2nd December 2020, 19:23 | #21 | Link |
WebP 2 + dlls [3724e16] [Windows][GCC 10.2.0][64 bit]
WebP 2 + dlls [377656e] [Windows][GCC 10.2.0][64 bit] Last edited by Scope; 8th December 2020 at 19:09. |
3rd December 2020, 14:28 | #22 | Link | ||
Huba Huba
Personally, I do care because webp has the highest lossless compression I've seen - making it my photo archival format, esp. because it still has fast decoding (unlike flif and other specialized codecs). A common fallacy seems to be that webp uses yuv/vp8 for lossless - but it's rgba and afaik a separate implementation added independently from the video codec legacy.
That's why I'm very excited to read about "improved lossless compression" and "full 10bit architecture (HDR10)" in "What to expect?" and I am keen to see comparisons 1.0 vs. 2.0 lossless. Webp is added to most browsers, a lot of image viewers - so it might be possible that these will be quickly upgrading to 2.0 (except for older Android) Quote:
Re-compressing gif animated webp is still a bit tricky since results vary (esp. with dithering in the gif), recompression is slow, and some image viewers only support non-animated webp Quote:
I'd really like to stop looking for an image archival format that supports hdr (12bit would be better though for dslr images...), has lossless compression with a high ratio plus fast decompression _and_ is widely supported... and I've tried just about anything that is out there. Is the bitstream finalized and the lib ready enough so we can begin asking devs of image viewers to upgrade? This depends on a _lot_ of mingw shared dll - could you like them as static so this is stand-alone?
"The innocent have nothing to fear" :stupid: Last edited by Marsu42; 3rd December 2020 at 15:04. |
3rd December 2020, 22:26 | #23 | Link | ||
Tiles should help regarding decoding speed of large images, if multithreading is acceptable. Quote:
(note that there's a 'vwp2' tool for visualization and for playing with the compression parameters in the library). |
3rd December 2020, 22:30 | #24 | Link |
Regarding WebP2's triangle-based compression for previews, i've set up a demo page you might find amusing here:
https://codepen.io/skal65535/project/full/ZwnQWM You can visualize the base64-strings resulting from running 'mk_preview -b64 ...' |
3rd December 2020, 22:31 | #25 | Link |
Sorry for no comment. I put it on quickly.
av1enc.cc: In function 'int main(int, const char**)': av1enc.cc:243:46: error: 'env_vars' was not declared in this scope 243 | for (size_t i = 0; i < std::max((size_t)1, env_vars.size()); ++i) { | ^~~~~~~~ Code:
#if !defined(_WIN32) } else { const char symbol = (std::abs(v) >= (norm * 0.50)) ? 'X' : (std::abs(v) >= (norm * 0.25)) ? 'x' : '.'; line += SPrintf(" %c ", symbol); #endif } |
3rd December 2020, 23:15 | #26 | Link | |
thanks for testing -> should be fixed now, hopefully! |
4th December 2020, 22:56 | #27 | Link |
https://chromium.googlesource.com/co...a9f9594d3c5703
Compressing AV1 at quality 0.0... aom_codec_decode(&codec, (const uint8_t*) bitstream.data(), (size_t) bitstream.size(), NULL) failed! cwp2.exe image_21447.ppm image_21447.wp2 -summary -q 68 -nometadata -effort 9 -inplace image_21447.ppm Assertion failed: effort != 9 || angle_scores.back().score <= min_allowed_score, file predictor.cc, line 961 cwp2.exe image_21447.ppm -summary -q 68 -nometadata -effort 6 -csp 3 -o image_21447.wp2 Assertion failed: id < FeatureMap::kHistogramSize, file segment_enc.cc, line 415 cwp2.exe image_21447.ppm image_21447.wp2 -summary -q 68 -nometadata -effort 9 -csp 2 -inplace image_21447.ppm Error! Cannot encode 'image_21447.ppm' as WP2 Status: WP2_STATUS_INVALID_PARAMETER Last edited by Jamaika; 6th December 2020 at 14:10. |
5th December 2020, 00:07 | #28 | Link | |
(or on the bug-tracker https://bugs.chromium.org/p/webp2, even) |
5th December 2020, 01:08 | #29 | Link | |
6th December 2020, 23:40 | #30 | Link |
Huba Huba
How do I enable 10-bit output, or is this auto-selected depending on 8/16 bit input, or not imlemented yet? Thanks.
"The innocent have nothing to fear" :stupid: |
7th December 2020, 00:14 | #31 | Link | |
./extras/ewp2 -h Usage: ewp2 in_file [-o out_file] [options] Options valid if 'out_file' has the .wp2 or .webp extension: -q <float> ........................ quality factor (0:small..100:big), default=75.0 -effort <int> ..................... compression effort (0:fast..9:slower/better), default=5 -csp <int> ........................ color space (wp2 only) Options valid if 'out_file' has the .y4m extension (4:4:4 8b by default): -depth <int> ...................... output bit depth per plane per sample (8..12) -444 .............................. 4:4:4 output samples (full chroma resolution) -420 .............................. 4:2:0 output samples (half chroma resolution) Options valid if 'in_file' and/or 'out_file' are 4:2:0: -sampling <filter> ................ algorithm to use for up- and/or chroma downsampling: smooth (default), nearest Options valid if 'out_file' is specified: -[no]metadata ..................... include [or exclude] input metadata in output -[psnr|ssim] <file path> <float> .. error returned if output (or input if no given output) has a distortion worse than specified compared to a reference file Other options: -v ................................ verbose -size ............................. print size and bits-per-pixel -rm [A|R|G|B|Y|U|V] ............... set specified input channel(s) values to opaque/black/grey System options: -noasm ............................ disable all assembly optimizations -version .......................... print version number and exit -h / -help ........................ this help |
7th December 2020, 17:27 | #32 | Link | |
Huba Huba
Sorry if I'm jumping the gun, I'm simply very excited to see webp lossless compression getting to 10 (and 12?) bit, it's not like I can use it a lot right now. In any case, I don't compile this myself atm, so someone needs to provide windows binaries @Jamaika, @Scope
"The innocent have nothing to fear" :stupid: Last edited by Marsu42; 7th December 2020 at 17:36. |
7th December 2020, 19:24 | #33 | Link | |
I did a Lossless Image Formats Comparison, it's not completely finished yet, I want to update some results and add a more denser Jpeg XL compression mode (-s 9 -E 3, but it slows down the decoding a bit). Some notes: - there are Tabs for switching between different types of sets - AVIF is lossless, but AVIF 444 is lossy (--cicp 1/13/1) the difference with the original looks like this https://i.imgur.com/MSCaY6E.png - BMF is a closed format, slow for decoding, does not support alpha, but one of the most effective, selected only to understand the compression possibilities - PNGs have been optimized (Pingo + ECT), the original PNGs are much larger (as can be seen in the PNG tab, where I made a comparison of the most effective and popular optimizers) https://i.imgur.com/Zj62IEi.png Lossless Image Formats Comparison (Jpeg XL, AVIF, WebP 2, WebP, FLIF, PNG, ...) Some general results (although it is better to compare by types of sets, as they are not equal in correlation): |
7th December 2020, 20:23 | #34 | Link | ||
skal/ |
7th December 2020, 20:45 | #35 | Link |
Yes, but this is uncompressed PNG + Brotli compression (it is supported by browsers, but not by applications), so this is only a theoretical option for comparison, in other cases it is better to use Pingo + ETC (which I used to optimize all PNGs)
7th December 2020, 21:44 | #36 | Link | |
Will 4:4:4 sampling be included in the standard Webp2 decoder? What about 4:2:2? And why there is a split between normal and special encoders? Thanks. |
7th December 2020, 22:41 | #37 | Link | |
Jethro,
webp2 is able to use a mixed per-block 4:2:0 / 4:4:4 switch right now. But considering that 4:2:0 was invented for reducing the storage of *reference frames* in video sequence, it's highly possible we'll just drop it from webp2 and just work everything as 4:4:4 with special quantization tricks for emulating 4:2:0 blocks locally. Memory consumption of reference storage is less a problem when you're trying to blit everything on screen on a per-row basis! And as of 4:2:2, well, it has too much a smell of the interlaced fields from the past to be very relevant nowadays. Right now, there's a split between special encoder (ewp2) and the everyday-use encoder (cwp2) because most of casual users (i mean, outside of this specialized forum) are mostly concerned about just transcoding their good-old 8b jpeg or PNG, and would be confused by all this new stuff like HDR10, Y4M, PQ, etc. cwp2 is supposed to work off-the-bat for 99% of everyday users, and ewp2 is supposed to empower the savvy curious ones. Eventually they'll converge... |
8th December 2020, 12:38 | #38 | Link | ||
Huba Huba
Why didn't you include heic (i.e. hevc-compression), as it's another currrent video codec with a widely used image spin-off? The performance seems to be somewhere between avif and webp, with the same problem for true rgb mode. I'm currently trying to figure out how to do rgb-lossless heic: https://forum.doom9.org/showthread.p...94#post1930194 Quote:
Speaking as an everyday user :-) compressing 16bit-something (like dslr images) to more-than-8-bit webp2 seems to be an important use case, esp. since this is one of the main difference vs. webp1.
"The innocent have nothing to fear" :stupid: Last edited by Marsu42; 8th December 2020 at 12:49. |
8th December 2020, 14:43 | #39 | Link | |||
Also HEIC without --matrix_coefficients=0 (heifenc -p chroma=444 --lossless -e x265 -p preset=placebo ...) https://i.imgur.com/ysoWbAK.png Visually the result may be the same, but it's not real lossless and other formats also have more effective near-lossless modes, when the image becomes much smaller and it would be unfair to compare such modes with real lossless. |
