Old 1st April 2020, 11:37   #281  |  Link
tebasuna51
tebasuna51's Avatar
Try now with SL-SR, or try to flac if your OPPO suport it.
Or maybe to flac 5.1 (the empty channels are compressed without size):
-af "pan=5.1(side)|FL < FL|FR < FR |FC < .0FR |LFE < .0FR |SL < BL |SR < BR"
Old 1st April 2020, 13:18   #282  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
So... I decided to start again using a smaller (470MB) '4-channel pcm.wav' audio file as a source', and: -
With this command line: -af "pan=5.0(side)|FL < FL|FR < FR |FC < .0FR |SL < BL |SR < BR", I hear no audio from the side channels on my OPPO.
However with command line: -af "pan=5.1(side)|FL < FL|FR < FR |FC < .0FR |LFE < .0FR |SL < BL |SR < BR", I hear audio from all the channels perfectly on my OPPO. So that's great.
But wait... There's more...
I re-encoded the original '4-channel pcm.wav' audio file to a '4-channel. flac' audio file, and the OPPO played all the channels perfectly too!
So I'm both happy and confused.
Old 1st April 2020, 16:54   #283  |  Link
SeeMoreDigital
Using the same '4-channel pcm.wav' file' as a source, I've just performed another test using this much shorter command line: -af "pan=5.1(side)". And it generated exactly the same result as this command line: -af "pan=5.1(side)|FL < FL|FR < FR |FC < .0FR |LFE < .0FR |SL < BL |SR < BR".
It's all like living in "The Matrix" stuff to me....
Old 1st April 2020, 19:03   #284  |  Link
tebasuna51
tebasuna51's Avatar
ffmpeg is always a surprise.
About flac: yes, the default channel layout for 4 channels is: front left, front right, back left, back right, then is correct with your source.
Old 1st April 2020, 19:29   #285  |  Link
SeeMoreDigital
It's certainly a weird one.
The 4-channel (quadraphonic) DVD-Audio disc plays fine in the OPPO. But the extracted '4-channel mlp/pcm.mlp' or '4-channel pcm.wav' files do not. But '4-channel flac.flac' files play fine.
Also, I've just discovered that '4-channel dts.mka' contained files play okay in the OPPO too...
Nothing is every straight forward is it
Old 5th April 2020, 18:14   #286  |  Link
jlw_4049
Anyway to scale the GUI larger/easier to read fonts?
jlw_4049 is offline   Reply With Quote
Old 5th April 2020, 18:25   #287  |  Link
SeeMoreDigital
Out of interest... What resolution display do you have?
Old 5th April 2020, 18:29   #288  |  Link
jlw_4049
I have a 1080p monitor. I can read the font easy but after long hours (my eye sight isn't perfect) it makes it rather difficult to read.
The program doesn't enlarge with the default windows DPI scalier. So I was hoping there was a way to adjust it in the programs .ini or something.
Old 6th April 2020, 11:11   #289  |  Link
tebasuna51
tebasuna51's Avatar
You have here a image sample in my 1080 display, I can't test diferent resolution or text size in screen configuration. BTW you have the source .au3 and autoit is free, modify the soft at your taste.
Old 6th April 2020, 17:17   #290  |  Link
jlw_4049
I don't see where to enlarge the screen size. This is way above my head :P
Old 19th April 2020, 10:04   #291  |  Link
tormento
Acid fr0g
tormento's Avatar
Do you mind use different folders for the needed programs?
I use MeGUI as standard repository for my encoders and I really don't like to put everything in eac3to folder or single folder whatsoever.
Thanks
@turment on Telegram
Old 19th April 2020, 11:23   #292  |  Link
tebasuna51
tebasuna51's Avatar
Maybe MeGUI can change their behavior to fit with foobar2000 and UsEac3to, and use a unique folder for audio encoders.
Remenber a path for any encoder is complex.
Old 20th April 2020, 14:26   #293  |  Link
Rumbah
Thanks
You could use symbolic links of your file system to set a link for the different files from the eac3to folder to your repository.
That way you could have your one tool source without any changes for any other programs you might want to use.
Rumbah is offline   Reply With Quote
Old 2nd May 2020, 10:02   #294  |  Link
tymoxa
@tebasuna51
Is possible to fix an error (Source file not found) that UsEac3to throws when PATH to input file(s) contains cyrillic symbols?
tymoxa is offline   Reply With Quote
Old 2nd May 2020, 11:19   #295  |  Link
tebasuna51
tebasuna51's Avatar
Sorry, many options in UsEac3to work by .cmd (or .bat) files with a special set of characters.
I have, inside UsEac3to, a translation between standard european character page to this special set, but I don't know how to make other translations.
In the download there are the autoit source, try to make this yourself.
Old 10th May 2020, 00:44   #296  |  Link
kdantas
Hi, sorry my noob question... how can I get the .log of the eac3to demux using UsEac3to Gui?
kdantas is offline   Reply With Quote
Old 10th May 2020, 00:52   #297  |  Link
tebasuna51
tebasuna51's Avatar
You can see the log in the main window, you can edit it, and you can save it with the 'Save Log' button in upper right corner ( in Input folder or Used Defined folder).
If you EnQueue the job the Save log is automatic.
Old 10th May 2020, 02:18   #298  |  Link
kdantas
Thanks @ tebasuna51, your information was perfect. One more question, for now, is it possible in the "Run and MkvMux" process to include the subtitles and chapters file?
Old 10th May 2020, 10:14   #299  |  Link
tebasuna51
tebasuna51's Avatar
If the source is a mkv the "Run and MkvMux" preserve video, subs and chapters, only audio (1 or 2 tracks) are modified with the changed by eac3to.
If you need modify subs you need run MkvMuxer separately.
"Run and MkvMux" is ussefull for some audio recode (DTS to AC3 or AAC) for play in devices without DTS decode support.
Old 10th May 2020, 13:06   #300  |  Link
kdantas
But, using "Run and MkvMux" after the files are demuxed by eac3to, doesn't mkvmerge use these files to create the .mkv file? In my mind, the source would be the files that eac3to extracts from blu-ray, in my case. Or am I wrong in that thought?
