17th February 2008, 20:24 | #261 | Link | |
Hey Now!
Have you tried loading in the mkv file directly into megui using a synth script? If that doesnt work try using h264info on the .h264 file and set the lvl to 4.1 and pps every picture is checked then try to import that. If that doesnt work then also you may need to remux the source using tsmuxer into a .m2ts or .ts file and use that as your source. |
17th February 2008, 20:33 | #262 | Link | |
17th February 2008, 21:25 | #265 | Link |
Hi Jamos, the file itself was encoded with x264. The settings are not ps3 compliant because of too many reference frames as an earlier user commented. But I don't see how my elementary stream is not a valid h264 stream. It is and it plays on all software players, just not ps3. What can I use to reencode the elementary stream to make it ps3 compatible?
19th February 2008, 12:27 | #273 | Link | |
use 'r'
next I found directx show filter in NERO 8 package - NeTSmux.ax - nero transport stream muxltiplexor. in "graphedit" I've made all necessary connections to it without problems, but filter didn't produce anything and graph stoped with error message. Did anyone have find the way to force this filter to work? Last edited by n0mag!c; 19th February 2008 at 12:35. |
22nd February 2008, 04:27 | #276 | Link | |
22nd February 2008, 04:30 | #277 | Link |
Hey Now!
No ps3 will not play a m2ts file (audio does not work) you have to burn a BD or a AVCHD disk to get it to work (ie use bluray in TSremux then burn to a UDF 2.5 format with either imgburn 2.440 or a newer version of Nero).
22nd February 2008, 07:34 | #278 | Link |
i have a HUGE question:
i have used mkv2vob to convert roughly 10 720p and 1080p mkvs. i think all of these have required h264info to change the level and some of those had to be transcoded so that it would play on the ps3 also making these videos almost twice the original size. i tried using tsmuxer to make a m2ts file and changing the level and then using tsremux to make an avchd dvd, but it wont play on my ps3 (i know i burned everything correctly). this requires me to ask this question: what is it that requires a file to be transcoded to play on a ps3 and how do i know when i can just change the level of the file in tsmuxer to make a ps3-playable file? please i need major help with this |
22nd February 2008, 13:39 | #279 | Link |
Caped Crusader
Not strictly true, the PS3 wont play DTS from the XBM only from authoured discs. But it will play m2ts files with ac3 ( and with LCPM audio, from what I've read but not tested myself ) from the XBM.
tsmuxer |
