20th August 2009, 02:26 | #7861 | Link |
Seems like they are saying that Dolby Digital Decoding will be present in all Windows Operating systems. The reference decoder will ship with Windows 7.
Therefor Windows 7 users may not even need FFDShow for EAC3 decoding.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake? Curly: Burned at the stake! Moe: Why? Curly: A hot steak is always better than a cold chop. |
20th August 2009, 09:51 | #7863 | Link |
Media Control author
So far I have no answer from Microsoft on bitstream
http://social.msdn.microsoft.com/For...9-7a9b97ae7357 About revision 3056, a few details :
Today some commercial filters are able even on xp/vista to bitstream compressed formats to the HDMI output : totalmedia theatre sends TrueHD/DTSHD directly to the HDMI 1.3 output, requiring a asus xonar, but this requirement is only to ensure the protected audio path, otherwise technically it is possible to do it on any HDMI output. So either this feature is brought by the OS and can be implemented into ffdshow, or else a new audio renderer will be required I guess and/or a new audio driver Last edited by albain; 20th August 2009 at 11:19. |
20th August 2009, 12:54 | #7865 | Link |
aka XaS
If he's happy with MPC-HC, leave him alone, unless you know ffdshow-tryouts offers extra functionnalities he might want, without breaking MPC-HC's.
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS |
20th August 2009, 13:34 | #7866 | Link |
On a windows 7 system if MPC-HC will replace ffmpeg with ffmpeg-mt (for the non-DXVA files) and will add independent volume for each channel I'll say the same thing, cause for me Winows 7's (DXVA) filters are better then FFDShow's or MPC-HC'S
Intel UHD Graphics 750; Win 10 22H2 |
20th August 2009, 16:10 | #7867 | Link |
I disagree, I find DXVA decoding (sometimes) less good than software decoding (for example coreavc without cuda or some software mpeg2 decoders).
20th August 2009, 16:57 | #7869 | Link |
Hi!
I'm a longtime ffdshow and MPC user, and still use ffdshow, although MPC-HC can play almost anything now just like ffdshow. But the subtitle feature is much better in ffdshow with its heuristic search and additional options. Lately I noticed something. Some movies need volume normalising because of their loud explosions and almost silent voices. I used ffdshow for this, but it didn't help much. It is changing the volume, but only slightly. Voices still low, Explosions high. Regain volume was checked/unchecked, max. amplification changed. Than I tried MPC-HC normalise option and Wow, it did exactly what I wanted. Everything was normalised at the instant I checked the normalise option. Voices were audible, and explosions went down to the same level. The movie became watchable without constantly changing the volume on the remote. Is it possible to make an MPC-HC like normalisation? Maybe as a new option at the Volume tab. |
20th August 2009, 17:07 | #7870 | Link | |
At default settings, Volume should not alter the sound, so enable it when you want to see the volume levels.
MPC-HC 2.2.1 |
20th August 2009, 17:09 | #7871 | Link |
@ohmy
You probably have wrong speaker settings in ffdshow. Enable the 'Mixer' and set the correct amount of speakers.
MPC-HC 2.2.1 |
20th August 2009, 18:47 | #7874 | Link |
Here's a sample file for my volume normalization problem. It's a fake trailer to an upcoming movie grabbed from youtube:
http://rapidshare.com/files/269547376/safa.mp4.html I modified the first half of it, so the sound is very quiet (20%), and in the second half it changes back to normal. (100%) The sound change is at 0:54 While MPC-HC makes the volume level equal and sounds good, ffdshow seems to do almost nothing |
20th August 2009, 20:36 | #7876 | Link |
@Octo-puss
Simply disable the internal ones in MPC-HC. Options -> Internal Filters. @ohmy For me volume normalization works pretty good when using ffdshow. I don't recall any others who have troubles with it. Are you sure ffdshow is being used and not any of the internal decoder of MPC-HC?
MPC-HC 2.2.1 |
20th August 2009, 21:16 | #7877 | Link |
@clsid
I'm sure, it's not MPC-HC-s internal decoder. All the transform filters are unchecked, and the audio is also unchecked. If it is checked, the normalization is working The ffdshow audio icon is present while playing the file. The volume option is checked, and looking at the volume levels, it shows, that the first half is quieter, than the second half. In ffdshow audio the following are checked: normalize, regain volume. Master volume is set to 100%. Max. amplification set to 400%. And normalization is working, but it's not as strong as MPC-HC's. With only ffdshow there is an obvious volume change at 0:54. With MPC-HC, it can't be heard. OK, I tried with GOM player using FFdshow. It is doing the same thing. The sound gets much better, when I click GOM player's normalize option. ffdshow is at rev. 3054 |
20th August 2009, 22:34 | #7878 | Link | |
ffdshow/AviSynth wrangler
np: Billy Bragg - M For Me (Mr. Love & Justice (Solo Version))
now playing: [artist] - [track] ([album]) |
21st August 2009, 17:07 | #7880 | Link | |
np: Moonbeam - You Can Hear Them (100)
