3rd December 2018, 10:49 | #5921 | Link | |
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
4th December 2018, 02:24 | #5924 | Link |
5th December 2018, 02:28 | #5925 | Link |
mpc-be plays this video at around 10 fps when it is actually a 29.970fps video. I tried mpc-hc and mpv and they played it @29.970 just fine.
Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom/iso2/avc1/mp41) File size : 51.7 MiB Duration : 3 min 23 s Overall bit rate mode : Variable Overall bit rate : 2 135 kb/s Writing application : Lavf58.23.102 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.1 Format settings : CABAC / 2 Ref Frames Format settings, CABAC : Yes Format settings, RefFrames : 2 frames Format settings, GOP : M=3, N=90 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 3 min 22 s Bit rate mode : Variable Bit rate : 2 002 kb/s Maximum bit rate : 2 097 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.072 Stream size : 48.4 MiB (94%) Title : h264@GPAC0.7.2-DEV-rev944-g0a890c07-master Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : avcC Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Duration : 3 min 23 s Bit rate mode : Constant Bit rate : 125 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Stream size : 3.03 MiB (6%) Title : aac@GPAC0.7.2-DEV-rev944-g0a890c07-master Default : Yes Alternate group : 1 |
5th December 2018, 12:25 | #5926 | Link | |
5th December 2018, 16:17 | #5927 | Link |
@wushantao
Thank. Updated in r4237. But I have a question. Why did you change the previously translated strings?
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
5th December 2018, 17:02 | #5928 | Link | |
Life's clearer in 4K UHD
9th December 2018, 10:36 | #5930 | Link |
is there any reason the wasapi render from MPC-BE doesn't see the 7.1 simulated channels from windows sonic or simply can't use it?
steps to reproduce: you need windows 10. go to sounds-> playback device -> your playback device (preferable analogue) -> spatial sound -> select "windows sonic for headphones" _< tick "turn on 7.1 virtual surround sound" play a 7.1 file with directsound it will render 7.1 as far as i can see. play a 7.1 file with mpc-be internal audio renderer it shows down mixing to stereo. |
9th December 2018, 13:21 | #5931 | Link | |
11th December 2018, 17:58 | #5933 | Link |
Hey.
Does anyone have a sample (MOV) with video in 'b16g' (Apple 16-bit Gray) format?
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 16th December 2018 at 11:28. Reason: typo |
11th December 2018, 21:33 | #5934 | Link |
I'm not familiar with that format at all...
12th December 2018, 19:30 | #5935 | Link |
A few issues to report:
Player can't resume playback until all the stream has been downloaded. Steps: - have "Remember file position" enabled in the player options - open the URL to some long youtube video (like this one: https://www.youtube.com/watch?v=A_xqBidOjpQ) - after 5 minutes or so, stop the playback of the video (using File -> Close) - open the same youtube URL again -> playback does not resume when the download of the stream has reached the 5 minutes mark, it only resumes after the entire stream has been downloaded locally; for some youtube reviews that takes 30 or more minutes that's a lot of time to wait. Another issue is with the xysubfilter external subtitle filter (maybe with the internal one as well). - start playing some media files with subtitles - open the xysubfilter properties dialog, and set a subtitle delay on the Timing tab - close the file - open the file again (or some other file) -> the subtitle delay has been reset to zero; in MPC-HC the subtitle delay is kept, and I find it preferable this way (especially when viewing the episodes of a series using external subtitle files with different timings). |
13th December 2018, 13:13 | #5937 | Link |
It's already working good. Don't need improvement.
