1st November 2007, 07:21 | #1803 | Link |
You can demultiplex EVO file with Elecard XMuxer.
www.elecard.com |
2nd November 2007, 22:05 | #1804 | Link | |
Or you can do it for free with Evodemux. |
8th November 2007, 05:46 | #1806 | Link | |
However, once this is done, scenarist complains that FrameRateCode is not BD compliant. Im not exactly sure what FrameRateCode is, as it doesnt appear to be a part of the header structure. I used h264info to force a 30fps frame rate with no effect. same with 60fps. Also, playing the raw stream gave some dropout frames and some garbled frames. Not sure where to go from here to fix the timing issues. |
8th November 2007, 08:32 | #1807 | Link | |
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net |
8th November 2007, 11:05 | #1808 | Link |
Now I'm getting errors when I want to load the demuxed and rebuild evo into the haali media splitter in the Graphedit, but the original evos work...
Filter failed to load file. Der Medientyp dieser Datei ist unbekannt (Return Code: 0x80040240) (Mediatype is unknown) Last edited by d0ORk; 8th November 2007 at 11:15. |
8th November 2007, 15:45 | #1809 | Link | |
I looked into that. Scenarist complains about "FrameRateCode". I checked the fixed_frame_rate_flag and it was set properly. Elecard makes a nice utility to display the current state of all the header flags (Stream Analyzer). |
9th November 2007, 19:40 | #1810 | Link | |
Anybody knows what are the BD compliant frame rates. A program to see the framerate of a avc elementary stream would also help. Seems like stream analyzer does indeed not show this. |
11th November 2007, 07:32 | #1811 | Link | |
I am pretty sure transformers is 1080p60. I tried to force 30 and 60fps using h264info, with and without 3:2 pulldown, but it continued to be noncompliant. One thing was curious - after forcing different frame rates, the frame related headers always stayed the same: timing_info_present_flag = 1 num_units_in_tick = 1001 time_scale = 60000 fixed_frame_rate_flag = 1 Maybe if these were changed using a hexeditor... I just dont know exactly what the values mean. |
12th November 2007, 15:54 | #1814 | Link | |
I've been struggling for some time now trying to feed MeGui this track using evodemux and evo-demux. Also, evodemux doesnt seem to rebuild the track correctly (when merging the two evobs) |
12th November 2007, 21:02 | #1816 | Link | |
Ill have to get back here to give full detail about the connections that fail and the megui error. |
12th November 2007, 21:12 | #1817 | Link | |
One thing that is "special" about this release is that there is an VC-1 imbedded for the picture in picture stuff but it is seen as a separate track in evodemux so when you extract only the main AVC movie there should be nothing left out of the VC-1 720x480 PIP stream but who knows? |
14th November 2007, 11:54 | #1818 | Link | |
I have the same issue with 4 mixed m2ts. My SetTopBox played only the first .ts and stop after. In the m2ts, there are MPEG2 and DD5.1. |
14th November 2007, 21:59 | #1819 | Link |
it's been a while since i've toyed with manipulating evo files...could someone refresh my memory on which filter one should use as source before say, the sonic HD demuxer? file source (async) isn't it, is it? thanks for the assist.
