Old 3rd July 2017, 17:49   #161  |  Link
Ghitulescu
Ghitulescu's Avatar
I simply do not understand why I can add a blank cell 2/1 following eg 1/13, but it is beyond the scope of PGCedit to have it named as 1/14.
Born in the USB (not USA)
Old 3rd July 2017, 19:22   #162  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Because 1/14 MUST be a part of the VOB 1, and it's not the case, as I've explained above. The new cell is totally independent, and MUST therefore have a new VID. I can give it 3/1 if you wish (but VID 2 will be missing and it's not a good idea) but I can't give it VID 1, already used by VOB 1. And since a new VOB must be created, its cell is cell 1, and must therefore have CID 1.
Do not be confused by VOB (Video Object) and VOB file, the extension of the file or files containing one or several VOBs. What PgcEdit does is to create a new Video Object, and append it to the (last) VOB file of the domain. It cannot modify an existing VOB by adding a new cell to the VOB. That's simply not possible without very complex tools.
Anyway, if you really want to change the VID and CID of the cell added by PgcEdit, you can do it with VobEdit. That's easy since there is only one nav pack in the short cell. But you cannot do that, as you will not have the correct structure. IfoEdit and VobEdit let you do anything, including totally illegal things, therefore you can try to do it anyway. But of course do it at your own risk. Your DVD will be totally illegal and you will probably have severe playback issues.
r0lZ
Old 4th July 2017, 10:27   #163  |  Link
Ghitulescu
Ghitulescu's Avatar
Maybe I am wrong but the way I understand the specs is that blank cells do not have any payload and consequently it doesn't matter whether they are or not part of the existing PGC/VOB (not as files but as concepts) since they are automatically compatible with anything before or after them.
A PGC is just a table comprising indexes.
You are right in what the actual file and object must be, but as I said, a blank cell should not pose any issue to the existing video objects.
I also understand it's a bit of work to be done in actualising several tables - it would have been nice ....
Old 4th July 2017, 13:09   #164  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
The blank cells are indeed compatible with anything before and after them IF and ONLY IF they are separate video objects, and therefore they must have a new VOB ID. Otherwise, the timecodes will suddenly jump to incompatible values within the current VOB and the player may crash or may at least be confused. And that's only an example of the many bad things that can occur.
The PGC is relatively easy to modify to add a new VOB, or even to reference a new cell in an existing VOB, but the other tables must be actualized, and some of them may be tricky to modify and may require to scan the whole VOB. It's a big job, and I don't want to do it just so that you (and probably only you) can do illegal/incompatible things.
I must also add that I don't understand why you need that feature. You wrote:
Originally Posted by Ghitulescu View Post
This artificially logically adds a new "segment" - and some other programs interpret this as two parts (like eg main feature and its trailer or studio/authorhouse logo - there are commercial DVDs employing this scheme).
Indeed, sometimes, a new VOB is created by commercial programs for obscure reasons, but a new VOB MUST also be created when the angle changes, and many authoring programs add it also at the layer break position. That means that the division of a single movie into several VOBs is frequent and must NEVER be a problem, as otherwise many commercial DVDs would not work correctly. If you use a program that supports only a single VOB, that means that it has a big bug, and you should ask its programmer to fix it. It's not the job of PgcEdit to implement complex workarounds for badly programmed apps.
r0lZ
Old 4th July 2017, 19:33   #165  |  Link
Sir Didymus
...Maybe I am wrong but the way I understand the specs is that blank cells do not have any payload and consequently it doesn't matter whether they are or not part of the existing PGC/VOB...
Indeed, your understanding is shallow. Using your terminology, cells without "payload" simply do not exist on real DVDs. Of course when they are properly authored. Even when a cell is "blank", it must be always, by definition, a playable unit. Different is the case when bad (or totally screwed) authoring is in place intentionally to implement copy protection schemes. Infact, programs such as PgcEdit and others are able to add consistently blank cells to the PGCs of DVDs as new VOBs. These cells are blank, but not void: they contain a single playable VOBu, including a NavPack, a single GOP composed by a single I-frame consisting of a black picture and (I think) some padding bytes.
Apart the above details, I am fully in line with the answers already provided by r0lZ on the matter: there is no point to enable PgcEdit to create rubbish...
Sir Didymus is offline   Reply With Quote
Old 5th July 2017, 09:01   #166  |  Link
Ghitulescu
Ghitulescu's Avatar
I only asked nicely if it is possible to do this.
To my knowledge, there is possible to have cells without any payload as it is possible to have VOBUs with no video.
It is also not forbidden to refer (almost) any offset from (almost) anywhere - yes, this is usually used in copyright protection schemes (I think).
So, if it is too much work I would not insist, of course. I thought that this would have required a simply daisy-chaining of pointers to the next full/empty VOBU.
I do not understand however why this is "illegal", or "rubbish"...
I am sorry I caused this misunderstanding... feature request withdrawn with immediate effect.
Thank you for your good work
Old 5th July 2017, 09:14   #167  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
No problem. I only tried to explain why I don't want to do it. And again, if some programs are not compatible with multi-VOB PGCs, then that programs are responsible of your problem, not PgcEdit. The short cells currently implemented in PgcEdit are fully compatible with the DVD-Video specs (hence the term "legal") and they should work with all players or programs. I see no reason to implement (with difficulty) things that are most probably "illegal" or, at least, dangerous.
@Sir Didymus: Thanks for your support. :-)
r0lZ
Old 5th July 2017, 10:10   #168  |  Link
Sir Didymus
This statement is totally wrong, and it is based on an implication using a very weak logic.
It is true that it is possible to have legit VOBUs without video, but they must be (always and in any case) playable units.
So, as "void VOBUs" do not exist, since they must have at least a Navigation Pack and some other digital information and padding bytes, physically readable by the laser spot of the DVD reader, for the same reason "void cells" or "cells without payload" are just ideas which do not exist in real DVD, and that cannot by supported by any technical specifications. So, these "void cells" are illegal stuff. Again, blank cells are not "void" cells!
Creativity is nice. Specs and DVD compliancy is another thing.
P.S. There was no intention to sound offensive in my post above. The term "rubbish" was used just to designate inconsistent stuff, badly organized concepts, and similar things, to stay definitely away from... OK?
Old 5th July 2017, 11:06   #169  |  Link
Ghitulescu
Ghitulescu's Avatar
I am finishing this discussion since it's clear that I was not understood
I was not discussing a cell without anything, SIZE: 0, as you think I wanted.
I was was discussing a cell that has all the attributes of a normal cell (as seen by the player), including the navigation tables, but no true content (as seen by the user). This way the original video structure (as seen by the file system) remained unchanged, only the sequence of pointers in the navigation could have been slightly changed.
And such cell can, besides, be placed anywhere in the chain, for the sequence of cells (as seen by the file system) does not necessarily need to be consecutive and can comprise gaps. It's maybe bad programming/authoring, but not illegal. That's the whole reason of having pointers in the first place.
But as I said, I do not want this anymore. It's kind enough that someone created such a software in the first place...
Old 5th July 2017, 11:19   #170  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
OK, thanks for understanding. I close this discussion too.
r0lZ
Old 5th July 2017, 12:28   #171  |  Link
Sir Didymus
Yes, Gitulescu, r0lZ. I also agree to refrain going on with this discussion. Let me just add (and this will be my last post here) that apparently Ghitulescu assumes that Navigation Information and the other PLAYABLE content of a cell is only stored in the IFO files. It isn't. Indeed the most relevant part of it is stored in the VOB files... Even for blank cells and also for VOBUs without video content...
Old 6th July 2017, 11:02   #172  |  Link
Ghitulescu
Ghitulescu's Avatar
That is an incorrect deduction...
I referred initially strictly to a PGC, but the function there is named "Create new cell" and the discussion deviated into another domain. Therefore the discussion went into two paths, I discussing the logical addressing and r0lZ the file system one (the two are indeed weaved). I do not know how one came to the conclusion that I meant the content (maybe there is a problem in defining what content is - I meant here the payload, the PES streams of audio, video and subtitles; but not the cell's identification) of a cell to be in IFO ...
I thought the implementation would have been a straight one, since in both cases (new different VID vs. new identical VID) the same tables had to be modified in IFO and the same navigation packet had to be identically changed. It appears I was wrong.
That was just to clarify the things (at least for me).
Sorry for any inconvenience caused.
Old 4th August 2017, 17:26   #173  |  Link
neil wilkes
neil wilkes's Avatar
Originally Posted by r0lZ View Post
... and to you and Wombler for your patient work on the manual, and to all beta testers for their wonderful job!
I would like to thank also all donors. Thanks to them, I am still motivated to continue to develop PgcEdit, although some additional donations are still welcome!
You're more than welcome - I find PGCEdit absolutely invaluable in daily use and it solves a number of issues in both Scenarist SD & DVD-Lab Pro 2.
I just wish there was a DVD-Audio equivalent tool.
www.opusproductions.com
Multichannel Audio Productions
DVD-Audio/Video Authoring specialists
neil wilkes is offline   Reply With Quote
Old 5th August 2017, 07:44   #174  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
And sorry for not working on a DVD-Audio editor. AFAIK, only a few DVD-Audio discs have been produced, and IMO it is not worth doing something like PgcEdit for them.
r0lZ
Old 5th August 2017, 11:07   #175  |  Link
neil wilkes
Absolutely no apologies necessary - there are probably under 5,000 out there in total so I completely understand and it is almost impossible to get the actual specs without spending scads of cash too.
The authoring tool we use is extremely robust though (Sonic/MEI DVD-Audio Creator) and all the problems are usually with the associated Video_TS rather than the Audio_TS anyway.
PGCEdit rocks and I get an awful lot of use out of it, and consider my donations up there with the best money I have ever spent.
Old 28th November 2019, 01:38   #176  |  Link
david42
Former Technical Janitor
PgcEdit PGC Editor Title1 : First ILUV End column has non 0 values
Sorry if I am putting this message into the wrong part of the forum but it's been over 4 years since I've used the forum.
I am using Pgcedit (newer than v9.3) and having trouble with a DVD movie reauthor because the main movie (title1) has several cells which have something other than 0 in the "First IVLU End" column as I scroll down through the chapters.
Usually I would select the Delete Angles button to try to fix this but if I do that no angles are found and it does remove cells, which have non 0 IVLU End values, AND also throws away the part of the movie that was in those cells.
I would appreciate if a kind soul could give me directions on how to fix this type of problem in a DVD because I do see it every once in a while.
Is there some way PgcEdit , VOBBlanker, VOBEdit, or IfoEdit can be used to fix this? I've used those programs for simple things but this problem has me lost like a newbie in the maternity ward.
BTW: All of the programs I list are awesome!
THANX
david42 is offline   Reply With Quote
Old 28th November 2019, 12:45   #177  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Not sure why you want to fix this. Non-zero ILVU End values are OK in a multi-angle DVD. I don't know why some parts of the movie are lost when you remove the angles. Perhaps a new form of protection ? Anyway, if the DVD works correctly, I suggest to leave it as it is. Otherwise, have you tried FixVTS ? Usually, it gives good results, but it works in place, so be sure to apply it on a backup.
r0lZ
Old 30th November 2019, 07:20   #178  |  Link
david42
PgcEdit Start IVLU End non 0 cells issue
There is only 1 angle in this movie (the angle column has no numbers in it).
I used vobblanker because dvdshrink found unreferenced cells left in byb fixVTS. The original movie plays back a bit unstable in the non 0 IVLU cells. Also if I (do not vobblank it) my next step is dvdshrink but it finds unreferences menu and video. It's the dvdshrink unreferenced cells issue that made me ass/u/me I needed to go back to PgcEdit and try to PGC Edit the movie title so I can select delete angle (even though there are no angles it does get rid of some of the non 0 IVLU cells [some of which should NOT be deleted]) next I run vobblanker to get rid of the (dvdshrink unreferenced video) material so there are no unreferenced videos in dvdshrink.
The movie total play time doesn't seem to change (strange) even though I run "Remove Useless Stuff" before going from PgcEdit to DVDShrink.
I'm confused about what to do. It would appear to be a protection that the logs in RipIt4Me doesn't show (usually it would insert useless packets if something was wrong with the rip from the DVD itself).
I'm not sure what specifics you need and how I would even do screen shot replies in the forum.
Any ideas (bearing in mind my skill level is low-medium) would be appreciated; as always.
Last edited by david42; 30th November 2019 at 07:30. Reason: forgot to answer fixvts suggestion in 1st reply version
Old 30th November 2019, 09:05   #179  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Hum, sorry, but I don't have enough info to understand the problem. I guess the non-zero First ILVU End value is there to skip the end of the cell, perhaps when it has read-errors for the protection. I don't remember how it works exactly, but DVDShrink should simply ignore that unplayable parts and remove them from the shrunk DVD.
r0lZ
