1st October 2012, 22:26 | #12242 | Link |
Not to question LAV video but I'm not sure if the primaries being signaled to madVR are the correct ones. it says EBU/PAL for a 720 x 480 4:3 NTSC DVD and on another 720 x 480 16:9 NTSC DVD madVR stated primaries as BT.470 System M.
Are these correct? I'm don't know know about BT.470 System M but EBU/PAL is only used with PAL discs right? |
1st October 2012, 22:36 | #12243 | Link |
Whatever it says was set in the bitstream like this. The values are directly taken from the various specs, there isn't much room to go wrong.
2nd October 2012, 07:19 | #12244 | Link |
@dansrfe, if you think there's a bug with those DVDs, a sample of each would help. Personally, I like weird samples, so if you really have a DVD with BT.470 System M primaries, I wouldn't mind getting a sample in any case.
2nd October 2012, 11:10 | #12245 | Link | |
The Ogg splitter in MPC-HC uses MEDIATYPE_Text instead of MEDIATYPE_Subtitle, and for some reason the subtitle renderer behaves differently. I don't feel like working towards its brokenness here. I believe BE overrides the splitters decisions.
2nd October 2012, 11:14 | #12246 | Link | ||
MPC-HC Developer
@e1iminator I am using LAV filters in progdvb... Where you have problem?
2nd October 2012, 14:17 | #12247 | Link | |
I am using the build with with this being an option and have set to not override, also MPC-BE doesn't have a tick to enable the sub's. I also tested with MPC-HC with same issue.
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) |
2nd October 2012, 14:19 | #12248 | Link |
No All it's now is optionals - wait next release;
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
2nd October 2012, 14:22 | #12249 | Link | |
The format contains 4 null bytes for some reason, i guess i can trim those off if they cause issues for SRT.
2nd October 2012, 14:27 | #12250 | Link |
I have a problem with LAV Audio Decoder (Decoding AC3 at least). I am using it to send audo to ReClock (Not bitstreaming) and let ReClock reencode to AC3 output so I can match the display to the the audio stream. However I am getting distortion and the volume is louder than if I use ffdshow's audio decoder. If I use ffdshow to send the audio unmolested it's perfect. LAV seems to do something strange to the audio when sent as PCM. No. The mixer option is not ticked. I also tried outputting in various output formats in LAV like 16 and 32 floating point. 16bit integer etc gave better results but were still too loud and caused a slight pop. But 32bit floating point gives distortion.
2nd October 2012, 14:30 | #12251 | Link | |
EDIT: Thanks nev, working great now
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) Last edited by VipZ; 2nd October 2012 at 15:25. Reason: Fixed |
2nd October 2012, 15:02 | #12252 | Link |
@ kasper93
it would be nice if i could select lav splitter instead of elecard, microsoft or prog; i have problems using prog splitter with channels such as bloomberg and cnbc; video lags audio elecard and microsoft work perfectly... Last edited by e1iminator; 2nd October 2012 at 15:04. |
3rd October 2012, 07:24 | #12253 | Link | ||
nevcairiel
3rd October 2012, 10:20 | #12254 | Link |
QuickSync Decoder author
I've added support for (unencrypted) DVD decode long ago. Decryption was done within ffdshow. The problem is that I don't know how to determine when a menu frame has arrived. When a menu frame arrives, I should flush the HW decoder. libavcodec doesn't queue so many frames as the Intel implementation so it's not a problem there. In normal file playback, the splitter sends EndOfStream and NewSegment events to signal this, but in DVD it doesn't happen. It only sends BeginFlush and EndFlush on seeks and doesn't send any event when a menu appears.
I didn't kill the DVD playback feature, but it's off by default. Can be changed via the normal config interface.
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. |
3rd October 2012, 15:54 | #12255 | Link |
Nev, can you please share x86 LAVF build with fixed YADF deintelacing?
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
3rd October 2012, 16:38 | #12256 | Link |
A question on Dolby Pro Logic II in the Mixing tab. I thought this worked in two main modes, Music and Movie. Which one does LAV use? Also, would I be correct to assume it's impossible to implement Pro Logic IIx due to licensing fees etc.?
3rd October 2012, 17:43 | #12258 | Link |
Help me please i've got a problem: When i try to use [URL="http://forum.doom9.org/showthread.php?t=156191"]LAV video filters/URL with any x64 version of your mpc build(1.6.4.5855 (2f0eed8)) with Nvidia Driver 306.23WHQL(GeForce? 460) on Windows x64.
I cant activate CUVID acceleration and even CoreAVC cuda Doesnt work. But it work on [URL="http://www.xvidvideo.ru/component/docman/doc_download/9063-media-player-classic-homecinema-x64-1634992-without-installer.html"]standart mpc-hc build/URL it also worked with your mpc build on 301.42 Nvidia driver |
4th October 2012, 02:41 | #12259 | Link | |
The BT.470 System M primaries DVD has some weird characteristics that I've noticed about it. 1) If I play the DVD from the IFO file and then manually select the main movie Title or click Play movie from the dvd menu it shows BT.470 System M in madVR's OSD for the primaries [from upstream]. 2) If I play any of the VOB files directly I get SMPTE C from the [best guess]. That other DVD that I have shows EBU/PAL primaries [from upstream] regardless of whether I play the DVD from the menu/manually select the main movie title or if I go directly to one of the movie VOB files. Not sure what to make of the results or what is correct and what is not. |
4th October 2012, 09:32 | #12260 | Link | |
x86: http://files.1f0.de/lavf/LAVFilters-...5-ga6b7a05.zip x64: http://files.1f0.de/lavf/LAVFilters-...6b7a05-x64.zip
