15th March 2012, 01:36 | #41 | Link |
Help Wanted
We have a new help-wanted wiki for interested developers here. Specifically:
15th March 2012, 06:48 | #43 | Link |
With regard to item2, Its probably expanding the brief too far but if a tool like Virtualdub was to be discussed then what about considering extending an actively developed and mature Linux based media toolkit called MLT. It uses ffmpeg, Frei0r etc and is also a playout server for broadcast.
http://www.mltframework.org/twiki/bin/view/MLT/ MLT is xml based and forms the base of a number of Linux NLEs including Kdenlive which is without doubt the most usable NLE on Linux at the current time. www.kdenlive.org Any extension of MLT can then be made accessible in kdenlive seperately by kdenlives active devs if need be. Or would a nodal based approach rather than Non Linear be more suitable. Last edited by Yellow_; 15th March 2012 at 09:36. |
15th March 2012, 07:09 | #44 | Link |
Avisynth Developer
Interesting development. Pity you chose 2.58 as a base instead of 2.6 ....... sigh
For exception handling there is already a catchable implementation through the IAvisynthClipInfo class, see Virtualdubs source for how to uses it. The painting of the error text is only a fallback in the VFW export stub (which almost everything else currently uses). Any app that uses the C or C++ API has to explicitly handle script and runtime errors, there is no text painting there. For ASM support the chosen solution is to use the Avisynth modified Softwire by Sh0dan. The Softwire in 2.6 has been adapted for 64bit, but it hasn't had much (any?) of a workout. It is hoped all future core development will use this instead if inline MSVC Asm. A thought to aid 64bit porting was to declare inbuilt register aliases like PAX, PBX, ... which would be EAX, EBX, ... in 32 bit and RAX, RBX, ... in 64 bit, this was envisioned to be a bit like the INTPTR type in C/C++ and would allow memory pointer arithmetic parts of the code to be 32/64 bit agnostic. The assumption being the 1st 64 bit cut would just be the 32 bit algorithm recut as 64bit. Enhanced versions in the future could take advantage of the extra registers and instructions to have faster versions, much like we have C++, MMX, iSSE and SSE2 versions of code now. Also on the 64 bit vapourware list is to have the Script AVSValue int and float types to be 64bit integers and doubles, as the 2 pointer types, clip and string, have to become 64 bit anyway. There was also some vague idea about borrowing some code from Wine to load windows .dll plugins in a Linux version. 90% of Avisynth plugins are pure algorithm code with no system calls, these would be a doddle to host in a Linux address space. |
15th March 2012, 17:45 | #45 | Link | ||||
15th March 2012, 20:19 | #46 | Link |
This is wonderful news, great work on the port! I'm not much when it comes to Linux, but after installing a pair of Ubuntu VMs (32/64 bit) and banging my head against KDev and CMake for a couple of days, I've gotten one of my plugins to compile and run, all with much less effort than I'd expected. I'm sure to have loads of capital-f Fun setting up a new build process that can properly handle both versions, but for the time being I have a few questions:
First, am I the only one having trouble when linking against ffms2 2.17? I downloaded the source from the googlecode project, and configured/built/installed it successfully, but when running AVXEdit and attempting to load a clip with FFVideoSource (or even just using ColorBars().KillAudio().PointResize(320,240)) I get an undefined symbol error with regard to GetSwsContext. Uninstalling 2.17 with Synaptic and replacing it with 2.16 (as delivered in the AvxSynth checkout), everything works as expected. This is hardly a proper bug report, but I don't want to be any more obnoxious than necessary, so I'm leaving out the details in case this is a known issue. Or if I've just missed something obvious. Which would be shocking. Next up is what I suppose is more a general freshman developer question than anything. I'd like to keep one set of source files for both versions of a plugin if possible; would it be incredibly stupid to #ifdef a "using namespace avxsynth" directive, or at least a set of "using avxsynth::SuchAndSuch" declarations in my source files? I understand those are dangerously poor form if they can be avoided, but they seem to be the cleanest way to handle cross platform concerns in this case. Is there a more intelligent way to handle the avxsynth namespace that I simply haven't learned of yet? My final concern is about source distribution. On Windows we all redistribute the copy of avisynth.h that we used to build our library; do we distribute avxplugin.h (and everything else in the avx_root/include/ directory) for Linux, or is it assumed everyone using the software has the source code installed? I know the Linux community is much more comfortable with downloading and building from source than most in the Windows world, but if I'm not mistaken it's possible and increasingly common to have binary releases even there. Am I correct in thinking that the avx_root/include/ directory (minus the .svn repository) is all I need to package along with my source? That's an annoying number of question marks for one post, and I know I'm revealing an embarrassing lack of experience in the *nix world here, but I'm supremely excited at the prospect of making my trivial toy plugins available to an even larger group of people who couldn't care less, so I'd like to clear up as many details as I can. |
15th March 2012, 21:58 | #47 | Link | ||
We would like to have a real install package so that you do not have to walk through these manual steps. Any volunteers out there? |
15th March 2012, 22:25 | #48 | Link | |
15th March 2012, 23:39 | #49 | Link | |
17th March 2012, 19:08 | #50 | Link |
hi
im having a problem when i try to play the script when i open AVXEdit and write a simple script, like this: Code:
ffvideosource("/path/to/my/file.mkv") |
18th March 2012, 00:07 | #51 | Link |
active1, do you have the ffms2avs plugin built in /home/.AVXSynth/plugins folder?
This may or may not help. http://forum.doom9.org/showthread.ph...47#post1564447 |
18th March 2012, 00:26 | #53 | Link | |
18th March 2012, 05:47 | #54 | Link |
can't reproduce luma scaling issue
I tried reproducing the luma scaling problem with h264 video inside m2ts using a clip from my camera, and I don't see the scaling (I displayed the histogram as well as dumped out the yuv and saw values > 235). Could you post your clip so I can test it on my machine? Maybe it's a difference in library versions.
18th March 2012, 07:43 | #55 | Link |
http://www.yellowspace.webspace.virg....com/Gold.aMOV
I mentioned earlier in the thread that the luma scaling was specific to ffms2 2.16 and fixed by The Fluff quite a while ago, maybe recent commits by the AVXSynth devs have bumped version to 2.17 and resolved the problem. I haven't built it again since the initial release to test but it was scaling, used ffms2 long enough to know. :-) Last edited by Yellow_; 18th March 2012 at 07:47. |
19th March 2012, 04:51 | #56 | Link | ||
/home/lab/AVXSynth/plugins/ffms2avs and it is contain : ffms2avs.kdev4 , libffms2avs.so , Makefile and two other folders : Prerequisites & src NOTE: i skipped three steps because i didn't know how to do them Code:
Create a .gdbinit in your home directory containing this text: (for 64-bit Ubuntu) set env LD_PRELOAD /lib/x86_64-linux-gnu/libpthread.so.0 (for 32-bit Ubuntu) set env LD_PRELOAD /lib/i386-linux-gnu/libpthread.so.0 This is a fix for the debugger hanging on dlopen) Quote:
20th March 2012, 00:55 | #58 | Link |
AvxSynth Pirate
Audio support is there
Hello to everyone on the forum from one of the committers (avxsynth@gmail.com)
Latest news: The support for audio functions is checked in. The following functions are supported: - Tone - FFAudioSource (***has been there already, can be used as audio source alongside with Tone function) - DelayAudio - AmplifydB - Amplify - AssumeSampleRate - Normalize - MixAudio - ResampleAudio - ConvertToMono - EnsureVBRMP3Sync (*** not tested) - MergeChannels - MonoToStereo - GetLeftChannel - GetRightChannel - GetChannel - GetChannels - KillVideo - KillAudio - ConvertAudioTo16bit - ConvertAudioTo8bit - ConvertAudioTo24bit - ConvertAudioTo32bit - ConvertAudioToFloat - ConvertAudio Remarks, comments, questions, suggestions...are more than welcome. |
20th March 2012, 01:05 | #59 | Link |
AvxSynth Pirate
Audio test scripts examples
Script1: Using tone:
---------------------------------------------------------------- #ErrorHandlingExternal clip0 = FFAudioSource(source="<path_to_your_media_file>") f1 = 2*261.6 f2 = 2*329.6 f3 = 2*392.0 f4 = 2*f1 clip1 = Tone(frequency=f1, samplerate=44100) clip2 = DelayAudio(Tone(frequency=f2, samplerate=44100), 1.0) clip3 = MixAudio(clip1, clip2) clip4 = DelayAudio(Tone(frequency=f3, samplerate=44100), 2.0) clip5 = MixAudio(clip3, clip4) clip6 = DelayAudio(Tone(frequency=f4, samplerate=44100), 3.0) clip7 = MixAudio(clip5, clip6) clip8 = MixAudio(clip0, clip7) # # use the line below to play sound at different sampling rates #AssumeSampleRate(clip8, 64000) ---------------------------------------------------------------- Script2: Another set of functions tested: ---------------------------------------------------------------- #ErrorHandlingExternal f1 = 2*261.6 f2 = 2*329.6 f3 = 2*392.0 f4 = 2*f1 clip1 = Tone(frequency=f1) clip2 = DelayAudio(Tone(frequency=f2), 1.0) clip3 = MergeChannels(clip1, clip2) clip4 = DelayAudio(Tone(frequency=f3), 2.0) clip5 = MergeChannels(clip3, clip4) clip6 = DelayAudio(Tone(frequency=f4), 3.0) clip7 = MergeChannels(clip5, clip6) clip8 = ConvertToMono(clip7) # # the result of the two functions below should be # unchanged audio volume # clip9 = AmplifydB(clip8, -30.0) Amplify(clip9, 31.62) ----------------------------------------------------------------- Script3: Illustrating proper downsampling (i.e. antialiasing) ---------------------------------------------------------------- #ErrorHandlingExternal clip0 = Tone(frequency=440) #clip0L = GetLeftChannel(clip0) clip0L = GetChannels(clip0, 1) clip1 = Tone(frequency=17000) #clip1R = GetRightChannel(clip1) clip1R = GetChannels(clip1, 2) clip2 = MergeChannels(clip0L, clip1R) clip3 = clip2 #ConvertAudioToFloat(clip2) clip4 = ResampleAudio(clip3, 32000) ConvertAudioTo16Bit(clip4) |
21st March 2012, 21:13 | #60 | Link | |
src=ffvideosource("/path/to/my/file.mkv") ShowSMPTE(src) |
