14th August 2008, 23:20 | #2221 | Link |
It would be great to have a 25gb BD-R preset, I guess it's about the 23gb mark. Although it can be added manually, I just need to know waht the exact file size should be. Blank Blu-Ray's are still too expensive to get a coaster cos your file size is too big!
14th August 2008, 23:37 | #2222 | Link | |
That awesome news. I will have to go check it out. I have a FRY's about 40 minutes from me. Thanks for the info. |
15th August 2008, 00:47 | #2224 | Link |
Atak the copy /b does not appear to produce a file eac3to is happy with.
eac3to v2.56 command line: "C:\DVDTools\RipBot264v1.10.5\Tools\eac3to\eac3to.exe" "H:\combined_evos.evo" 1:"H:\Temp\RipBot264temp\job1\video.mkv" ------------------------------------------------------------------------------ EVO, 1 video track, 4 audio tracks, 2 subtitle tracks, 1:49:54 1: h264/AVC, 1080p24 /1.001 (16:9) with pulldown flags 2: E-AC3, 5.1 channels, 1536kbit/s, 48khz, dialnorm: -27dB 3: E-AC3, 5.1 channels, 768kbit/s, 48khz, dialnorm: -27dB 4: AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB 5: AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB 6: Subtitle 7: Subtitle [v01] Extracting video track number 1... [v01] Muxing video to Matroska... Unfortunately the Haali Muxer cannot handle this source file. It doesn't contain enough seek/recovery points. Aborted at file position 692666368. |
15th August 2008, 00:48 | #2225 | Link |
Combine those files with TSmuxer
15th August 2008, 01:20 | #2226 | Link |
н∂-ƒαиαтι¢
Bug:
Selecting 2.0 CT AAC-LC @ 96kbps audio still produces multichannel audio. Code:
"C:\Program Files\RipBot264\tools\bepipe\bepipe.exe" --script "import(^G:\Temp\RipBot264temp\job1\job1.avs^)" | "C:\Program Files\RipBot264\Tools\enc_aacPlus\enc_aacPlus.exe" - "G:\Temp\RipBot264temp\audio.aac" --lc --cbr 98804 Last edited by ~bT~; 15th August 2008 at 01:28. |
15th August 2008, 01:32 | #2227 | Link |
final script would be more helpful.
15th August 2008, 07:46 | #2230 | Link | |
15th August 2008, 08:18 | #2231 | Link | |
15th August 2008, 13:37 | #2233 | Link |
is it possible in any way to add more than one video (i want to create a trailer disc in blu structure) i cant find a way of adding more than one video
or if that isnt possible if i merge them all into one file is there a way of changing the chaptering to make each trailer a seperate chapter? love the prog btw U GENIUS!! |
15th August 2008, 13:51 | #2235 | Link | |
н∂-ƒαиαтι¢
15th August 2008, 17:23 | #2236 | Link | ||
BD5=4480 MB BD9=8150 MB (these already exist) Not really that difficult. Last edited by wakebrder; 15th August 2008 at 17:27. |
15th August 2008, 21:59 | #2237 | Link | |
I did not ever try and manually enter a desired size before. I thought that the presets were the only choices. Thanks for the info |
15th August 2008, 23:03 | #2238 | Link | |||
16th August 2008, 00:31 | #2239 | Link |
How would you enter the desired size? Only way I see doing it is figure out the bitrate for encoding to get the desired file size for the video either using a bitrate calculater or the old fashion way and enter that in the bitrate and dont lock a size
16th August 2008, 06:33 | #2240 | Link | |
Hopefully it won't be long beofre DVD-ROM's are thought of as the CD-R's of optical media! Aparently Pioneer have already developed a 500gb Blu-Ray disc! |
