12th June 2009, 10:35 | #1245 | Link |
adrianmak: Are you in the possession of a recent Avisynth build (2.5.7+) that supports 64bit? AFIAK there was merely a single custom build 64 bit version back in 2005 which is not available anymore (and probably extremely outdated).
So, as long as there's no 64 bit Avisynth, there's no use for 64 bit plugins.. |
12th June 2009, 15:02 | #1247 | Link | |
Compiling Encoder
http://members.optusnet.com.au/squid_80/ |
5th August 2009, 21:22 | #1249 | Link |
AviSynth plugger
Terka,
I make several "planning" to do it. Last time - use phaseshift maximums as a predictors. But I am afraid, iy should be implemented not in MVTools block-based framework.
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
15th August 2009, 10:04 | #1250 | Link |
one question to mrecalulate.
MAnalyse has some default setting, S1. When using MAnalyse in script, i can select my own settings, S2. Other, not directly specified settings, remains same as S1. When using MRecalculate, i can select my own settings, S3. Other, not directly specified settings, remains same as S2? |
15th August 2009, 19:26 | #1251 | Link |
AviSynth plugger
Terka,
good question. it is not documented. other remains as undocumented defaults of mrecalculate, which are same values as defaults of manalyse.
19th August 2009, 21:08 | #1252 | Link |
thank you for reply.
One more thing, the following doesnot work with latest mvtools2 AVISource("c:\test.avi") # or MPEG2Source, DirectShowSource, some previous filter, etc vectors = MSuper().MAnalyse(isb = true) MShow(vectors) |
19th August 2009, 22:10 | #1253 | Link |
AviSynth plugger
This script is wrong. MShow need in super clip, for example:
AVISource("c:\test.avi") # or MPEG2Source, DirectShowSource, some previous filter, etc MSuper() vectors = MAnalyse(isb = true) MShow(vectors) or AVISource("c:\test.avi") # or MPEG2Source, DirectShowSource, some previous filter, etc super=MSuper() vectors = MAnalyse(super, isb = true) MShow(super,vectors) I replace source by super to show padding and vectors at padding
24th August 2009, 00:24 | #1254 | Link |
Is the blur I'm getting with Mdegrain3 in darker scenes expected, or have I gone wrong somewhere? I've read over the documentation and after tweaking about every option I could, I wasn't able to get a noticeable change (aside from the overall strength, thsad). Source: http://i26.tinypic.com/24vk4l0.jpg Default: http://i25.tinypic.com/kbzvut.jpg Thsad200: http://i26.tinypic.com/24vk4l0.jpg VOB Sample: http://www.mediafire.com/?ij2jznzjugy My script is: Code:
DGDecode_mpeg2source("VTS_03_1.d2v") tfm(order=0) src = last super = src.MSuper() bvec3 = super.MAnalyse(isb=true, delta=3, overlap=4) bvec2 = super.MAnalyse(isb=true, delta=2, overlap=4) bvec1 = super.MAnalyse(isb=true, delta=1, overlap=4) fvec1 = super.MAnalyse(isb=false, delta=1, overlap=4) fvec2 = super.MAnalyse(isb=false, delta=2, overlap=4) fvec3 = super.MAnalyse(isb=false, delta=3, overlap=4) src.MDegrain3(super, bvec1, fvec1, bvec2, fvec2, bvec3, fvec3) |
24th August 2009, 17:07 | #1256 | Link |
AviSynth plugger
2.4.0 beta (09.01.2009 by Fizick)
MDegrain: Changed degrain weight method to more strong... Approx: Old: (thSAD-blockSAD)/thSAD. new: (thSAD*thSAD - blockSAD*blockSAD)/(thSAD*thSAD + blockSAD*blockSAD) Assume thSAD=400, Example 1. current SAD=100, old strength = 0.75, new strength = 0.87. Example 2. current SAD=200, old strength = 0.5, new strength = 0.60. Example 3. current SAD=300, old strength = 0.25, new strength = 0.28. Example 4. current SAD=400, old strength = 0, new strength = 0. blurring usually indicates wrong vector search...
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. Last edited by Fizick; 24th August 2009 at 17:10. |
24th August 2009, 17:45 | #1257 | Link | |
Ah - thanks for posting the new formula. I ever wondered since it was implemented - - but not enough to start digging through the source code ...
Official question: What about taking into account local complexity when evaluating SAD? Aren't there any proven concepts out there for that?
24th August 2009, 20:06 | #1258 | Link |
x264aholic
This probably is computationally unfeasible, but how's about how well a region can be compressed? For a given block, run it through your favorite lossless compressor and calculate the % of the original file size. Flat areas would probably give something like (general numbers here) 200 bytes compressed vs 2000 bytes uncomp'd, so it's complexity score would be 0.1.
Like I said, that's probably way too slow to be practical but there's probably a way to do something similar and much faster.
You can't call your encoding speed slow until you start measuring in seconds per frame. |
24th August 2009, 20:43 | #1259 | Link |
AviSynth plugger
Didée,
suprisingly, about week ago i found your manifesto about local complexity hidden in non-official mvtools thread http://forum.doom9.org/showthread.ph...80#post1305680 If anyone has ideas that s/he thinks that would bring a worthwhile improvement, then: MAKE IT, and SHOW THE PROOF. Until then, I'll resort to short "nope"-style answers, when indicated. My answer is - nope. SAD is SAD, and it is evaluated (and must be evaluated) in MAnalyse as is. Postprocessing and usage of this info (in MDegrain, etc) is other story. But rigth now I am more interested in more coorct vector field estimation. May be even with variable block size like h264. in tis case SAD may be not so big at edges.
25th August 2009, 19:36 | #1260 | Link |
This is an issue I have been thinking about myself. Right now we simply don't know if a low SAD means that the match is good or that there isn't much information anyway.
We would want some sort of metric that tells us how reliable our guess on the movement is. I had hoped this could be an alternative approach for the movement analysis. but so far I haven't found a way to get the concept into a working algorithm. I'm not even sure it is possible to do it in a way that the produced vectors and computation time is better or at least equivalent.
GA-P35-DS3R, Core2Quad Q9300@3GHz, 4.0GB/800 MHz DDR2, 2x250GB SATA HD, Geforce 6800 |
