Old 3rd September 2018, 20:51   #561  |  Link
Nastenka
Hi Asmodian,
First off, thanks for your preset configs which have helped me tremendously in tweaking my settings.
I had a few more questions, though. I have a 1080 Ti as well, but my screen resolution is only 1440p. I've gone through with hardware calibration and all, therefore I am looking to tweak your settings a little more since with less upscaling to be done, shouldn't there be some more hidden potential? Since my sources are quite good, I already changed a couple upscaling NGU AAs to NGU Sharp.
Also, are your presets more of a general use case or specific, like for Anime and such?
I'd appreciate any help.
Nastenka is offline   Reply With Quote
Old 3rd September 2018, 21:35   #562  |  Link
Asmodian
Watching 1080p at 1440p is actually harder than watching 1080p at 4K. For 4K you simply double it (with NGU) but with 1440p you have to downscale it afterwards. I do not think there is anything to improve for watching at 1440p.
My presets are intended to be general but I do want Anime to look good as part of that. I might chose different settings if I didn't need Anime to look good as well but it would not be very different (i.e. changing NGU AA to NGU Sharp).
madVR options explained
Old 24th October 2018, 20:14   #563  |  Link
UMNiK
Great guide, but I wonder if you could provide a simple table of viable settings for 720p\1080p content on a 1080p monitor, the most common scenario. It can be rather difficult to figure out which settings are completely superfluous in that case, and which algorithms aren't wasted. At the moment I'm just using all Lanczos 3 AR (LL, SL) with smooth motion if judder is detected and no extras. I assume any doubling/quadrupling is pointless, but are refinements/other algorithms? I appreciate that you have provided the settings.bin, but I'd much rather have a nice table to figure it out and have some choice myself.
UMNiK is offline   Reply With Quote
Old 22nd November 2018, 22:33   #564  |  Link
Olivier C.
this display is already calibrated: [BT.709, pure power curve, 2.20] This sets the current display characteristics. The gamut option affects the conversions used by madVR when playing video with different gamuts but the gamma options only have an effect when using the 'enable gamma processing' option in 'color & gamma'.
This is not totally true if HDR --> SDR conversion is used, at least with "tone map HDR using pixels shaders" option (I didn't tried other HDR options).
Olivier C. is offline   Reply With Quote
Old 22nd November 2018, 22:35   #565  |  Link
yes HDR-SDR it is inconsistent and you can get all kinds of gamma if it it used with gamma processing.
Old 22nd November 2018, 22:50   #566  |  Link
Olivier C.
I would to like to say that the gamma options have an effect even if the 'enable gamma processing' option in 'color & gamma' is not used at all, in case of HDR->SDR conversion
Old 22nd November 2018, 22:58   #567  |  Link
kind of but i still hope madshi makes it more transparent first.
Old 22nd November 2018, 23:09   #568  |  Link
Olivier C.
Thanks huhn
Old 5th December 2018, 02:56   #569  |  Link
Asmodian
Finally updated for madVR v0.92.17.
Thanks! I updated that description to reflect this.
Old 25th January 2019, 12:48   #570  |  Link
Ava Pug
The link for Max Quality settings.bin doesn't work.
Ava Pug is offline   Reply With Quote
Old 7th February 2019, 15:50   #571  |  Link
K3ka
Hello! Thank you for your guide.
Can you,please, reupload file with max quality settings?
K3ka is offline   Reply With Quote
Old 7th February 2019, 15:52   #572  |  Link
Asmodian
Sorry, I am currently traveling and do not have access to the file where I am.
Edit: it looks like the link changed when I updated for 0.92.17, it doesn't usually do that. I have updated the link.
