11th March 2008, 03:55 | #3641 | Link |
Mr. Sandman
Berrinam is still MIA?
13th March 2008, 13:53 | #3644 | Link | |
Mr. Sandman
1- Revert to the old profiles code 2- Complete the profiles refactor adding the missing zones and custom CLI options fox x264 3- Go ahead without zones and add custom CLI options only.
13th March 2008, 14:04 | #3645 | Link |
Swallowed in the Sea
ok...shouln't be too complicated anyway.
btw, last night I checked the new DGindex stuff for audio streams extraction and it seems to be more complicated than I thought. We need to run a special command first to create a logfile to have each tracks IDs, then read those datas from the file and put them in the current DGindex command...so, great. :-/ I'll see what can I do for this part.... |
13th March 2008, 14:07 | #3646 | Link |
Mr. Sandman
eh, i had a look at it some time ago and i gave up since i had not enough time to get it working.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 13th March 2008 at 14:31. |
13th March 2008, 14:26 | #3647 | Link |
HDConvertToX author
@Kurtonise13
yea, confirm; i use the same approach on automkv First check if stream is mpeg2 (mediainfo) if yes, lauch dgindex in info mode, parse the log and add the audio tracks to list If video is mpeg4, run dgavcdec demuxing all audio tracks and indexing the file, then add audio to list BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
14th March 2008, 14:06 | #3648 | Link | |
14th March 2008, 17:26 | #3649 | Link |
Mr. Sandman
DVD Decrypter is dead and in some countries even illegal.
Sadly, we should not rely on it anymore but that means rewriting some code... Buzzqw method is the right way to go (yeah italians do it better) but as i said, it needs some time and will to rewrite some parts of megui.
14th March 2008, 18:00 | #3650 | Link |
I extract all streams and rename the files replacing the index with language code and name extracted from IFO.
14th March 2008, 20:32 | #3651 | Link |
HDConvertToX author
yes.. if have an ifo.. but with a mpeg stream, not belonging to dvd.. it's hard to tell language
on automkv i use vstrip to determine audio id/languages (on ifo) and then allow dgindex to demux only tracks user selected BHH
23rd March 2008, 01:56 | #3652 | Link |
This is the current constructor. This throws a null ref exception in Mono because of a a missing null-check which prevents MeGUI from loading:
class JobQueueSettings : ApplicationSettingsBase { public JobQueueSettings(IComponent c, string k) :base(c, k) {} } Code:
class JobQueueSettings : ApplicationSettingsBase { public JobQueueSettings(IComponent c, string k) :base(k) {} }
Nothing to see here... |
23rd March 2008, 06:28 | #3653 | Link |
Pain and suffering
Megui x264 config: RC and ME > Macroblock Options
When you select Adaptive DCT (--8x8dct), --i8x8 should be enabled also, this is a bug. Please fix it Also i8x8 is on by default default: --partitions "p8x8,b8x8,i8x8,i4x4" Edit: Also please update --analyse to --partitions. Thanks Last edited by bob0r; 23rd March 2008 at 07:27. |
24th March 2008, 08:37 | #3654 | Link | |
24th March 2008, 08:45 | #3655 | Link | |
both are correct... |
24th March 2008, 16:40 | #3656 | Link |
From what i can tell, it's ok to make this change, so i'm going to go ahead and commit this. Let me know if any issues pop up that i've missed. The fix is in revision 479, so things should Just Work (TM) on Linux now. Encoding and all that doesn't work, that needs to be set up, but MeGUI starts up.
26th March 2008, 12:21 | #3659 | Link | |
Pain and suffering
I just say: It would be better if you renamed it just to match Current x264 settings when you type x264 --help. Clarity > Sanity! P.S. If you fixed the i8x8 issue, please update the stable version on the updater.... Okay Sahrktooth? Sharktooth come on irc tonight 00:00-04:00 or tomorrow please, got something to run by you |
26th March 2008, 16:35 | #3660 | Link |
Mr. Sandman
ill see what i can do
development, megui, not a help thread |
