28th February 2010, 21:08 | #602 | Link |
One other point: the --profile and --tune don't seem to pass through (not a big deal, you can set those options manually)
And what is the difference between "extra options" box, vs. the "use command line" box in the GUI ? |
28th February 2010, 21:12 | #603 | Link | |
"use command line" use only him parameters and ignored gui parameters |
28th February 2010, 21:14 | #604 | Link |
poisondeathray
This options not supported in vfw: FRAMES/SEEK/MUXER/DEMUXER/INDEX/QPFILE/THREAD-INPUT/NOPROGRESS/VISUALIZE/TUNE/PRESET/PROFILE/SLOWFIRSTPASS "use command line" disable all GUI-options and use only what you enter in edit-box. "extra options" append you entered options to GUI-option. |
28th February 2010, 21:25 | #606 | Link |
poisondeathray, you may use "--log-file c:\mu_encode_log.txt" (also --log-file-level supported)
from cli-help: Code:
--log-file <string> Save log to file --log-file-level <int> Log-file level information [2] |
28th February 2010, 21:27 | #607 | Link |
They probably would be supported after I make redesign of interface (where profile/preset/tune would be part of interface but most of other options would probably discarded [for advanced user there is command line options]).
1st March 2010, 06:27 | #610 | Link |
Yes it's definitely looking like that (with the few exceptions that komisar listed several posts above). Need to do some more testing to be sure, and it still needs to be verified by a strict BD verifier. (NAL-HRD patch seems to being very close to officially being commited too)
2nd March 2010, 18:30 | #612 | Link | |
14th March 2010, 17:38 | #613 | Link |
I'm currently encoding 720p30 in real-time in VirtualDub into x264vfw (Bugmaster's last build) on an i7 920 PC. I am using default settings but with CABAC disabled. With CABAC enabled, I drop a lot of frames I'm trying both CRF at around 25, and also with set bandwidth of 5mbps.
Bearing in mind it's real-time, it's VFW, it's AVI etc, I'm pleasantly surprised by the quality level but what settings could I work with to improve quality? Also, is there a DirectShow x264 encoder available as fully featured as x264vfw? I'd imagine the option to deal with dual frames simultaneously could improve efficiencies? |
14th March 2010, 19:52 | #614 | Link | |
As for DirectShow x264 encoder the only one I am aware is MONOGRAM x264 Encoder (1.0.5.0) |
14th March 2010, 20:13 | #615 | Link |
Edit: I've switched to the x264 implementation in ffdshow and can achieve 720p30 real-time capture comfortably with CABAC and lots of other goodies in VirtualDub. I'm using LAME at 192kbps for MP3 compressed audio. The .avi files run fine even in Windows 7 media player.
The only issue I find is that the audio needs to be set +500ms in order to be in sync with the video - something not required with x264vfw. Last edited by easy2Bcheesy; 15th March 2010 at 17:50. |
12th April 2010, 10:19 | #618 | Link |
Derek Prestegard IRL
A request, if anyone is maintaining this code:
It would be helpful if in one pass ABR mode, the GUI allowed for target bitrates over 20mbps. I would like up to 100mbps if at all possible. Though I usually just use CRF, ABR/CBR can be useful in certain scenarios ~MiSfit
These are all my personal statements, not those of my employer :) |
13th April 2010, 00:00 | #620 | Link | |
x264vfw_21_1538bm_22856 x264vfw64_21_1538bm_22856 I added pseudologarithmic slider for ABR with bitrate from 1 to 999999 kbit/s. Hope this would be enough for anyone . |
