9th January 2008, 18:18 | #401 | Link |
There is no problems in adding AQ to VfW version. The only thing that needed is too compile with patched x264lib (VfW code already known about --aq-strength and --aq-sensitivity command line options). But before I will add AQ in my builds somebody (may be I, but later) need to fix some side-effects of current AQ (I think, due to this side-effects AQ patch is not in x264 trunk).
9th January 2008, 18:20 | #402 | Link | |
x264 developer
12th January 2008, 17:35 | #404 | Link |
<The VFW Sheep of Death>
Looks like it's gotten a little too popular... I'll put the zip as an attachment here, if it will fit.
Can anyone suggest/offer a better free hosting package?
Recommended all-in-one stop for x264/GCC needs on Windows: Komisar x264 builds! |
12th January 2008, 18:45 | #406 | Link |
Version 3_719bm of x264vfw
Changes: - Added option "Extra options" (For those who want to mix standard options and x264-style command line options) - Fixed impossibility to encode in some applications (for example, TMPGEnc Plus v2.524.63.181) which set lFrameCount == 0 in ICM_COMPRESS_FRAMES_INFO message - Fixed other minor bugs Last edited by MasterNobody; 15th January 2008 at 02:23. |
12th January 2008, 19:56 | #407 | Link |
Thanks, MASTER
There was trial version VirtualDub with support mkv: http://216.75.63.164/andrew/VirtualDubMKVout.zip http://216.75.63.164/andrew/VirtualdubMKVsrc.zip Discussion is conducted here: http://forums.virtualdub.org/index.p...&t=8904&st=60& Last edited by Gromozeka; 12th January 2008 at 20:04. |
14th January 2008, 19:33 | #409 | Link |
Gromozeka
I think current 259 symbols (260 including ending zero) for command line is enough. An it is the standard for real command line in Windows (this mean you can't use longer command line with x264 CLI version). I may suggest you to use "Extra options" instead of full command line. It has the same size 259 symbols but there you need to specify only options for which there is no standard GUI options. May be you will post your command line which need more than 259 symbols here to look at it. Last edited by MasterNobody; 14th January 2008 at 19:37. |
14th January 2008, 20:07 | #410 | Link |
Software Developer
MasterNobody, your installer doesn't create working shortcuts on WinXP x64 Edition!
What your installer created is: Target: »C:\WINDOWS\system32\rundll32.exe x264vfw.dll,Configure« Start in: »C:\WINDOWS\system32« What we need on x64 Windows: Target: »C:\WINDOWS\system32\rundll32.exe x264vfw.dll,Configure« Start in: »C:\WINDOWS\sysWOW64« Or alternatively you can use this: Target: »C:\WINDOWS\system32\rundll32.exe C:\WINDOWS\sysWOW64\x264vfw.dll,Configure« Start in: »C:\WINDOWS\system32«
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 14th January 2008 at 20:13. |
14th January 2008, 20:27 | #411 | Link |
MasterNobody
The standart my command line from MeGui (not all): --crf 18 --ref 10 --bframes 3 --b-pyramid --deblock -2,-1 --partitions all --8x8dct --direct auto --me umh --trellis 2 --subme 7 --mixed-refs --b-rdo --weightb --bime --no-fast-pskip --no-dct-decimate --cqmfile "C:\Program Files\x264GUI-Lite_14-04-2007\Matrices_x264\M4G HRM V2.cfg" --deadzone-inter 6 --deadzone-intra 6 in x264vfw: --crf 18 --ref 10 --bframes 3 --b-pyramid --deblock -2,-1 --partitions all --8x8dct --direct auto --me umh --trellis 2 --subme 7 --mixed-refs --b-rdo --weightb --bime --no-fast-pskip --no-dct-decimate --cqmfile "C:\Program Files\x264GUI-Lite_14-04-2007\Matric |
15th January 2008, 06:37 | #413 | Link | |
16th January 2008, 01:35 | #414 | Link |
I compiled x264vfw experimental build. This x264vfw build was compiled using x264 core with adaptive quantization patch version 0.41 by Dark Shikari. There is no standard options for adaptive quantization so you need to specify x264-style command line options for using it.
P.S. I will update this builds not regularly (only when Dark Shikari will post new versions of his patch with source diff) |
16th January 2008, 11:55 | #415 | Link |
Software Developer
Thanks
Will AQ be enabled by default in the "experimental" build? If not: What "x264-style command line options" do I need to set in particular to enable AQ? BTW: Variance AQ, Version 0.42 is out
16th January 2008, 15:20 | #416 | Link | |
x264 developer
Lambda AQ would fail horribly on high QPs due to a bug that will be difficult to solve. |
17th January 2008, 00:39 | #417 | Link |
x264vfw experimental build was updated to AQ patch version 0.42 by Dark Shikari (slightly modified but must be bit identical)
No, it not enabled by default. The easiest way to use it is to specify "--aq-strength 1.0" in "Extra options" field (also there is "--aq-sensitivity <float>" option but it is recommended to leave it equal to 0.0 and so use automatic sensitivity) Last edited by MasterNobody; 17th January 2008 at 00:47. |
17th January 2008, 00:50 | #418 | Link |
Software Developer
I see
29th January 2008, 03:55 | #420 | Link | |
x264 developer
--aq-strength 0.5 --aq-sensitivity 13 --qcomp 1.0 |
