15th April 2009, 20:09 | #8762 | Link |
Derek Prestegard IRL
I tend to think that pricetag is invesely proportional with quality
Look at Aften versus Apple's AC3 encoder, or a $30k Dolby rackmount encoding server... ~MiSfit
These are all my personal statements, not those of my employer :) |
15th April 2009, 20:21 | #8763 | Link |
Here's a feature request that I'd absofreakinglutely _LOVE_ to see implemented:
QuickTime support I deal with ProRes + PCM sources a lot, and currently use an AviSynth + SoundOut workflow to handle them. It would be very nice to just do this: Code:
eac3to movie.mov 2:audio.ac3 -384 -0,1,2,3,4,5 ~MiSfit
15th April 2009, 20:26 | #8764 | Link | ||
BluRay Maniac
16th April 2009, 04:48 | #8765 | Link | |
Do you feel from your own personal experience and ABX testing that you would choose DD 640kbps encoded by eac3to.exe (uses libAften.dll for this conversion, I believe) over DTS 1.5 Mbps encoded by SurCode, given that the source for each encoder would be the same?
- SomeJoe Last edited by SomeJoe; 16th April 2009 at 17:15. |
16th April 2009, 07:03 | #8766 | Link |
Nero AAC Encoder could not be located http://www.nero.com/eng/nero-aac-codec.html http://www.nero.com/eng/technologies-aac-codec.html |
16th April 2009, 09:51 | #8767 | Link |
Any idea why eac3to doesn't detect any of these AVCHHD/BD images from TSMuxer as bluray?
I also experience this when splitting with TSMuxer but full movies seem ok, does eac3to have a threshold on running time? |
16th April 2009, 22:24 | #8770 | Link | ||
About year ago I dmuxed TRAINING DAY HDDVD using eac3to to mkv.
Here is the log: Quote:
I'm suprised that Mediainfo recognised VC1 video in mkv container as 29.97fps (!) The same TsMuxer - 1080i 29.97 (pulldown)... After TsMuxer finished the job BDinfo showing: Quote:
16th April 2009, 22:49 | #8771 | Link |
You didn't strip the pulldown flags from the stream, hence it shows 29.97fps, this is the format on the HDDVD disk. You can take them out using either EAC3TO (it does it by default these days) or TSMUXER (tick the remove pulldown box). The stream will then show as 23.976fps.
Cheers, -jj- |
17th April 2009, 23:37 | #8774 | Link |
Is it possible to convert a 6 channel aac file to a 2 channel aac file with eac3to? And if so how? I couldn't find anything that looked like it could do that but I'm not very proficient with eac3to or audio files for that matter.
17th April 2009, 23:58 | #8775 | Link |
Yes, sort of:
eac3to input.aac output.m4a -down2 Code:
eac3to input.wav output.m4a -down2 |
18th April 2009, 12:49 | #8777 | Link |
Hi madshi, been awhile since I last posted here, but still using eac3to everyday
Anyway, have a question; What is the difference if I just demux video stream with eac3to and mux it in mkv with mkvmerge instead of mux it directly into mkv with eac3to? Do stream/mkv header loose some important data? Im asking this, as I found out that some AVC titles muxed in mkv with eac3to are causing small stutter on PCH but if demux this mkv with eac3to and mux it back with mkvmerge (inputing elementary raw video stream) then the stutter is gone. But since its double the work with this, am I safe to just demux the streams at first place? btw, this is the link from nmt forum regarding this PCH problem; http://www.networkedmediatank.com/sh....php?tid=10602 |
20th April 2009, 20:52 | #8779 | Link |
My older version of arcsoft is bugging me constantly about updating to version 3. I assume that the new version 3 stuff won't work with eac3to, which is why I'm holding off on upgrading. Are there some files to hold onto that I can copy elsewhere for eac3to to use? Which file does eac3to need in order to work properly?
Or, has anyone tried upgrading arcsoft to version 3 and had eac3to still work? I really don't want to lose my eac3to tools! Thanks! |
20th April 2009, 20:57 | #8780 | Link |
Is there a bug that you are experiencing or a feature you would like to see implemented? If so, post it here and I'm sure madshi will work on it in due time.
HdBrStreamExtractor |
eac3to |
