Old 21st August 2013, 12:18   #1  |  Link
efreitora
Lag on Video
Hi there.
Yesterday I've reinstalled my PC after that I installed MPC-HC + CoreAVC (DXVA enabled) + LAV Filters and the 720p x264 videos were playing perfectly. I use this configuration from 2 years and it's never had any issues.
Today I installed MS Office 2010 and Visual Studio Ultimate 2010 and now when playing some x264 videos the playback started to lag.
PC Confiiguration: P4 3GHz; 2GB RAM; AMD Radeon HD 4350 512MB; Windows XP SP3
efreitora is offline   Reply With Quote
Old 21st August 2013, 14:11   #2  |  Link
jkauff
Can't help you, but I suspect the install of VS 2010 created some sort of .NET problem within XP that's affecting DXVA.
Old 21st August 2013, 16:17   #3  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
Might clear up after background .NET runtime optimization completes. Also check for running auto-update routines.
raffriff42 is offline   Reply With Quote
Old 22nd August 2013, 11:27   #4  |  Link
efreitora
There are no any .net processes. There is nothing to interfere.
I did system restore to the time before installing VS 2010 and videos are working very good. But if I undo the system restore it starts again with lagging.
It seems no one has this issue with .net.
Thank you for your replies.
Old 23rd August 2013, 04:20   #5  |  Link
marquis
Just as a last ditch effort have you made sure everything is up to date? I'm not an expert, but sometimes when I bring in new things and other things act a bit off it is because they're not running on the proper update. I think you might check the .NET processing again too because these guys know their stuff.
marquis is offline   Reply With Quote
coreavc, lag, lav, mpc
