17th September 2011, 15:32 | #12981 | Link |
Thats just it, i havent. After the abort the only thing i did was launch BDRB and hit backup again. So it should have resumed. I noticed that BDRB had reselected streams to be blanked that i have previously UNSELECTED prior to starting the backup process in the first place. So it seems BDRB doesnt remember the streams blanked correctly
17th September 2011, 16:19 | #12982 | Link | |
In order to save those settings I'll have to put the selection list into the INF file so it will reset your changes to the default selections when you resume. The problem is that on some of these discs the string in the INF might be 500 characters long. Last edited by jdobbs; 17th September 2011 at 16:22. |
17th September 2011, 16:41 | #12984 | Link | |
I ended up using -> http://forum.videohelp.com/threads/3...srt-or-sub-idx to pull the subtitles and convert to an SRT. Yup the OCR is horrible, but thankfully, for forced subs, there isn't much there so the effort needed isn't too bad However that post you linked to says you can do multiple audio tracks. its discussed in the next few posts there too.. So I'm guessing that it still doesn't work? or am I doing something wrong? Last edited by Mark_Venture; 17th September 2011 at 16:44. |
17th September 2011, 18:19 | #12987 | Link | |
Former Kanenite
----------------------- [09:25:56] BD Rebuilder v0.39.01 (beta) - Source: BSG_THE_PLAN - Input BD size: 38.64 GB - Approximate total content: [03:04:30.092] - Target BD size: 22.90 GB - Windows Version: 6.1 [7601] - Quality: High-Speed Option (BD-25), Two Pass - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [09:25:56] PHASE ONE, Encoding - [09:25:56] Processing: VID_00096 (1 of 13) - [09:25:56] Extracting A/V streams [VID_00096] - [09:25:57] Reencoding video [VID_00096] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 1,119 frames - Inverse Telecining in effect (IVTC) - [09:25:57] Reencoding: VID_00096, Pass 1 of 1 - [09:26:03] Video Encode complete - [09:26:03] Reencoding audio tracks (if req'd) - [09:26:03] Multiplexing M2TS - [09:26:04] Processing: VID_00094 (2 of 13) - [09:26:04] Extracting A/V streams [VID_00094] - [09:26:05] Reencoding video [VID_00094] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 1,353 frames - Inverse Telecining in effect (IVTC) - [09:26:05] Reencoding: VID_00094, Pass 1 of 1 - [09:26:12] Video Encode complete - [09:26:12] Reencoding audio tracks (if req'd) - [09:26:12] Multiplexing M2TS - [09:26:12] Processing: VID_00093 (3 of 13) - [09:26:12] Extracting A/V streams [VID_00093] - [09:26:14] Reencoding video [VID_00093] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 1,512 frames - Inverse Telecining in effect (IVTC) - [09:26:14] Reencoding: VID_00093, Pass 1 of 1 - [09:26:21] Video Encode complete - [09:26:21] Reencoding audio tracks (if req'd) - [09:26:21] Multiplexing M2TS - [09:26:22] Processing: VID_00095 (4 of 13) - [09:26:22] Extracting A/V streams [VID_00095] - [09:26:24] Reencoding video [VID_00095] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 2,160 frames - Inverse Telecining in effect (IVTC) - [09:26:24] Reencoding: VID_00095, Pass 1 of 1 - [09:26:34] Video Encode complete - [09:26:34] Reencoding audio tracks (if req'd) - [09:26:34] Multiplexing M2TS - [09:26:34] Processing: VID_00086 (5 of 13) - [09:26:34] Extracting A/V streams [VID_00086] - [09:26:37] Reencoding video [VID_00086] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 4,084 frames - Inverse Telecining in effect (IVTC) - [09:26:37] Reencoding: VID_00086, Pass 1 of 1 - [09:26:56] Video Encode complete - [09:26:56] Reencoding audio tracks (if req'd) - [09:26:56] Multiplexing M2TS - [09:26:57] Processing: VID_00092 (6 of 13) - [09:26:57] Extracting A/V streams [VID_00092] - [09:27:00] Reencoding video [VID_00092] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 5,002 frames - Inverse Telecining in effect (IVTC) - [09:27:00] Reencoding: VID_00092, Pass 1 of 1 - [09:27:22] Video Encode complete - [09:27:22] Reencoding audio tracks (if req'd) - [09:27:22] Multiplexing M2TS - [09:27:24] Processing: VID_00062 (7 of 13) - [09:27:24] Extracting A/V streams [VID_00062] - [09:27:27] Reencoding video [VID_00062] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 1,560 frames - [09:27:27] Reencoding: VID_00062, Pass 1 of 1 - [09:27:55] Video Encode complete - [09:27:55] Reencoding audio tracks (if req'd) - [09:27:55] Multiplexing M2TS - [09:27:57] Processing: VID_00097 (8 of 13) - [09:27:57] Extracting A/V streams [VID_00097] - [09:28:02] Reencoding video [VID_00097] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 9,881 frames - Inverse Telecining in effect (IVTC) - [09:28:02] Reencoding: VID_00097, Pass 1 of 1 - [09:28:47] Video Encode complete - [09:28:47] Reencoding audio tracks (if req'd) - [09:28:47] Multiplexing M2TS - [09:28:50] Processing: VID_00089 (9 of 13) - [09:28:50] Extracting A/V streams [VID_00089] - [09:29:51] Reencoding video [VID_00089] - Source Video: VC-1, 1920x1080 - Rate/Length: 29.970fps, 7,290 frames - [09:29:51] Reencoding: VID_00089, Pass 1 of 1 - [09:34:42] Video Encode complete - [09:34:42] Reencoding audio tracks (if req'd) - [09:34:42] Multiplexing M2TS - [09:34:57] Processing: VID_00088 (10 of 13) - [09:34:57] Extracting A/V streams [VID_00088] - [09:36:23] Reencoding video [VID_00088] - Source Video: VC-1, 1920x1080 - Rate/Length: 29.970fps, 12,345 frames - [09:36:24] Reencoding: VID_00088, Pass 1 of 1 - [09:44:25] Video Encode complete - [09:44:25] Reencoding audio tracks (if req'd) - [09:44:25] Multiplexing M2TS - [09:44:56] Processing: VID_00087 (11 of 13) - [09:44:56] Extracting A/V streams [VID_00087] - [09:46:11] Reencoding video [VID_00087] - Source Video: VC-1, 1920x1080 - Rate/Length: 29.970fps, 12,240 frames - [09:46:12] Reencoding: VID_00087, Pass 1 of 1 - [09:54:09] Video Encode complete - [09:54:09] Reencoding audio tracks (if req'd) - [09:54:09] Multiplexing M2TS - [09:54:22] Processing: VID_00090 (12 of 13) - [09:54:22] Extracting A/V streams [VID_00090] - [09:55:08] Reencoding video [VID_00090] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 27,423 frames - [09:55:08] Reencoding: VID_00090, Pass 1 of 1 - [10:05:00] Video Encode complete - [10:05:00] Reencoding audio tracks (if req'd) - [10:05:00] Multiplexing M2TS - [10:05:25] Processing: VID_00010 (13 of 13) - [10:05:25] Extracting A/V streams [VID_00010] - Error in attempt to extract audio/subs. - SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net [10:09:12] - Failed to retrieve audio, aborted |
17th September 2011, 20:45 | #12989 | Link |
@JD: Just finished testing FF5 (even though it had DTS-E), i must say that although BDRB didnt remember the blankin settings and i had to rerun the job the blanking itself performed PERFECTLY with a 1 minute timer. No annoying trailers whatsoever. Excellent work
17th September 2011, 20:57 | #12990 | Link |
I get the feeling, that if I run either dark city, or drag me to hell with "FORCE_NOENCODE", while blanking one title, and then run the output back through the program, it's still gonna compress the remaining title. I haven't attempted it yet. But I have a feeling, that's where you're gonna discover what's going on. E.g. something else needs to be blanked with the title. Whatever is referencing the blanked title, also needs to be blanked(or simply adapt the code to be aware of this). Sorry I can't be more specific. I really don't know much about this stuff :S
Well I'll be damned... I'm looking at a very high bitrate for encode #2. I'm rerunning the output which was 24Gb with "FORCE_NOENCODE" set, and blanked one of the titles. So i'm not sure why it can't do the job correctly in encode #1, but a second encode might just work. I may be jumping the gun here, but the bitrate for remaining title is VERY high, I feel good about this one I suppose I could have removed some audio tracks, and would have not needed the second encode. Or an encode at all What can I say, i'm picky. Worked like a charm for "Dark City". I guess until the code can be updated, I'll be running titles like this one twice. Which isn't really a big deal. Because the first process requires no encoding, it doesn't take long. Blank the unwanted stuff, and then reload the output and start process 2. I wonder how the blanking is going for others though. E.g. are they finishing it all in one process, and getting the expected output size? Last edited by omegaman7; 18th September 2011 at 03:58. Reason: Verdict! |
18th September 2011, 15:32 | #12991 | Link | |
1. Do a Movie Only backup with all English subs. (Unless you want a blu ray backup as well I set the output size at 60GB so no re-encoding is done. Faster that way). 2. Use BDSup2Sub to examine the subtitile files (they should still be in the BDRB /Workfiles folder) to determine which one contains the forced subs. 3. Create .mp4 (or .mkv) output with RibBot264. (Use the single .mt2s file made in step one as the input.) One of the settings for each job is which subtitle track to include. Just pick the one you identified above. The rest just set up according to what sort of output you want. Mediainfo will not show any subtitles because it burns them into the video stream. A couple of limitations: It's considerably slower than BDRB on my machine, and as far as I can tell you can only select one audio stream. It has worked fine for me with titles such as Avatar, Taken, Tourist, Da Vinci Code and others. |
18th September 2011, 17:30 | #12992 | Link |
Update on FF5, the rebuilt disc jammed arround 36minutes. Something probably got blanked that shouldnt have been. The burnt double layer ISO from AnyDVD skipped past the problematic spot without a problem. I'll be running a new encode now. That being said the 2nd job i ran "Cop Out" performed flawlessly (though i did apparently have it blank the menu background, the menu itself was unaffected and behaved like it should)
18th September 2011, 19:42 | #12993 | Link |
I've just converted a BD50 to BD25 (best quality), and the audio seems to start ok, but it goes out of sync towards the end of the episode. Is this fixable or is it worth converting again?
Thx Last edited by Tripledrop; 18th September 2011 at 19:45. |
18th September 2011, 21:04 | #12994 | Link |
Could be I'm having a thick-o day (even more so than usual) but v0.39.01 is acting somewhat peculiarly.
I have not added ENABLE_TEST=1 to the .INI file. I tried to do a full backup of Citizen Kane (US) but BD-RB lists only the main movie in both Full Backup and Movie-Only Backup modes. v0.38.09 lists 7 items in Full Backup mode: VID_00020 (AVC 1080p Main Movie) 29 387,99 MB VID_00055 (AVC 480i) 189,59 MB VID_00060 (AVC 480i) 290,33 MB VID_00063 (AVC 480i) 156,52 MB VID_00073 (AVC 480i) 42,17 MB VID_00074 (AVC 480i) 8,10 MB VID_00075 (AVC 480i) 192,66 MB v0.39.01 lists only VID_00020, no matter what I try. |
18th September 2011, 21:29 | #12995 | Link |
@jagjockey
Best guess is that some other program has intercepted the AVC codec. Unistall BD-RB and its helper apps. Then, if you have any CODEC packs installed remove them (they aren't needed -- FFDSHOW has all the CODECs anyone needs). Then reinstall BD-RB and its apps again carefully following the instructions in the first post of this thread. |
18th September 2011, 22:08 | #12996 | Link | |
Movie-Only always shows only the main movie. Last edited by jdobbs; 18th September 2011 at 22:11. |
19th September 2011, 09:30 | #12999 | Link |
OK, now I'm totally confused (not hard to achieve, admittedly). In Full Backup mode (of Citizen Kane), 0.38.09 lists 7 items, while 0.39.01 lists only 1 item. Is that how it's supposed to be?
19th September 2011, 15:45 | #13000 | Link | |
Here's the bottom line... when you run that disc --- does it work? Does it look a good as the original? We're squabbling about minutia here that is of virtually zero importance. Leaving a few hundred megabytes intact on a 25GB target is rounding figures. BD-RB has always done this selection analysis to provide better speed and compatibility. Now it just does it better. BD-9 output, however, it another matter. Since the original's maximum bitrate is too high and the target is too small, BD-RB doesn't have the luxury of deciding to leave some things intact. Instead it has to go through a whole list of additional hoops (like going through the entire target M2TS -- resetting DTS, PTS and other timing codes when the "leave alones" are reencoded). That's especially true when there is an out-of-mux substream that is interactive. That takes time and increases risk. Last edited by jdobbs; 19th September 2011 at 15:57. |
