Old 25th February 2018, 21:40   #49241  |  Link
ryrynz
ryrynz's Avatar
Rather not likely at all actually, use SVP.
Old 25th February 2018, 21:43   #49242  |  Link
foozoor
foozoor's Avatar
Will madVR only be used for real-time rendering?
foozoor is offline   Reply With Quote
Old 25th February 2018, 22:22   #49243  |  Link
bkrieger
I am using NGU high for both Chroma Upscaling and Image Upscaling. Under image downscaling I am using SSIM 2.0, 100%.I have a GTX 980 TI.
For Chroma Upscaling, should I use super res filter, and if so what strength?
Under image downscaling I am using the strict soft anti ringing filter. Should I also use the anti bloating filter and if so what strength.
Sorry, I tried searching the forum for these settings, but couldn’t find an explanation on them or what people are using.
Thanks
bkrieger is offline   Reply With Quote
Old 25th February 2018, 22:24   #49244  |  Link
steakhutzeee
steakhutzeee's Avatar
Thanks
Try to take a look here https://forum.doom9.org/showthread.php?p=1709584
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM
steakhutzeee is offline   Reply With Quote
Old 25th February 2018, 22:57   #49245  |  Link
ryrynz
ryrynz's Avatar
Please don't quote entire posts directly above yours when you have a one line reply..
It's entirely up to you whether you like how if looks. Personally I'm not a fan of SuperRes, NGU does a good job with chroma anything else on top of it usually is imo excessive sharpening using resources better spent elsewhere. Anti ringing is a good choice if you don't mind the sharpness hit.
Old 25th February 2018, 23:03   #49246  |  Link
bkrieger
Thanks for that.
My only question then is, should I turn on Super-res filter. Is it wildly used?
Thanks
Old 26th February 2018, 01:53   #49247  |  Link
no is generally not advised to be used with ngu.
Old 26th February 2018, 12:12   #49248  |  Link
d3rd3vil
Originally Posted by Asmodian View Post
To each their own I suppose. I use 4:4:4 + 24 Hz without interpolation. Using motion interpolation to take 24 Hz to 60 Hz, with SVP or similar, is the worst situation. As always, smooth motion is only useful if you cannot get a well matched refresh rate. Doing it in the TV is a better place than in madVR.
Using SVP for 24 to 60 or 120 is the best way there is big time!
d3rd3vil is offline   Reply With Quote
Old 26th February 2018, 14:07   #49249  |  Link
bran
Just exchanged my GTX1070 for a RX580 (because nvidia only supported 8 or 12bit output, and 12bit yields banding on my TV).
The RX580 struggles quite a bit more than my 1070 though (got a 4K screen and watch 720/1080/2160p) material only.
Is there any specific changes I would be advised to do in madVR and/or LAV Filters when switching from nvidia to AMD? Using DX11 in LAV Filters right now as it is, DX11 non-FSE in madVR.
HTPC: Samsung 65JS9505, Yamaha A2070, Sonus Faber, RX580
bran is offline   Reply With Quote
Old 26th February 2018, 15:27   #49250  |  Link
mytbyte
RX580 should be on par with 1060, n'est-ce pas? What exactly does it struggle with? I have RX580 in a laptop, I could check
mytbyte is offline   Reply With Quote
Old 26th February 2018, 15:51   #49251  |  Link
noee
@bran:
NGU chroma scaling is *not* cheap on Polaris (at least on a 560), so if you're using that, maybe drop it down to Med/Low. NGU in general, is heavy on Polaris, so for luma scaling, you might drop it back from High=>Med if you're using that.
Win7Ult || RX560/4G || Ryzen 5
noee is offline   Reply With Quote
Old 26th February 2018, 17:24   #49252  |  Link
njfoses
Originally Posted by pirlouy View Post
I really enjoy the motion interpolation from my Samsung TV. They manage to add better motion without giving soap opera effect (ok there is some judder -not even artifacts- sometimes). I prefer to use 4:2:2 + 24Hz + motion interpolation instead of 4:4:4 + 60Hz + madVR's smooth motion.
On my Sony 940E i greatly prefer to have control over motion interpolation so i have to sacrifice 4:4:4 as well. Being that none of the video content i watch is encoded in 4:4:4 this is a tradeoff worth taking imho.
njfoses is offline   Reply With Quote
Old 26th February 2018, 17:25   #49253  |  Link
njfoses
Looks like a new Nvidia driver has been released.
Old 26th February 2018, 20:44   #49254  |  Link
Manni
I gave it a quick try and not to restart the discussion but this driver is still incompatible with Asio4all after a clean install. Neither jRiver nor REW can select the HDMI output in the control panel. I'll try flexasio when I have more time.
If anyone is able to use Asio4all with this (or 390.77) driver on Window 10 Pro x64 1709 latest build (16299.248) please let me know by PM so as not to clutter the thread with OT posts. Thanks!
Win11 Pro x64 b23H2
Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33
madVR/LAV/jRiver/MyMovies/CMC
Denon X8500HA>HD Fury VRRoom>TCL 55C805K
Old 27th February 2018, 02:47   #49255  |  Link
khanmein
@bran exchanged my GTX1070 for a RX580
GTX 1070 > RX 580
khanmein is offline   Reply With Quote
Old 27th February 2018, 04:24   #49256  |  Link
ryrynz
ryrynz's Avatar
Yeah and for a reason that probably amounts to near zero visible improvement to boot. I had a laugh.
Old 27th February 2018, 04:55   #49257  |  Link
sony TVs are usually able to motion interpolate and keeping 4:4:4...
Old 27th February 2018, 09:51   #49258  |  Link
bran
GTX 1070 > RX 580
Yes, I'm fully aware of that. But as I said, nvidia outputs only 8 or 12bit. 12bit yields banding on my Samsung JS9505.
Yeah, I'm thinking about that. More or less only viewing 1080 and 4k material on 4k TV, so maybe Super-XBR is good enough to use as well on these ~10Mbps+ 1080p rips and Blurays?
So much has happened with madVR, and I know many of the options are "use what you prefer", but I'm having a hard time finding what is the best performance/PQ ratio on 1080p->4k upscaling.
As it is now im using NGU Sharp on all options, no Super Res, Random Error D, Enhance detail 1, low debanding, use colored noise.
This is making the RX580 Strix 3-fan edition go jetplane after a few mins :P
Old 27th February 2018, 10:44   #49259  |  Link
ryrynz
ryrynz's Avatar
So why didn't you just stick with the superior card and output 8 bit? Seems like a silly idea to me to jump cards to get what probably amounts to an insignificant change in PQ.
Anything you'd do with scaling with the superior card would have a far bigger impact on the image.
Old 27th February 2018, 10:55   #49260  |  Link
bran
Because I want HDR and BT2020 without banding?
Actually, I'm having a hard time noticing major difference upscaling high-bitrate 1080p material to 4k with super-xbr vs NGU.
