Old 3rd September 2008, 22:32   #61  |  Link
stax76
stax76's Avatar
This wasn't generated with the latest beta, I've uploaded the latest beta a few minutes before my latest posting less then a hour ago.
Old 3rd September 2008, 22:55   #62  |  Link
Albo
OSX User
Oh sorry! You're quick with the updates. Let me try that again.
Bug Report: http://www.2shared.com/file/3870878/...tic_Files.html
Albo is offline   Reply With Quote
Old 3rd September 2008, 23:26   #63  |  Link
stax76
stax76's Avatar
Did it create a 264 file with reasonable filesize that plays in VLC? If so I don't understand why DGAVCDec don't run after mkvextract, it does here. If there is a 264 file what happens if you open this manually with StaxRip?
Old 4th September 2008, 00:11   #64  |  Link
Albo
OSX User
It creates a 264 file that's viewable in VLC, but if I add that file as a source it gives me the same error: "The format is not supported".
Old 4th September 2008, 00:26   #65  |  Link
stax76
stax76's Avatar
If you create a mkv x264 file with StaxRip and then open it with StaxRip, does it load?
Old 4th September 2008, 01:02   #66  |  Link
Albo
OSX User
It does. I think there is something particular about this file, as another mkv just opened perfectly. I tried creating a new version of the original non-working file with MKVMerge, but the same error happens.
*Scratch that. Just tried a third mkv - same error. So that's two that produce the same error now.
Old 4th September 2008, 09:15   #67  |  Link
stax76
stax76's Avatar
Maybe it happens here too so please upload a clip to rapidshare.
Old 4th September 2008, 14:31   #68  |  Link
Albo
OSX User
Here's the file I've been trying to work with...
Sky Fighters opening titles (104MB ZIP)
Old 4th September 2008, 15:47   #69  |  Link
stax76
stax76's Avatar
I can reproduce it so I can investigate it.
Old 4th September 2008, 15:53   #70  |  Link
Albo
OSX User
Ah, excellent, it's not just me! PHEW! Thank you for looking into this.
Old 5th September 2008, 09:17   #71  |  Link
stax76
stax76's Avatar
Problem is the DGAVCDec preparer is restricted to AVC format but MediaInfo don't return AVC as format for the 264 file, likely a MediaInfo bug, to workaround remove the AVC restriction in the options, I'll make a bug report to MediaInfo.
Old 5th September 2008, 15:04   #72  |  Link
Albo
OSX User
Thanks for the research into this issue. How would I go about applying the workaround? Is this something I can do myself?
Old 5th September 2008, 15:27   #73  |  Link
stax76
stax76's Avatar
Like I stated you have to remove the AVC format from the input format list of the DGAVCDec preparer so all formats get handled.
Old 5th September 2008, 15:46   #74  |  Link
Albo
OSX User
Yeah, I tried that and it doesn't stick. If I delete AVC and click ok, then click Edit again it's still there.
Old 5th September 2008, 17:18   #75  |  Link
stax76
stax76's Avatar
Alright, new beta online.
Old 5th September 2008, 18:27   #76  |  Link
Albo
OSX User
Nice, that works now, thank you.
Unrelated issue regarding DTS tracks: What's the best way to have StaxRip handle those? Should I be converting before bringing into the app, or is there a method in which it can encode directly from DTS to AAC 2ch?
Old 5th September 2008, 20:00   #77  |  Link
stax76
stax76's Avatar
Both is possible but I've no experience with DTS.
Old 6th September 2008, 01:30   #78  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
...also there is no best as per forum rules...
Old 6th September 2008, 14:54   #79  |  Link
stax76
stax76's Avatar
@Albo
I've changed the defaults now to workaround the problem, there is now one DGAVCDec preparer handling the extensions 264, h264 and avc regardless of the format returned by MediaInfo and then there is a second DGAVCDec preparer that handles the extensions ts and m2ts in case MediaInfo returns AVC as format. I've not uploaded it yet however (I don't want to shutdown uTorrent right now).
Old 6th September 2008, 18:52   #80  |  Link
Albo
OSX User
Great! Look forward to using the new version. I've also solved my DTS issue by using a Mac-based solution for the re-encoding, and then muxing to an mp4 in Windows.
bug, staxrip
