15th January 2012, 23:58 | #11501 | Link | |
At any rate, no worries. I just have an ac3 audio track that I have since deleted the source material for. I encoded it with a Film Light DRC setting and decided that Film Standard would be preferrable. It isn't worth transcoding to change it though. |
19th January 2012, 10:03 | #11505 | Link | |
More likely your eac3to is not setup to properly decode or encode dts. Type eac3to -test at the command prompt and see what it says. I could ask why you are trying to make a mono dts file... Stereo acoustics will sound much better, even if you are just duplicating the mono track. If you are determined to work with this challenging format (due to commercial copyright issues), you can play around with this brand new experimental open source dts codec that folks here have been working on. http://forum.doom9.org/showthread.ph...20#post1552620 |
19th January 2012, 20:17 | #11507 | Link | |
Here is that command you told me to use: Code:
eac3to v3.24 command line: eac3to -test ------------------------------------------------------------------------------ eac3to (v3.24) is up to date Nero Audio Decoder (Nero 6 or older) doesn't seem to be installed http://www.nero.com/eng/store-blu-ray.html CAUTION: You need Nero 7. Nero 8 won't work with eac3to. ArcSoft DTS Decoder (1.1.0.1) works fine Sonic Audio Decoder (3.24.0.0) doesn't seem to be installed Haali Matroska Muxer (2011-09-08) is up to date Nero AAC Encoder could not be located http://www.nero.com/eng/nero-aac-codec.html Copy NeroAacEnc.exe to the eac3to or to the Windows folder. Surcode DTS Encoder (1.0.29.0) is installed MkvToolnix (2.5.3.0, release version) is installed There's a new release version (5.2.1.0) available http://www.bunkus.org/videotools/mkvtoolnix There's a new beta version (5.2.1.0, 2012-01-13) available http://www.bunkus.org/videotools/mkvtoolnix/win32/pre Code:
eac3to v3.24 command line: eac3to 00001.m2ts 4: japanese-1.0.dts ------------------------------------------------------------------------------ M2TS, 1 video track, 3 audio tracks, 2 subtitle tracks, 0:24:13, 24p /1.001 1: h264/AVC, 1080p24 /1.001 (16:9) 2: TrueHD/AC3, 5.1 channels, 48kHz, dialnorm: -25dB (embedded: AC3, 5.1 channels, 448kbps, 48kHz, dialnorm: -25dB) 3: TrueHD/AC3, 2.0 channels, 48kHz, dialnorm: -25dB (embedded: AC3, 2.0 channels, 192kbps, 48kHz, dialnorm: -25dB) 4: TrueHD/AC3, 1.0 channels, 48kHz, dialnorm: -25dB (embedded: AC3, 1.0 channels, 96kbps, 48kHz, dialnorm: -25dB) 5: Subtitle (PGS) 6: Subtitle (PGS) [a04] Extracting audio track number 4... [a04] Extracting TrueHD stream... [a04] Removing TrueHD dialog normalization... [a04] Decoding with libav/ffmpeg... [a04] [libav] Substream min channel cannot be greater than max channel. <WARNING> [a04] The libav decoder reported error -1 while decoding. <ERROR> Aborted at file position 1048576. <ERROR> Code:
eac3to v3.24 command line: eac3to 00001.m2ts 4: japanese-1.0.wav ------------------------------------------------------------------------------ M2TS, 1 video track, 3 audio tracks, 2 subtitle tracks, 0:24:13, 24p /1.001 1: h264/AVC, 1080p24 /1.001 (16:9) 2: TrueHD/AC3, 5.1 channels, 48kHz, dialnorm: -25dB (embedded: AC3, 5.1 channels, 448kbps, 48kHz, dialnorm: -25dB) 3: TrueHD/AC3, 2.0 channels, 48kHz, dialnorm: -25dB (embedded: AC3, 2.0 channels, 192kbps, 48kHz, dialnorm: -25dB) 4: TrueHD/AC3, 1.0 channels, 48kHz, dialnorm: -25dB (embedded: AC3, 1.0 channels, 96kbps, 48kHz, dialnorm: -25dB) 5: Subtitle (PGS) 6: Subtitle (PGS) [a04] Extracting audio track number 4... [a04] Extracting TrueHD stream... [a04] Removing TrueHD dialog normalization... [a04] Decoding with libav/ffmpeg... [a04] [libav] Substream min channel cannot be greater than max channel. <WARNING> [a04] The libav decoder reported error -1 while decoding. <ERROR> Aborted at file position 1048576. <ERROR> Code:
eac3to v3.24 command line: eac3to 00001.m2ts 4: japanese-1.0.wavs ------------------------------------------------------------------------------ M2TS, 1 video track, 3 audio tracks, 2 subtitle tracks, 0:24:13, 24p /1.001 1: h264/AVC, 1080p24 /1.001 (16:9) 2: TrueHD/AC3, 5.1 channels, 48kHz, dialnorm: -25dB (embedded: AC3, 5.1 channels, 448kbps, 48kHz, dialnorm: -25dB) 3: TrueHD/AC3, 2.0 channels, 48kHz, dialnorm: -25dB (embedded: AC3, 2.0 channels, 192kbps, 48kHz, dialnorm: -25dB) 4: TrueHD/AC3, 1.0 channels, 48kHz, dialnorm: -25dB (embedded: AC3, 1.0 channels, 96kbps, 48kHz, dialnorm: -25dB) 5: Subtitle (PGS) 6: Subtitle (PGS) [a04] Extracting audio track number 4... [a04] Extracting TrueHD stream... [a04] Removing TrueHD dialog normalization... [a04] Decoding with libav/ffmpeg... [a04] [libav] Substream min channel cannot be greater than max channel. <WARNING> [a04] The libav decoder reported error -1 while decoding. <ERROR> Aborted at file position 1048576. <ERROR> Last edited by An IP BreAKDoWN; 19th January 2012 at 20:27. |
19th January 2012, 20:27 | #11508 | Link |
first you need to demux the thd from the m2ts:
eac3to 00001.m2ts 4:japanese.thd Code:
ffmpeg -i japanese.thd japanese.wav
if you ask a question and somebody give you the correct answer don't forget to leave a "thank you" note... Visit The Land Of Dracula (Romania - EU)! |
20th January 2012, 08:50 | #11510 | Link | |
You need: Code:
ffmpeg -i input.thd -acodec pcm_s24le output.wav Code:
eac3to input.wav -analyzebitdepth Last edited by TDiTP_; 20th January 2012 at 08:54. |
20th January 2012, 11:40 | #11511 | Link | |
One question though, how can I find the bit depth of the THD since the libav in eac3to can't open it since its a mono? Last edited by An IP BreAKDoWN; 20th January 2012 at 11:44. |
20th January 2012, 15:17 | #11512 | Link | |
20th January 2012, 22:40 | #11514 | Link | |
eac3to input.wav -analyzebitdepth |
21st January 2012, 05:25 | #11515 | Link | |
BTW, BDInfo can check bitdepth of THD incorrectly: look known issues. Of course, if libav of eac3to can't decode THD, then -analyzebitdepth does not make sense (because for determine bitdepth you need to decode). In this case you should try fresh ffmpeg. |
25th January 2012, 19:47 | #11516 | Link |
Back to basics question.
I've been using eac3to to join various audio files together. I have been doing it by hand as a commandline and it works well.
However I have a directory containing 37 mp3 files (all same params) that I want to join. A batch file would be nice, perhaps using IN DO, but my brain won't work, please somebody take pity... Thanks. |
25th January 2012, 22:16 | #11517 | Link | |
47.952fps@71.928Hz
I really haven't done anything like joining files in eac3to, but I do do some batch files. For doing multiple files, I just open a text file with the "eac3to" commands, copy and paste them several times. Going back and modifying only the input/output file names. And then exit at the very bottom. Note: I also have windows configured to open CMD in a folder, using the context menu: "Open Comand Promt here" Code:
"path\eac3to.exe" "sourcefile[+sourcefile2]" [trackno:] "[destfile|stdout]" [-options] "path\eac3to.exe" "sourcefile[+sourcefile2]" [trackno:] "[destfile|stdout]" [-options] "path\eac3to.exe" "sourcefile[+sourcefile2]" [trackno:] "[destfile|stdout]" [-options] exit I use "" if the path of my eac3to is in a folder with 2 words including a space "App Bin", and also some of the source files are in folders that contain spaces as well. I also add in custom logs. Code:
-log=custom_name_codec__etc_with_no_spaces_to_reduce_amount_of_quotes.txt Yet
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
26th January 2012, 03:06 | #11518 | Link |
OK. I've done it. I'm not a whizz at programming so it may not be very elegant but it works. If you want to use it just copy and paste into a batch file (set path to eac3to). Drop into a folder of mp3 files, double click and a single file of them all nicely joined will appear!
FOR %%a IN (*.mp3) DO echo/|set /p =" "%%~NXa"+" + >> temp.txt set /p inlist= <temp.txt set newlist=%inlist:~0,-1% path.to\eac3to.exe" %newlist% "Joined mp3 files.mp3" del temp.txt |
28th January 2012, 01:06 | #11519 | Link | |
Telewhining
30th January 2012, 03:38 | #11520 | Link |
Hi.
Does anybody know how to set SoX to handle the 64 floating point output from eac3to? Or in an other question, what kind of 64bit-Stream is eac3to giving out? I've tried a lot of commands but all I've got is noise and it sounds like playing a CD-ROM in an audio-player. This is the last command-line i've tried to pipe from eac3to to SoX: Code:
eac3to "test.ac3" stdout.wav -full -simple | sox -V3 --type .f64 --rate 48000 --encoding floating-point --bits 64 --channels 6 --ignore-length - -t wav --encoding floating-point --bits 32 result.wav "--type raw --rate 48000 --encoding floating-point --bits 64 --channels 6" -> Doesn't works too. Lot of noise. If i set "--type" to wav, SoX says: Code:
sox WARN wav: wave header missing FmtExt chunk sox FAIL formats: can't open input `-': Sorry, don't understand .wav size Code:
General Complete name : E:\Tools\eac3to\test.wav Format : Wave File size : 668 MiB Duration : 5mn 4s Overall bit rate mode : Constant Overall bit rate : 18.4 Mbps Audio ID : 0 Format : PCM Format profile : Float Format settings, Endianness : Float Codec ID : 00001000-0000-0300-8000-00AA00389B71 Codec ID/Hint : IEEE Duration : 5mn 4s Bit rate mode : Constant Bit rate : 18.4 Mbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 64 bits Stream size : 668 MiB (100%) |
eac3to |
