Old 8th October 2021, 20:27   #41  |  Link
PCU
Originally Posted by DJATOM View Post
Once it will be sold for MSRP. Don't wanna pay 2.5x for it.
You have to wait until 2023/24!
PCU is offline   Reply With Quote
Old 8th October 2021, 22:34   #42  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Originally Posted by PCU View Post
Friends, found this commercial some how new lossless codec: (pinned, but no one mentioned!)
MagicYUV Lossless Video Codec
https://www.magicyuv.com/
Not "new", if the key factor for you is speed then it's the best, imo. And it's free (v1.2), I guess that v2 is even more faster.
VoodooFX is offline   Reply With Quote
Old 9th October 2021, 10:16   #43  |  Link
PCU
100% lossless & best compression is important for me.
Old 9th October 2021, 10:33   #44  |  Link
PCU
Konstantinos Konstantinides
, Co-authored a book on image, video, and audio compression.
Answered February 18, 2016
Originally Answered: what is the best lossless video compression technique with the best compression ratio?
Digital cinema uses lossless JPEG2000. More recently, H.265 added a lossless mode as well. Acoording to a 2012 paper (http://www.apsipa.org/proceedings_2012/papers/252.pdf ) Motion JPEG 2000 (using wavelets) appears to be slightly better than H.265. JPEG-LS is not that far behind either.
Old 9th October 2021, 10:35   #45  |  Link
PCU
Bob Hannent
, Playback and delivery architect at a large streaming company
Answered January 22
HuffYUV and Lagarith are probably the best absolutely lossless codecs, you can compare their techniques. Although it's worth pointing out that just the way you transform the colour from RGB to YUV (or other colour formats) is a mathematically lossy process.
With 4K and more affordable SSD storage there has been a rise in the use of RAW-ish formats but they are largely proprietary.
But also most organisations don't want or need totally lossless, more visually lossless and that's why JPEG2000, JPEG-XS/XR and AVC-Ultra are very common formats for interchange in professional circles.
There is a big difference between 2:1 compression which you might get with something like Huffman tables and the 10:1 or better that you can get with accepting the output won't be pixel for pixel identical as the source.
Old 9th October 2021, 12:00   #46  |  Link
DJATOM
DJATOM's Avatar
I'm fine with it. 2070 is enough for now.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 9th October 2021, 12:19   #47  |  Link
PCU
Any active lossless video codec with Adobe plugin support? (excluding MagicYUV & FFV1)
Old 9th October 2021, 14:07   #48  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Then look at x265, because MagicYUV's compression ratio is weak.
Old 9th October 2021, 17:12   #49  |  Link
PCU
Is x265 really lossless?
Old 9th October 2021, 17:45   #50  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
What means "really lossless" (or "not-really lossless")?
Old 10th October 2021, 09:19   #51  |  Link
PCU
I heard that it is not 100% lossless and when converting the image quality is lost.
Old 10th October 2021, 10:40   #52  |  Link
Mathematically lossless
Unlike visually lossless codecs, MagicYUV is mathematically lossless, meaning that the decompressed output is bit-by-bit identical to the original input.
This means there is no generation loss. You can re-compress the same clip over and over as many times as you want without quality degradation.
Above from previously link to its home site.
If using eg YV12 loaded into VirtualDub2 Full Processing mode,
and saving as compressed YUV then will go through conversion to RGB and then to YUV and then compressed.
So, there would be losses in colorspace conversions, but the compression itself is lossless.
[Full Processing, mode converts to RGB for Vdub processing/filtering]
Fast Recompress mode, will enter into negotiation between VDub and MagicYUV and come up with a strategy to avoid colorspace conversion, if possible.
Above how it used to be, there is new VD2 Normal Recompress, not sure how that is different.
Old 10th October 2021, 11:58   #53  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
If you don't compress as lossless then it's not lossless, if you compress as lossless then it's lossless.
Old 10th October 2021, 12:04   #54  |  Link
PCU
What settings should I use?
Old 10th October 2021, 12:06   #55  |  Link
PCU
What about AME (Adobe Media Encoder)? I always use it as my media converter with lots of plugins.
Old 10th October 2021, 12:25   #56  |  Link
PCU
Old 10th October 2021, 12:29   #57  |  Link
Sorry, no idea, I dont use it.
Also, I rarely use MagicYUV and only have the old free one that runs on XP.
[I usually use Ut_Video, and again only the old XP compatible one]
Old 10th October 2021, 13:02   #58  |  Link
PCU
What lossless format compresses most of all, still YULS?
Old 10th October 2021, 14:38   #59  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
You should read answers on your thread.
MagicYUV
Actually it was mentioned twice!
Old 10th October 2021, 14:58   #60  |  Link
PCU
Yes, sorry, I'm blind , but It was about ~3 months ago!
