13th March 2014, 22:02 | #24921 | Link |
Posts: n/a
And yet another grand release
From mighty "mad" - my soul's caprice. He's "mad" but also "shi", yes - "shi", A great name combo for all times to be! The above was written with assumption that madshi is pronounced like madshee, and not madshy/madshai Does that mean the image will be darker if the display is set to use BT.1886 gamma via 3DLUT in contrast to the previous madVR release? |
13th March 2014, 22:12 | #24922 | Link |
2 short questions:
1. I have a 6bit + FRC LCD display. What is the "right" setting (I know you hate this kind of question) for "the native display bitdepth is:" ? a) 6 bit b) 8 bit c) use test patterns and decide whatīs looking best for you 2. Is there a workaround for using 23,976 and 24,000 Hz refresh rates side-by-side in Windows for use with the display switcher (I donīt want to use smoothmotion or Reclock and my projector only accepts refresh rates in the 30Hz - 60 Hz region so actually I want to use 47,952 and 48,000 Hz with the EDID override method, I have to lower both refresh rates because of the clock deviation, so I end up with two 47,xxx refresh rates, Windows canīt distinguish them...) Thanks for your help |
13th March 2014, 22:24 | #24924 | Link |
What is the 7-bit bitdepth option for anyway?
edit: Hannes69 asked the same question as me basically Is linear light processing for dithering supposed to be better? In general, I'd be interested in a little blip about linear light processing. Thanks madshi Last edited by JarrettH; 13th March 2014 at 22:40. |
13th March 2014, 22:28 | #24925 | Link | |
The defaults are horrible, I'd suggest pattern 3 and adjusting strength between 0.5-2.0, increasing clamp improves really fine detail without artifacts if adjusted correctly, I use 0.5.
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 |
13th March 2014, 22:53 | #24926 | Link |
madshi,
I think there's a problem with jRiver. If I start playback on my secondary monitor (FSE mode) all looks good, but then when I click on anything like an icon or a window on my primary, video goes to black, but it keeps playing and I still get audio. I can get it back by double-clicking (to display mode back to primary) and then going full screen again. No issues like this with any prev madVR versions... CCC14.2B, jRiver MC19 b122 Lemme know if you want a log.
Win7Ult || RX560/4G || Ryzen 5 |
13th March 2014, 23:11 | #24927 | Link | |
13th March 2014, 23:54 | #24928 | Link |
MadShi!!!! ESET Smart Security think your newest version is a virus.. "Probably unknown NewHeur_PE virus"... I'm just informing you even if there is no virus...
Gigabyte G1.Sniper Z87, I7 4770K (3.5ghz), Gigabyte Radeon 280x, Win8.1 x64, ATI 15.7.1, MPC-HC BE 1.4.6 1478, MadVR v0.90.21, LAV Filters 0.68.1, XySubFilter 3.1.0.746 |
14th March 2014, 01:17 | #24931 | Link | |
HCFR has options to disable the VideoLUT or 3dlut (under Measure - Generator - Configure), but it can't undo what is disabled by MadTPG |
14th March 2014, 01:34 | #24933 | Link |
after all the money ive spent on that titan , they better get this fixed asap , but as said something tells me this is just theyre usual run o the mill automated email response they send out to all the other bugfix tickets they send out
14th March 2014, 04:41 | #24935 | Link | |
14th March 2014, 06:58 | #24936 | Link | |
Thank you for another great build.
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410. Last edited by James Freeman; 14th March 2014 at 07:08. |
14th March 2014, 07:28 | #24937 | Link | ||
Less bitdepth will give you a "sharper" or noiser display, many people wouldn't be able to tell the difference between 8bit and 7bit, pick what you prefer. Quote:
That's what makes MadVR what it is, no compromises. I do hope madshi updates the screenshots when 1.0 hits.. things have changed a bit now. Quite impressed how far things have come along since the early days, it's been fun. Last edited by ryrynz; 14th March 2014 at 09:08. |
14th March 2014, 13:55 | #24938 | Link |
madshi, I am getting lots of "madVR reports: - Creating direct3d device failed (8876086a)" errors with this new build 87.7 when starting to play various vids. Cannot find a pattern but it is happening alot. I have to close and reopen Zoom Player then it works again.
With previous build 87.6 I didn't get these, not once. |
14th March 2014, 14:57 | #24939 | Link |
Kid for Today
I'm also getting quite a lot of "this device doesn't support overlay" and I'm seeing tearing in windowed/FSW even though I'm quite sure that wasn't the case with older builds like 2 weeks ago. I've got Aero disabled BTW.
14th March 2014, 15:03 | #24940 | Link | |||||||||||||
The internal processing of some displays can't properly display 8bit images without introducing banding artifacts. Setting madVR to 7bit or 6bit could help work around that, on the cost of a slightly higher noise floor. Quote:
