15th June 2006, 05:44 | #161 | Link |
AviSynth plugger
No, but here is simple fps doubler (from 15 to 30):
data = DePanEstimate() f1_2 = DePan(data=data, offset=1./2) Interleave(f1_2,last)
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
15th June 2006, 15:37 | #162 | Link |
Huh?
How about from 15fps to 23.976? Would something along the lines of:
i=last data=DePanEstimate(i,range=1,trust=5) f=DePan(i,data,offset=x) b=DePan(i,data,offset=-x) Interleave(f,i,b) SelectEvery(???)
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. |
15th June 2006, 17:47 | #163 | Link |
AviSynth plugger
Look to fps conversion examples in DePan doc and try understand them.
15th June 2006, 22:22 | #164 | Link |
Huh?
I'm not being lazy, the framerate changes appear out of the blue in the readme, and the only two examples (2-to-3 and 3-to-5) are too different for a common template to be extracted from them. About the only thing I see in common is that both examples create some kind of backward and forward information, but that's it.
16th June 2006, 05:35 | #165 | Link |
Here's some code I used quite awhile ago. Haven't tested it with the latest version. However, it worked when I last used it. Hopefully it will help you fill in the gaps in your knowledge and get you going.
#Slow motion loadplugin("c:\Program Files\AviSynth 2.5\plugins\depan.dll") AVISource("E:\Volleyball\Volleyball (Soldedad)\Volleyball (soledad)0022.avi") converttoYV12() AssumeBFF() fps3to5() function fps3to5(clipYV12) { # change FPS from 3 to 5 (or 15 to 25, or 18 to 30 and so on), i.e. with factor=5/3 # uses global motion compensation # input must be YV12 progressive (or separated fields probably ?) SeparateFields(clipYV12) data = DePanEstimate(clipYV12) t3_5 = DePan(clipYV12, data, offset=-2./5) t6_5 = DePan(clipYV12, data, offset=1./5).trim(2,0) t9_5 = DePan(clipYV12, data, offset=-1./5).trim(1,0) t12_5 = DePan(clipYV12, data, offset=2./5).trim(3,0) Interleave(clipYV12, t3_5, t6_5, t9_5, t12_5) SelectEvery(15,0,1,2,3,4) weave() } |
16th June 2006, 16:25 | #166 | Link |
Huh?
Thanks, but that 3-to-5 example is in DePan's readme, and the only other example (2-to-3) is much too different to extract a general framework from them.
16th June 2006, 16:43 | #168 | Link |
Huh?
Not exactly, I need a 15-to-23.976 script that doesn't result in the need of resampling/repitching the source audio.
16th June 2006, 18:16 | #170 | Link |
Huh?
I assume 15-to-29.97 won't workt with DePan either, am I stuck with duping/interpolating frames with ChangeFPS then?
17th June 2006, 02:06 | #172 | Link |
Huh?
You mean extrapolation to 150fps and then ChangeFPS(23.976), right? And what should I use for the extrapolation?
17th June 2006, 19:37 | #175 | Link | |
Huh?
[edit]If the final conversion is going to be to 23.976, would it benefitial to do the up-interpolation to 120fps instead?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. Last edited by Chainmax; 17th June 2006 at 21:48. |
19th June 2006, 03:41 | #177 | Link |
Huh?
But 119.88 (120) is a multiple of 23.976 (24), whereas 150 is not. Does that not make a difference when the filter tries to calculate which of the up-interpolated frames to discard?
19th June 2006, 12:11 | #178 | Link |
That's why sharfis is not talking of an exact convertion, he says you'll have remaining jerkiness. With the depan way as I understand from sharfis and the 3to5 script, you can only divide by decimal numbers the gap between 2 frames to introduce the interpolated ones. This is not compatible with 15 to 23.976 (or more precisely 24000/1001, and this is not an decimal number)
Have a look in the avisynth doc to what changefps does... You'll see why with the depan method "the more up-interpolation, the less the remaining jerkyness due to the 1000/1001 factor." |
19th June 2006, 17:32 | #179 | Link |
Huh?
I see. So, what would the modified fps3to5 with 1/10th steps to achieve 150fps be?
21st June 2006, 21:05 | #180 | Link |
Huh?
Alain2? scharfis_brain?
