8th March 2007, 06:57 | #901 | Link |
Mmmmmmmmangoscam!
Sweet, thanks. Trying it on KoH's audio now, will post results.
With KoH, the audio is two parts after demuxing, the second part would extract the core with mkvmerge fine, but the first part hung up about halfway through with an invalid DTS encoder header error and was unextractable for me. Hopefully this tool gets past it. Any chance of a similar tool for DD+/E-AC3? As I understand, E-AC3 streams also employ a similar method where there's a regular AC3 core, but I haven't read the spec so I'm unsure. |
8th March 2007, 07:08 | #902 | Link |
Mmmmmmmmangoscam!
G:\>dtscore .\koh\part1.dts .\koh\part1-out.dts Frame length 2012 bytes, Sample Rate 48000, Bitrate 1509750 Offset 1527602371 Illegal sync byte found and skipped! This is not an error! Offset 1910398788 Illegal sync byte found and skipped! This is not an error! G:\> |
8th March 2007, 07:36 | #903 | Link | |
Glad to hear it helps on KoH :-) For DD+/E-AC3, no chance very likely, since Dolby breaks the backward compatibility of legacy DD/AC3 software/hardware by designing new bitstream format and different bsid. Even if I can extract the 640Kbps 5.1 core, it is still undecodable by legacy product. |
8th March 2007, 08:07 | #904 | Link |
I've tried getting the video and audio to sync, but still no luck. I've tried two different methods to get the dd+ --> ac3 track to sync, but its always off. I'm using MKVMerge to merge the .mkv and the .ac3. Has anyone else had success with any method, and if so, what did you do?
Thank you. |
8th March 2007, 09:59 | #905 | Link |
@all,
I need your help. I am still trying to get a dd+ track back to a normal .ac3 and I am not successful. Everyone in this thread is talking about Sonic Audio Decoder 4.2, but I am not able to find this one. Which product do I need to buy to get this one ? I just have Sonic Audio MCE Decoder 4.1, but when I try to link a .ddp file via graphedit to this one, it takes a while and then Sonic HD Demuxer will be put between them and it will not work as the output file in .wav is just very small. Thank you all for your help. This is driving me totally crazy. |
8th March 2007, 10:20 | #906 | Link | |
8th March 2007, 11:30 | #907 | Link |
I have been trying out the ” DTS/AC3/DD+ source” filter that Orbitlee modified and it works great for DD+/E-AC3.
I have been thinking that Sonic Audio Decoder or Cyberlink Audio Decoder should be able to decode Dolby TrueHD. As it is right now it’s not really possible to connect such a stream in Graphedit with the audio decoders. Would it be possible to modify the source filter so that it works for Dolby TrueHD as well? |
8th March 2007, 11:45 | #908 | Link | |
Coder
Does anybody want to use this function in EVOdemux? Continue to work or not? |
8th March 2007, 11:59 | #910 | Link |
xport
drmpeg,
your xport utility is great but is it possible to add there feature to export every track that is in m2ts file? I mean it is little bit time consuming to use it 5 times if you want to extract everything from it. And one more, how are things moving with LPCM export? Would it be soon possible to extract it and save into multichannel file? But despite this, still thank you for your great job |
8th March 2007, 12:13 | #911 | Link | |
Coder
8th March 2007, 12:26 | #912 | Link | |
Unfortunatley I have big trouble on implement this feature now. 1. No specs on TrueHD and DTS-HD yet. 2. Both Dolby TrueHD and DTS-HD Master Audio are VBR instead of CBR. Gabest's source filter is designed on CBR only. So there will be some difficulties. |
8th March 2007, 13:57 | #917 | Link | |
1. File Source (Async.) -> Sonic HD Demuxer -> Sonic Cinemaster Audio Decoder 4.2 -> Dump 2. To get the channels right and convert it to wav in the process: sox -r48000 -t .raw -c 6 -3 -s dump.raw dump.wav I just deleted my Blu-ray test files but will rip a disc again and see if it's possible to skip Cinemaster Audio Decoder completely from the chain. |
8th March 2007, 15:21 | #918 | Link | |
8th March 2007, 15:49 | #919 | Link | |
However, I do have an update for LCPM. http://www.w6rz.net/xport.zip Version 0.94 now defaults to demuxing all the channels of an LPCM track. I've added the -2 option to only demux two LPCM channels (like in version 0.93). I tried the 6-channel output with sox, and it seems happy. I don't have a way to test the 6-channel .wav file. Ron
HD MPEG-2 Test Patterns http://www.w6rz.net |
8th March 2007, 16:12 | #920 | Link | |
But from what I understand from Drmpeg's post there is a now also another option to extract LPCM. |
