7th March 2016, 16:42 | #901 | Link |
The Nvidia GT630 v2 is a Kepler card and NVEncC should work for you.
Your driver is ancient... Install the latest and it will do the job.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
7th March 2016, 18:25 | #903 | Link | |
Best regards Dust Signs
The number you dialed is imaginary. Please turn your phone by 90° and try again |
8th March 2016, 12:15 | #904 | Link |
Thanks!
For the driver version I was incorrect it's actually a newer 347.52 from 2015 installed on that sys. For the GPU error I suspect that maybe the GPU memory type is the cause for the error? This GT 630 has only cheap DDR3 with 14.4GB/s bandwith(according to GPU-Z). I will try another GK208 GPU laying around a "GT 640" with GDDR5 memory on the system and 40.1GB/s bandwith. Maybe that will do the trick. Buying a new second gen maxwell eg. GTX950 for about 150,- € only for transcoding isn't worth it for me. Pascal is around the corner. Hopefully there will be some low end Pascal GPUs for NVENC usage. I double checked that I use "NVIDIA H.264" at encoder settings. I'm using StaxRip v1.3.1.7 and I read this article for a first orientation and setup: http://www.techspot.com/article/1131...ack/page5.html Last edited by Pengaban; 8th March 2016 at 12:33. |
8th March 2016, 13:22 | #905 | Link | |
I suggest you to download and install latest driver for your system. GPU memory type and performance has nothing to do with such compatibility errors.
8th March 2016, 14:00 | #906 | Link |
Tried latest StaxRip x64 test-build
1)I have asked this previously. For the file below in "Single file" mode I can mux subtitles. In "file batch" mode, I can't. Sample: http://www.filedropper.com/00063 Bug or limitation ? 2) More than 2 audio streams muxing looks good. 3) VCEEnc has a newer version 1.03v2 here: https://onedrive.live.com/?id=6BDD43...DD4375AC8933C6 4) I think going to Help -> Support forum should point here and not in videohelp.com forum
8th March 2016, 14:51 | #907 | Link |
Is it possible to use x265.exe (for example 8-bit or 10-bit) instead of the multilibrary x265_ml.exe ?
I'm asking this because there are several builds available on the web, updated daily, based of various compilers, while as far as I know x265_ml.exe is only available in Ligh's builds, which are updated less frequently and built with a single compiler. So using single libraries might be, occasionally, more flexible. |
8th March 2016, 16:25 | #909 | Link |
Has anyone succeeded in using HW encoding (QSV, NVEnc, VCEEnc) on a laptop with GPU switching technology ?
Like Nvidia Optimus or AMD Enduro.
8th March 2016, 18:57 | #911 | Link |
How ?
Can you describe it a little ? Which program worked ? QSVEncC, NVEncC or both ?
8th March 2016, 19:47 | #912 | Link |
Both worked, used the H264 version. I've never used these encoders before, I was surprised by their speed. Just to make sure I'm not mistaking, you refer to these encoders that I highlighted in the image below?
As were the ones I used. * I can understand a little English, but to talk I use google translator, so if something sounds incomprehensible, i am sorry. Last edited by Havokdan; 8th March 2016 at 19:52. Reason: Picture |
9th March 2016, 01:34 | #913 | Link | |||||
9th March 2016, 06:49 | #914 | Link |
@Stax76
It seems that you have some interesting options for decoder using NVEncC, like ffmpeg DXVA2 and QuickSync. Is it possible to add those to VCEEncC too ?
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all Last edited by NikosD; 9th March 2016 at 09:20. Reason: ffdshow -> ffmpeg |
9th March 2016, 13:55 | #915 | Link |
Hi guys,
just wanted to give a quick feedback on the NVENC error. My educated guess was right about the GPU RAM Type. I just swapped the GT630(DDR3) with the GT640(GDDR5) without changing anything on the software side and it worked like a charm with the 347.52 driver. Remember the GPU cores are the same on the two cards both GK208. Maybe this is something worth to mention anywhere in the documentation? Done some quick&dirty test on a FullHD.ts(variable bitrate ~9MBit/s) file recorded from SAT TV. I got ~33 fps with NVENC H.264(Mode:CQP standard) compared to 3,x fps with x264 on the same old system(Athlon64 x2 DualCore 2GHz). OK x264 at "medium" settings managed to get a 50% smaller file compared to the original .ts as NVENC only managed a ~20% reduction. But I think room to improve on that. Looking forward to Nvidia Pascal and some lowend GPUs with enhanced NVENC support. Last edited by Pengaban; 9th March 2016 at 13:59. |
9th March 2016, 14:03 | #916 | Link | ||
Are you 100% sure your GT630 is not a Fermi card ? Quote:
Did you try to choose as decoder the CUVID decoder of latest StaxRip versions ? It should be a lot faster than your CPU (SW) decoder.
9th March 2016, 14:40 | #917 | Link | ||
So finally the power draw of the whole system was about equal with the GT630 in place compared to the old onboard GPU. Quote:
Is this "CUVID" an new ecoding "Mode" from the NCENC encoder? |
9th March 2016, 14:44 | #918 | Link | |
CUVID has nothing to do with encoding. CUVID is a fast HW decoder in order to accelerate the transcoding process (decoding+encoding) Because you decode the clip with your very slow CPU which is slowing down the whole process and your NVENC (HW) encoder, which is faster than your CPU.
9th March 2016, 14:53 | #919 | Link | |
9th March 2016, 14:59 | #920 | Link |
Yes, that switch.
You have to select the NVEnc cuvid decoder. Tell us your results on the same clip and settings.
