 6 VBV underflows fixed: 6 minimum bitrate: 193 maximum bitrate: 8492 average bitrate: 3364
19th October 2005, 21:45 | #22 | Link |
HCenc author
@Boulder
Strange, the log values show an easy encode with just a few VBV fixes and a max. bitrate which isn't that high. Have you also tried to author it with Muxman or IfoEdit? How does it look when the m2v is loaded into BitrateViewer or MPEG Stream Eye? |
20th October 2005, 10:00 | #23 | Link | |
Pig on the wing
This is the first time I've had such warnings and I've used 9000 as the maximum. Do you know any program that could tell me at what frame/GOP the underflows occur? I could check it on my picky Pioneer if it has a real effect.
And if the band you're in starts playing different tunes I'll see you on the dark side of the Moon... Last edited by Boulder; 20th October 2005 at 10:03. |
23rd October 2005, 17:33 | #24 | Link | |
interlace this!
green warnings from spruce are pretty safe to ignore - they don't translate to playback problems in my experience, though that fact is taken on faith because only the pedants like us will complain about occasionally stuttery playback... most people blame their equipment and forget about it (samsung owners are justified here...) i suspect spruce gives a green bitrate warning when the bitrate exceeds the flagged max bitrate, and gives a red warning when the bitrate exceeds the 10.02 mbps limit of DVD. i've not tried this, but it's possible that if you were to change the max bitrate set in the m2v, the warning would go away. also beware that BV free version reports too-low bitrates. you have to multiply them by 1.024 i believe.
sucking the life out of your videos since 2004 |
23rd October 2005, 17:46 | #25 | Link |
Pig on the wing
hank already found the problem with a little help from MuxMan's log file and a little util. It's not about exceeding the max bitrate, it's just a rare case of a couple of a bit too large frames not arriving on time. He said it'll be fixed in the next release.
I haven't tried whether my player will stutter at that point but it would have been a minor issue anyway.
26th October 2005, 21:07 | #26 | Link |
I am trying to frameserve from VirtualDub to AviSynth to encode with HC. The AVI loaded in VirtualDub is NTSC DV so it's 720x480 29.97fps. AviSynth script looks like this:
AVISource("enc.vdr") ConvertToYV12(interlaced=true) It works fine in HC 0.15A, but with the 0.16 test release it just exits as soon as I start it (no error message displayed, or if there is it exits so fast I can't see it). All settings were the same for both versions because I loaded them from the same INI. 0.16 works fine for normal AviSynth scripts where I'm not reading from a VirtualDub frameserver. Any ideas?
moitah.net Last edited by Moitah; 26th October 2005 at 21:11. |
26th October 2005, 23:08 | #27 | Link |
HCenc author
Some remarks here so the other thread will not be hijacked completely
@Carpo & Pasqui I think it's perfectly safe to use the latest HC016, IMHO it's the most stable version until now. It's just called a test version to see if the crashes which some people experience with HC015 are now gone. There will be an "official" release of it when it's finished, still working on 1 pass VBR. Before the official release there will be another test version which can do 1 pass VBR. Known bugs for HC016 (and all previous versions): - GOP/VOBU/pulldown issue reported by Xeno86, will be solved in the next release - VBV underflow reported by Boulder, working on that now @Moitah I never tested this but yes I can replicate it. HC015 finishes normal, HC016 just disappears immediate, frameserver reports 1 frame served Debugging time again... |
27th October 2005, 01:51 | #28 | Link | |
Narrator: And of course, with the birth of the artist came the inevitable afterbirth - the critic. (History of the World part 1) |
27th October 2005, 15:29 | #29 | Link | |
thats why i never used it in the test (of course i didnt know of those issues) but it was a case of just in case - and i never meant to knock your encoder as its a damn fine piece of kit to have - since my little test i been using HC15 non stop
The Internet: where men are men, women are men, and children are FBI Agents |
30th October 2005, 18:29 | #30 | Link |
Pig on the wing
It appears that HC doesn't like ffdshow's mjpeg decoding.
I've got a TV capture, captured with ffdshow mjpeg. I open it via AVISource so the infamous DirectShowSource can't be the culprit. When the script is opened, HC quits almost immediately leaving a zero byte length m2v file behind. EDIT: using DirectShowSource it works
And if the band you're in starts playing different tunes I'll see you on the dark side of the Moon... Last edited by Boulder; 31st October 2005 at 12:42. |
2nd November 2005, 23:17 | #32 | Link |
Hank315, thank you for an excellent encoder!
I'm happy to report that the current testrelease works with Wine in Linux, hits the specified average and peak bitrates and does it with excellent image quality and speed. My Pioneer standalone (which is quite strict about standard compliance) has no problems with the resulting bitstream. |
3rd November 2005, 00:31 | #34 | Link | |
Testeur de codecs
Why not adaptative ratio for bframe and for example I(q4)b(q4)b(q4)p(q4) in high motion part -> low ratio for high motion I(q4)b(q6)b(q6)p(q4) in low motion part -> high ratio for low motion You use low quant variability and for example I(q4)b(q4)b(q4)p(q4) in high motion part -> low ratio for high motion I(q3)b(q4)b(q4)p(q3) in low motion part -> high ratio for low motion with that PSNR and visual quality could be very better ... ???
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 |
7th November 2005, 07:04 | #35 | Link |
@hank315,
I've got some high-motion interlaced source which doesn't play well with any encoder but ProCoder. All other encoders yield blocky output. HC has the least blockiness. ProCoder shows no blocks. Would you be interested in some of this source? I could send you a minute or so of the original GOPs for testing along with Procoder and HC conversions. My motivation? I want to switch to only using HC and provide you whatever support I can for your baby to be more capable.
Reclusive fart. Collecting Military, Trains, Cooking, Woodworking, Fighting Illini, Auburn Tigers |
7th November 2005, 22:59 | #37 | Link | ||
HCenc author
@Sagittaire
high motion: IBPBPBPB... normal motion: IBBPBBPBB... (very) low motion: IBBBPBBBPBBB... In your blind test I noticed that for the HC encoding a fixed GOP was used. A variable GOP scheme is DVD compliant, also Mencoder and CCE do it. Mencoder uses very short GOPs on fades, CCE uses 2 or more consecutive P frames in low action scenes. For HC the quant variability ATM is more based on bitrate than low/high motion, but maybe some tweaks with respect to motion could raise quality. Quote:
8th November 2005, 01:04 | #38 | Link | ||
from http://www.mpeg2.de/doc/dvd/book_b/video.htm Quote:
8th November 2005, 03:45 | #40 | Link | |
Testeur de codecs
adaptative Bframe number is compliant with DVD MP@ML ... ???
IPPPBPBBPBBPPP for example ... ??? In this case quality with Mencoder could be very better ... lol Quote:
