9th January 2006, 14:43 | #1101 | Link | |
clueless n00b
So let me say it once and for all: for the x264 configuration dialog, if an option is not to be accessible, it keeps its current value, but it's disabled. The rest is done in the x264TristateAdjustment method in the CommandlineGenerator class. It's rather frustrating for me to having spent hours to get this darned thing working only to have it broken again by somebody else
9th January 2006, 16:07 | #1102 | Link |
Mr. Sandman
i think the behaviour was modified when the whole tri-state was rewritten.
i've a local copy of the old method. i can restore it in few minutes (i'll do it tonight).
9th January 2006, 17:12 | #1103 | Link |
berrinam, go ahead and put me down for the following, since I already know the MP4 muxer and commandlinegenerator code from my work on track names.
Add support for the -sbr or -sbrx tags in mp4box commandline Description: Add a checkbox in MeGUI MP4 Muxer which says something like "AAC is SBR", so that the audio information is correctly stored in MP4 Status : No-one is working on it |
9th January 2006, 17:31 | #1104 | Link | |
clueless n00b
9th January 2006, 18:04 | #1105 | Link | |
developer wannabe
9th January 2006, 18:20 | #1106 | Link | |
9th January 2006, 20:54 | #1107 | Link | |
9th January 2006, 21:18 | #1108 | Link | |
clueless n00b
10th January 2006, 00:06 | #1109 | Link | |
10th January 2006, 13:04 | #1112 | Link |
BeHappy/MeGUI developer
My opinion!
@all dev's
Hi! I was @ new year vacation and I spend this time with my family mostly far from PC. But I found time to take closer look @ MeGUI sources. And I'm frustrating now! I found some amount of non-optimal code architecture, including annoyng copy/paste programming paradigm... It's a really not good! I really don't understand some decisions in it! Take look @ audio-related staff. Why all configuration forms are created by copy/paste metodology? Hey, forms is objects and you can still use inheritance/poliphormysm with it! I really don't understand why does You use ugly ENUM<->Int casting, why not just use enums? In other case I don't understand unnecesarry using of "Property Paradigm": Code:
int someProperty; public int SomeProperty { get{return someProperty;} set{somePropert=value;} } Code:
public int SomeProperty; I believe we must stop implementing any additional features until full code review and refactoring!
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
10th January 2006, 13:21 | #1113 | Link |
clueless n00b
1) Forms: Please feel free to lay down a good foundation for GUI inheritance.. I only have limited experience with it, hence I implemented them all as separate forms but I do agree that it would make more sense and be easier to maintain to have basis forms and forms that derive from it. The same obviously also goes for the video config, muxer and settings forms. So when you start working at the audio, please do lay the groundwork for a major improvement in this area.
2) enums <-> ints... once again plain ugly and my fault.. I'm just not sure if you can bind enums to dropdowns.. I guess that's why I started with ints, then figured for code maintainability it would be better if the names of the options were spelled out, hence the enums. You'll see that in more recent codes, there are no such conversions anymore and I'm using the enums directly, as it should be. Once again, if you start working on the audio, please feel free to change that. 3) There however I have to disagree with you. Variables should not be declared public. In Java we have setters and getters to change/get variables, in .NET we have properties. In VS2k5 you can easily define your private variable, then using the refactoring functionality turn this into a property with about two clicks (I don't recall the exact procedure.. it's been a while since I watched that "what's new" video). And in both Java classes at university as well as coding practices for C# they tell you that accessing variables directly is bad style of programming. For most variables, you don't need any accessors because they are only used within the class where they are declared, but those that are to be accessed externally should use properties.
10th January 2006, 13:21 | #1114 | Link | |
10th January 2006, 13:36 | #1115 | Link | |
obj.SomeFileld = value; obj.SomeProperty = value; Until you does not expose your objects from MeGUI it's safe to use public fields instead of primitive public properties!
10th January 2006, 14:12 | #1116 | Link | |
Now let's discuss about MeGUI architecture. I'm strongly prefer to keep main MeGUI architecture as simple as possible. As fact megui is job-based sofware so Job && JobList && JobExecutor is main GUI-less abstract classes. Another abstract classes would be JobProvider - some component wich provide some GUI for concrete job creation, tuning and tweaking and JoblessUtility - some additional visual staff (like bitrate calculator etc.) AudioJobProvider/VideoJobProvider/MuxJobProvider implementations itself can contain multiple configureable and extensible components (pattern Facade)... MeGUI must provide JobList management functionality and act as a host for multiple JobProviders and JoblessUtilities. It must provide additional bridge between JobProvider and JoblessUtility (for AviSynth script creation or bitrate calculator).
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS Last edited by dimzon; 10th January 2006 at 14:25. |
10th January 2006, 17:11 | #1117 | Link | ||
clueless n00b
Actually, you can use properties as full blown methods... the StatusUpdate contains a few examples, and there are some in other classes as well. For consistency purposes and design, every variable that needs to be available publicly should be wrapped in a property. Anything internal can stay a simple variable. This has a lot of advantages. Even inside the same project, with properties come nice descriptions that show up when using the commandline completion.. so even somebody not quite familiar with a class will be able to use those properties, whereas the use of the internal variables actually requires the study of the source.
I have already done a major refactoring once, redesigned a lot of the classes, and while in the end it's all nicer, it meant a really long time without even so much as a bugfix. Considering how MeGUI has grown, I don't think that's such a good idea. An incremental update, as I have begun to outline, where different parts of the entire project are marked off "under construction" and will be modified while the rest of the program continues to live, is a much more practicable approach.. it also lowers the pressure in having to get things done the right way right now as it will not be possible to make any big changes in the near future. We can certainly implement many of your suggestions (e.g. JobExecutor, although the name is horrible, the concept is good, same for JobList), but I think it would be better to hammer out the details and do the whole thing in small steps so as to not break everything at once and then having to deal with hundreds of not thousands of compilation errors when trying to put it together, and then the millions of smallish bugs that will have crept in.
10th January 2006, 17:25 | #1118 | Link | |
Mr. Sandman
0.2.3.2003 10 Jan 2006 Restored x264 tri-state the way it was before the whole tri-state was rewritten to a single method (that implies grayed out controls means also they're disabled in the commandline) However please do some testing and verify EVERY grayed out control is disabled in commandline
10th January 2006, 17:28 | #1119 | Link | |
clueless n00b
10th January 2006, 17:30 | #1120 | Link |
Mr. Sandman
Dont remember who did it, but if you check the changelog it should be there (i think berrinam or charleski)
Also, x264 rev398 has a new switch "--nr <int>" (noise reduction, default value is 0).
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 10th January 2006 at 17:37. |
development, megui, not a help thread |
