7th February 2009, 16:14 | #843 | Link |
н∂-αиαтι˘
chapters are not being detected correctly.
here is the log and mediainfo. http://www.mediafire.com/?sharekey=3...db6fb9a8902bda |
7th February 2009, 16:20 | #844 | Link |
Programmer (or just 教务长)
It is the first time I see such format of the chapters.
I have no files with chapters to test with, so you or someone else sent me such .txt file from mediainfo and chapter information looked totally different. *** I think it is fixed now in 337. Last edited by deank; 7th February 2009 at 16:22. |
7th February 2009, 16:43 | #850 | Link |
dear deank, many congratulations for your excellent program ! keep it up
I saw that you removed the "Change first SRT line timing" option from the tsMuxer menu (but is still on the tutorial). I had a similar problem with an .srt file these days... the first subtitle was starting on 32 ms and when I created the AVCHD folder with tsMuxer, subs didn't show up in PS3. Then I edited 32 ms and made it 300 ms and worked. I suppose you are doing something similar automatically. Please advise on this. I think that the subtitle language should be also available in the 'tsMuxer' tab, because now it is declared as 'und' in the tsMuxer meta file, that AVCHD uses. This would help non-English users a lot ! Thanks again for your excellent work ! I am expecting the custom titles and my donation is underway... |
7th February 2009, 16:46 | #851 | Link |
Custom titles work.
If you name your srt like ... movie name.LID.srt where LID is your language code (like gre) - it will be used and shown in player as Greek. SRT line timing option is moved to ADVANCED tab... I had no time to update the tutorial with the new tabs and options explanation. |
7th February 2009, 17:19 | #853 | Link |
To increase the number of donations, you may have to think about some 'marketing' issues. I know, you don't have time for this, but some of the early users should post more information about your great program in other forums.
As of today, your program is the only one which allows the storage of HDV (camcorder) movies on BlueRay disks with one single step and WITHOUT any re-coding! Most people don't know that re-coding takes time and some of the original quality! Make this known! FSNAVI |
7th February 2009, 17:22 | #854 | Link |
It is just that I didn't know if it will be so much interest in multiAVCHD - I'm glad of course...
I had to think of other ways to support my update server because of the heavy traffic. I'm not into marketing and stuff... I posted about multiAVCHD in one or two forums... and that's it. I'll think about it. Thanks. Dean p.s. May be this "multi- part in the name or the multiple blablabla in one structure" are not clear enough... because multiAVCHD can be used for single files and folders to do all needed transformations... |
7th February 2009, 17:37 | #855 | Link |
Hello Dean,
It's the first time that I try to work with this format - a VC1HD-DVD .ts file. And multiAVCHD don't recognised it. This is the analysis report of the file: Opening: H:\FILMS\XXX HD.ts Opening File... Video Loaded. Auto Finding PIDs PID Attribute List: PID: 0x1011: VC-1 Video: 1920x1080 @ 23.976 PID: 0x1100: AC3: 2/0: L,R 48KHz 80Kbit/s PID: 0x1101: AC3: 3/2.1: L, C, R, SL, SR, LFE 48KHz 448Kbit/s PID: 0x1102: DTS: 3/0: L, C, R 16 bits 48KHz 1536Kbit/s Scanning For Format Changes File size: 22980936888 Bytes Video Resolution from Codec: 720 x 480 @ 29.97 fps Duration from Codec: 7423.01 Duration from Timestamps: 7427.39 Average System Bitrate: 24752652.18 Is it normal? Or some codecs are missing? Thanx! |
7th February 2009, 17:37 | #856 | Link |
Thanks for your comments deank !
You can always use a more catchy title like "AVCHD Workshop", "HD Maker" etc The program is getting much attention in the Greek forums as far as I know, and a lot of people are expecting the custom title feature. Keep it up ! |
7th February 2009, 17:40 | #857 | Link |
@vpapanik: Thanks... And as I said earlier - custom menu/titles work... and I'd rather keep the name "multiAVCHD".
@xeniste: can you send me the output from mediainfo, not from ts packet editor? Last edited by deank; 7th February 2009 at 17:43. |
7th February 2009, 17:46 | #858 | Link |
Sorry, I was not clear, I meant the Custom Menu Title Names Editor...
Do you have any idea where I can find a custom background to test 'Custom Menu'. Or at least the resolution required. Thanks a lot |
7th February 2009, 18:00 | #859 | Link |
You can put any JPG/JPEG/BMP file for background... it will be resized...
Or.. search GOOGLE for images Click here and you will see multiAVCHD background Last edited by deank; 7th February 2009 at 18:02. |
