24th July 2007, 17:33 | #1324 | Link |
Banned
bigmurph,
yeah, you cant just upgrade over what you got now in some cases...you have to go to control panel, remove everything from windows components as well having to do with media player and do a clean install with wmp11 final. this means you will need to UNdrm any of your current files that are protected, because you will be given new licenses when you reintall this latest WMP and napster that Fix2 DOES work with dont update, clean it out, and install fresh. that way you are guaranteed to have not only fresh IBX licenses that the new FairUse works with, but also all correct WMP file versions of ddl's etc... ::: milOtis |
29th July 2007, 21:31 | #1326 | Link | |
hey milotis, when i rolled back, i used one of your guides or someone elses on the Doom9 forums. I'm too lazy to search for it, but I think it was the same process you described here. Add/remove programs, then I deleted WMP11 and an additional 3-4 patches that the procedure described. I restarted many times, but I'm not sure if I did it right. At the end I went to the Napster site http://home.cfl.rr.com/privftp/?D=D and used Auto DRM-reset (which may have been stupid, but Fairuse wasn't working and my songs weren't playing either at that time-before FIX2 and mirakagi). I might try to do it again, but don't have time now. I would really like to be able to do this - and I thought I would have success like others (who are actually using WMP11 without rollback!) - without having to reformat XP. I have 1000+ songs right now and it would be a pain in the ass to go back and download them all again from Napster and then UNdrm them after a fresh install of windowsXP. ANy advice/links? Thanks |
29th July 2007, 21:33 | #1328 | Link | |
Found the procedure saved in my favorites. It was described in the doom9 forums somewhere, too. http://www.kensavage.com/index.php/a...dia-player-11/ |
2nd August 2007, 22:28 | #1333 | Link |
Never Grow Up !
13th August 2007, 18:06 | #1335 | Link | |
this was really in response to this thread: http://forum.doom9.org/showthread.php?t=128703 about something followed in the news about this phenomina. the thread asks about where fair use line lies. i'll try to edit it and repost the drm specific details. thanks, |
17th August 2007, 16:57 | #1339 | Link |
i'm having some trouble and am hoping someone can help.
I bought a video off amazon's unbox service and used the FairUse4WM_v13Fix-2 file that was posted here. I stripped the drm just fine and moved it over to my media pc and it worked just fine. Now I also bought 2 tv shows off unbox and used the same method as above, but this time the resulting video on the other pc is green and purple. you can see everything just fine, just it has those colors. anyone know how i can fix this, as it looks like some drm? is still in there. Thanks |
