27th December 2012, 02:55 | #16621 | Link |
madVR v0.85.7 released
http://madshi.net/madVR.zip Code:
* fixed: new 2x/3x shaders sometimes got activated when they shouldn't * renamed "speed up DXVA ..." options to "don't use copyback for DXVA ..." * disabled option "don't use copyback for DXVA deinterlacing" by default now |
27th December 2012, 03:07 | #16622 | Link | |
Broadband Junkie
27th December 2012, 08:17 | #16623 | Link |
Madshi, the blank window Overlay issue I can only get that to occur now when it's enabled before restarting, so don't worry bout it.
Regarding "use a separate device for presentation" is there a preferred setting you think for this? Reason I ask is because I have no flushing set at all and to disable it I need to flush/flush and sleep. I can't see any obvious performance differences in display times or GPU usage between the two configs but I generally strive for the least amount of work my system has to do to get acceptable output. Have you tried changing any flush settings, queues etc to help try to prevent that? Perhaps you can look into if indeed it's truly necessary for you. |
27th December 2012, 09:03 | #16624 | Link |
I need that option (use a separate device for presentation) enabled as well or I get slowly incrementing delayed frames. All my queue and flush settings are at their defaults. 2.4 Core 2 Quad, Radeon 6570, Win 7 x64.
27th December 2012, 11:06 | #16626 | Link | |
Having this option enabled automatically forces a "flush & wait" after the last render step. So there's really no difference with flush settings, after all. Having the OSD open means that all render queues are emptied every second, so that the paused frame can be updated with the latest OSD information. After emptying the queues, madVR automatically starts working to fill them again. So basically in this state madVR is constantly rendering to fill the queues, then empties them again, then fills them again etc. This isn't really ideal, of course, but then having the OSD on should only be a temporary thing for debugging purposes, so I don't think GPU consumption with OSD on in paused state is very important. |
27th December 2012, 11:57 | #16627 | Link |
Hi madshi, thanks for all the updates. Just a quick one... the file name extensions (23p, 23fps, etc) don't seem to be working anymore. I'm coming from 0.55.2. If you can't reproduce it I'll post a log.
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
27th December 2012, 12:02 | #16629 | Link |
Andy o,
see the change log. There was a full rewrite of the file name tags.
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V Win 10 64bit 1803 + Zoom Player v14 |
27th December 2012, 12:42 | #16630 | Link |
OK thanks, has this been discussed more in depth though? I'm still adding "refreshRate=23" and nothing happens. Same with "frameRate=23". I don't know what the difference is between those two, either.
Here's the log https://docs.google.com/file/d/0B0La...NNV0hMczA/edit (to download the zip go to File-download--stupid google unzips the file right there and obscures a way to download the original zip).
27th December 2012, 13:11 | #16632 | Link | |
For AMD users this option has no effect at all. For NVidia and Intel users it results in a small chroma blur. |
27th December 2012, 13:29 | #16634 | Link |
First of all, thanks for your continued hard work on MadVR. A really good piece of software.
I've encountered a rather strange bug, happens randomly and with quite specific settings. Here's how to reproduce:
Same file works fine with one of the "use separate device ..." options disabled or when using either other scaling algorithms or no scaling. Also other files work perfectly. Link to sample: Code:
www.mediafire.com/?ca88a1buue7g2dy Code:
www.mediafire.com/?z72h4726xh4v859 Intel Core i5 3570K Intel HD 4000 + drivers v2875 Windows 7 (x64) MadVR v0.85.7 MPC-HC Lite 1.6.6.6391 (32bit of course) LAV Filters 0.54.1, but also happens if using MadVR's internal decoding |
27th December 2012, 16:11 | #16635 | Link | |
I have redone the tests with newest madvr build. I also noticed that I didnīt have newest VGA bios so I flashed the newest one. Donīt know if the change that now happened comes from VGA bios or madvr (donīt even know if decoding matrix has to do with settings in VGA bios...) DXVA decoding still delivers right colors. And DXVA scaling for BT709 now seems to be the same like in your setup (very similar numbers in decoding matrix: AnalyzeGpuNv12ToRgb(VideoProcessBlt): +, bitdepth: 17, yFactor: 0.99998474, yOffset: 0.00000000, range: 15.99975586..234.99641418 YCbCr -> RGB decoding matrix used by GPU: 0.99998474 0.00000000 1.53823853 0.99998474 -0.18417358 -0.45913696 0.99998474 1.81320190 0.00000000 Difference now: bitdepth 17 instead of 32 ??? Using DXVA scaling with BT601 content now leads to following numbers: AnalyzeGpuNv12ToRgb(VideoProcessBlt): +, bitdepth: 17, yFactor: 0.99998474, yOffset: 0.00000000, range: 15.99975586..234.99641418 YCbCr -> RGB decoding matrix used by GPU: 0.99998474 0.00000000 1.73019409 0.99998474 -0.21400452 -0.51620483 0.99998474 2.11410522 0.00000000 The numbers have slightly changed in comparison to old test, but itīs more or less the same decoding matix. I donīt know the numbers for a correct BT601 decoding matrix, but the numbers given are the ones used. So now DXVA decoding and BT709 DXVA scaling are right, BT601 I donīt know.... Edit: found out something more: http://www.equasys.de/colorconversion.html The BT709 decoding matrix is similar to "YPbPr to RGB color conversion for HDTV" and the unknown matrix which is used for BT601 DXVA scaling in my case is similar to "YCbCr to RGB color conversion for HDTV". Confusing... Last edited by hannes69; 27th December 2012 at 16:56. |
27th December 2012, 17:23 | #16636 | Link |
Banned
I tried the avisnyth script below to do a 24p to 60p conversion using blending (my first script, so no idea if it's correct).
It causes the madVR render times to decrease massively. How can that be? There must be something wrong, right? Code:
SetMemoryMax(512) SetMTMode(2) AssumeFPS(24) ConvertFPS(36) SelectEvery(3,0,0,1,2,2) SetMTMode(1) GetMTMode(false) > 0 ? distributor() : last |
27th December 2012, 17:43 | #16637 | Link |
I had problems with hi10p 1080p playback(720 worked fine)-i would drop about 50% of frames. (i think rendering queue was almost empty)
I noticed when trying to play back hi10p 1080p anime for testing that it worked just fine untill subtitles (karaoke) started-i tried messing around with gpu and cpu buffers in madvr settings-set them to 16-cpu and 12-gpu-no improvement at all. then,i messed with sub-pictures to buffer in subtitles options in mpc-hc. Changing it from 5 to 1 did help,althrough i dont have animated karaoke subtitles now,just static ones. Setting it to 0 made the problem to come back. It doesnt have any impact visual impact on static subtitles but i can now play back those videos just fine. And so,i have a question-WHY does subtitles buffer have such impact on playing back such content? im running xp32bit,phenom II x2 3,1ghz and radeon HD4870(1gb version),and 4gb of ddr3 ram. my screen is set to 76,416hz@1680x1050 (cant yet get it working to 71,928hz). Downscaling i use is AR filter,linear light Catmull-Rom and chroma upsampling is 3-taps Jinc with AR filter. its mkv file so mpc used haali media splitter,lav video and madFlac. (latest versions of lav and madvr) Last edited by konakona; 27th December 2012 at 17:51. |
27th December 2012, 18:13 | #16638 | Link | |
Disable it and use xy-vsfilter. |
27th December 2012, 20:09 | #16640 | Link | |
When xy-vsfilter devs finish the support for the new rendering interface, it will be able to render subtitles at higher resolution without those problems. You can, of course, keep using MPC-HC subtitle renderer for SD videos, if you are not having any slowdown with those... Last edited by shimaflarex; 27th December 2012 at 20:34. |
