Old 8th July 2018, 15:34   #51681  |  Link
Manni
Originally Posted by jmone View Post
Thanks - I could do that, but so far I've only the one and it is not that great of a movie. I presume however the "better" option will be to use the HRD->SDR conversion option that is currently being work on (when it is ready) for all HDR content?
When it's ready, for sure.
Win11 Pro x64 b23H2
Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33
madVR/LAV/jRiver/MyMovies/CMC
Denon X8500HA>HD Fury VRRoom>TCL 55C805K
Old 8th July 2018, 17:34   #51682  |  Link
sniper
"don't draw subtitles" on screenshots is not working
v0.92.14
Anybody else getting this? tried it on several different videos, anime w/ soft subs and also movies with srt file same results
sniper is offline   Reply With Quote
Old 8th July 2018, 19:53   #51683  |  Link
sneaker_ger
What subtitle renderer are you using? The function doesn't work with subtitle filters that render on the video themselves ((xy-)vsfilter), only with those that use a separate subtitle interface (MPC-HC ISR, XySubFilter, AssFilter(Mod)).
Old 9th July 2018, 00:18   #51684  |  Link
jmone
Had a play with the test builds over at AVS. Looks good though the rendering overhead of HDR-->SDR seems to much for my 1070 on UHD HDR 59.94 content. Can't get the render times down under the required 16ms for 59.94 content (all high 20ms+) regardless of the Chroma scaling used. Unless you have any ideas of combos that work with a 1070 it looks like a 1080/1180 will be the next purchase.
jmone is offline   Reply With Quote
Old 9th July 2018, 09:07   #51685  |  Link
Manni
You need profiles to use less power with UHD @ 50/60p, for example with bilinear chroma etc. It should be just doable. Certainly not a problem for the 1080ti.
Win11 Pro x64 b23H2
Old 9th July 2018, 09:46   #51686  |  Link
jmone
FYIW - I tried all the Chroma scaling options including bilinear - all in the 20ms+ on the 1070.
EDIT: Depending on the HDR-> SDR Settings (like using Clipping) you can almost get away with no drops on bilinear....
Old 9th July 2018, 11:20   #51687  |  Link
what are your nvidia powersettings?
Old 9th July 2018, 11:41   #51688  |  Link
veggav
What test builds?
I'm stuck with an older version of MadVR because the newer ones don't work with UHD BD menus with Jriver media center.
Is this a closed thing? Or can I also try newer builds here?
veggav is offline   Reply With Quote
Old 9th July 2018, 13:04   #51689  |  Link
ryrynz
ryrynz's Avatar
The test builds are for HDR tonemapping improvements, ain't gonna fix your problem. Just wait.
Old 9th July 2018, 22:25   #51690  |  Link
jmone
The fixes for the issue with BD Menus sometimes being off the screen is fixed in the test builds. Still it is best to wait till a new version is out and is packaged with JRiver.
Old 9th July 2018, 23:21   #51691  |  Link
Warner306
Are the rendering stats now accurate, for those of us who have seen them drop after the last Windows Update?
Old 10th July 2018, 05:39   #51692  |  Link
heiseikiseki
I see it drops two times. One is after update to Windows 10 1803 ,
another one is after update to the latest Nvidia Driver.
Now on my PC for none OC GTX1060
23.975fps with smooth motion
720p->1440p
chroma> NGU AA (low) +RCA (for free)
luma> NGU sharp (very high)
chroma> NGU sharp(med)
the rendering time is around 6.2ms.
heiseikiseki is offline   Reply With Quote
Old 10th July 2018, 06:05   #51693  |  Link
can you make a screen of the OSD plz?
Old 10th July 2018, 06:16   #51694  |  Link
heiseikiseki
https://i.imgur.com/YiszMGB.jpg
https://i.imgur.com/pRYpf1S.jpg
I don't why if I turn on the showadvancestep then the rendering time would be increased.
Old 10th July 2018, 06:31   #51695  |  Link
to be expeceted just using it the incress it.
but 720 is pretty boring for a 1060.
Old 10th July 2018, 09:06   #51696  |  Link
Asmodian
Originally Posted by heiseikiseki View Post
I don't why if I turn on the showadvancestep then the rendering time would increase.
To elaborate on what huhn said, ShowRenderSteps needs to measure how long each step takes and to do this an extra flush is needed after each step, this slows down rendering overall. This is only true when the OSD is open.
madVR options explained
Old 10th July 2018, 11:42   #51697  |  Link
heiseikiseki
Oh!! Thanks for the explain!
Old 10th July 2018, 13:41   #51698  |  Link
zeus0r
hey there!
HDR passthrough via madvr is working fine and it puts my TV into HDR mode like it should. problem is: the picture is waaay too dark then. in dim scenes you can't even recognize faces properly.
so i tried the same files with the TV's internal mediaplayer -> perfect picture, not that dark.
any idea what could cause this?
4k SDR clips look wonderful via mpc-hc so it definitely is a HDR-specific problem.
my setup:
- philips 55pos901 oled tv
- gtx 980
- win 7
- mpc-hc + lavfilters + madvr (latest versions)
zeus0r is offline   Reply With Quote
Old 10th July 2018, 16:23   #51699  |  Link
mclingo
could it simply be that HDR is invoking a different profile on your TV which is set to FULL instead of LIMITED?
Old 10th July 2018, 17:58   #51700  |  Link
Warner306
I updated my driver and tried to do the manual method of creating a custom resolution.
First, I edited the EDID custom resolution created by madVR. The only thing that was different was the total number of pixels. This was entered and I played something. No change.
I deleted the custom resolution and started over. This time, when I finished, the driver entered the resolution as 23 Hz instead of 24 Hz. Still no go.
I then used CRU to create a custom resolution. It did not put anything into the GPU control panel, but the option to choose 24 Hz was removed, so it appeared to apply the correct EDID override. Played something and still no change.
So my apologies to the person I told to use the manual method of creating a custom resolution, as I couldn't figure it out, either.
The current driver doesn't seem to respond to anything but the default EDID. Not sure how common this is.
Custom resolutions are a total crapshoot...
