22nd May 2020, 12:03 | #7421 | Link |
MPC-BE use for some time now with great satisfaction... the other day I wanted to install MPC-HC and I noticed that the audio of the latter was weaker than that of MPC-BE, do you know what it can depend on? Volume for both 100%
22nd May 2020, 14:17 | #7422 | Link |
Can be several things. Some I can imagine:
- Internal Filters of MPC-BE vs. internal LAV Filters in MPC-HC -> different settings possible. - bitstreaming enabled in one of them - custom settings in the advanced audio processing options which MPC-BE has. |
23rd May 2020, 04:40 | #7424 | Link |
Thanks - fixed.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
25th May 2020, 14:59 | #7425 | Link |
I did some changes to the MPC video renderer:
- select the swap chain bit depth based on the bit depth of the area where the player window is located, not on the video bit depth; - if Windows is configured to display HDR+WCG, then make the video renderer display HDR10 content as HDR10. Regarding the first issue, I noticed that the bit depth of the swap chain was 8 bit. That's not optimal, we should be using more than 8 bit if the area where the player is located has a higher bit depth. The change I did was to pick the swap chain bit depth based on what Windows reports as the output bit depth underneath the area occupied by the player window. Regarding the second issue, I noticed that even though HDR+WCG was enabled in Windows 10, the video renderer would tonemap HDR10 video content to SDR. The change I did was to allow displaying HDR10 media as HDR10 content when the area occupied by the player window was enabled as HDR. What I did not do was to handle the case when the media player window is moved from one screen (virtual or not) to another, as one could be able to show HDR and another one only SDR. This would mean recreating the swap chain. Did try to do so, but likely hit some multithreading issues. This needs to be done by someone who understands what's going on there. Would there be any interest in these changes? Last edited by KoD; 25th May 2020 at 15:52. |
25th May 2020, 23:34 | #7426 | Link | |
You can create pull request on github.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 26th May 2020 at 00:18. |
26th May 2020, 07:01 | #7428 | Link |
Latest SVN - https://yadi.sk/d/AjAXDDHtHRIELg/Beta%20(Nightly)
29th May 2020, 09:35 | #7430 | Link | |
29th May 2020, 09:48 | #7431 | Link |
You can say "thanks" to google
P.S. Fixed.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 29th May 2020 at 10:12. |
31st May 2020, 02:49 | #7434 | Link | |
v0lt's sig -> https://forum.doom9.org/showpost.php...postcount=7378 Russian forum -> https://mpc-be.org/forum/index.php?topic=4 I had to translate but the links are here: Ночные сборки: Яндекс.Диск, Альтернатива 1, Альтернатива 2. Старые версии на VideoHelp.com. Sometimes VideoHelp has the latest, and the main Yandex link is usually showing download limit exceeded so I find myself using alternative 1. Last edited by M.Scott; 31st May 2020 at 03:06. |
8th June 2020, 09:15 | #7439 | Link | ||
BTW, if anyone knows, is there a changelog for the betas, would like to know what all has changed? |
8th June 2020, 09:56 | #7440 | Link |
I don't think so, you can take a look at the commit messages on sf.net
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
