20th February 2010, 05:23 | #10861 | Link | |
Edit: Is ffdshow_rev3254_20100207_dbt_bitstream_trial_beta2.exe the correct file?
"Do everything by hand, even when using the computer." - Hayao Miyazaki Last edited by DigitalDeviant; 20th February 2010 at 05:26. |
20th February 2010, 09:05 | #10862 | Link |
Media Control author
Sorry, wrong link (I was really tired)
Here is the right one : http://damienbt.free.fr/ffdshow_rev3...bluraysubs.exe |
20th February 2010, 11:55 | #10865 | Link |
I have adapted the approximative scaler to RGB32 for PGS subtitles.
There are still the bilinear and the full scaler to be adpated now. I'll test another build when all the scalers will work and with the modifications on the interface |
20th February 2010, 12:34 | #10866 | Link |
Hi albain,
nice progress! I've tested briefly, I think there are some colorspace issues with YV12, because It didn't look so good combined with DXVA. It also crashed once when I changed the subtitle stream in the middle of playback. I'll have time to take a look at the code later this week. Thanks! |
20th February 2010, 15:31 | #10868 | Link | |
I have committed my changes : all the scalers work except bilinear, don't know why, it is not very important I have renamed the Subtitles > Vobsub section to "BluRay & DVD" The color problem you got may be due to an inversion of red and blue channels. There was a bug in the existing code, I fixed it. Maybe this is the cause. You can grab the last revision if you want to work on it. I haven't work yet on the subtitles stream switching issue (crash). Thanks Damien |
20th February 2010, 16:07 | #10869 | Link |
Can someone update the ICL project files? I've done it for my needs but it should be in the SVN. BTW, albain I noticed that you removed the post build event of registering ffdshow.ax. I hope you keep it that way.
20th February 2010, 17:45 | #10873 | Link | |
I haven't tested it much due to lack of time but this was something I encountered on the first test with multiple simultaneous subs.
"Do everything by hand, even when using the computer." - Hayao Miyazaki |
20th February 2010, 18:43 | #10874 | Link |
@Tal : I didn't experience crash while switching subtitle streams Last edited by albain; 20th February 2010 at 18:48. |
21st February 2010, 01:17 | #10875 | Link |
http://www.mediafire.com/?zuydynjgcki
I can't seem to get a screenshot of what it's supposed to look like but the dialog is supposed to be at the bottom and the kanji title translation is supposed to be at the top. Edit: ffmpeg-mt seems to be working in the recent build on xvidvideo.ru.
"Do everything by hand, even when using the computer." - Hayao Miyazaki Last edited by DigitalDeviant; 21st February 2010 at 05:10. |
21st February 2010, 07:50 | #10876 | Link |
Any plans to add FFDSHOW DXVA support for the Clarksdale architecture? Intel created an SDK to make it easier to work with.
HTPC #1 with Xonar HDAV, Pioneer VSX-TX01H HTPC #2 with Clarksdale, Pioneer VSX-TX01H XBMC for the win!! |
21st February 2010, 10:12 | #10877 | Link |
I have tested subs in DXVA and also in non DXVA with FFDshow of course lol. I have strange issue : I use MPC Mpeg Splitter for .m2ts and MPC Matroska Filter for MKV. For .m2ts : The graph connect subtitle output from MPC to Text input FFDshow for m2ts with sub inside and also m2ts with no sub inside (i can verify if sub is here with mediainfo) -> but even with m2ts with sub, i can't see it and selected it (even if i seek the movie) For .mkv : FFDshow find sub (.srt or other and play it) i can select sub if we have multi file in directory but the issue that it didn't choose always the right sub) for example, i have a sample.mkv with sub inside and other files with sample2.srt toto.srt etc. -> FFDshow select sample2.srt (in this case). (DirectVobsub select only the match name). Also when right clic on FFDshow didn't show embedded sub and to make it appear, i must seek in video and it appear. I hope that i can explain good lol. It's a great work but for now i can't see subs arf !. Ps : To try to select, enable/disable sub, i use MRCremoteplus, i can map this option with MCE remote, i can manage enable/disable but no selection of sub, i think that i didn't find where is configured, i've try to find to show it in OSD screen but no success lol. Also i've try with in mediaportal but, i think it was necessary to put an remote API like MCERemoteplus in mediaportal code to make it work. Cheers, Seb.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
21st February 2010, 10:16 | #10878 | Link | |
FFDshow select sample2.srt (not cool lol) and i can't see embedded sub . Seb.
21st February 2010, 11:52 | #10879 | Link |
Hi again lol,
So this is log from debugview if it help Trace from .m2ts with mutliple sub inside (no selection possible and no sub renderer) M2TS_0001_Multisubs(not working even seek) Trace from .mkv with mutliple sub inside, sub only appear when i seek the video (when i go to right clic on FFDshow icon, i have the choice after but didn't render too. MKV_[Eng-Jap] Art Of Fighting OVA (Eng-Esp sub)(Seek) Trace from .mkv with only 1 sub inside, sub only appear when i seek the video and disable and enable sub (when i go to right clic on FFDshow icon), i have the choice after but didn't render too. MKV_sample(Appear after many seek and disable and enable sub) I know that it for Bluray but i made all test posible to see why. Anther issue also is if the OSD is enable, when i play [Eng-Jap] Art Of Fighting OVA (Eng-Esp sub) Graphstudio crash. Cheers, Seb.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. Last edited by Sebastiii; 24th February 2010 at 22:39. |
21st February 2010, 12:39 | #10880 | Link |
Convolver filter question: I tried the convolver filter inside ffdshow with impulse files here http://sjeng.org/foobar2000.html . Specifically I tried the Urei 1178 Impulse file inside the tube amps package. With Auto Adjust enabled I have very low volume compared to nearly the same level of volume as original file with foobar convolver component. When I disabled Auto Adjust I have to set the Level bar to maximum to have nearly normal volume. Is this by design?
Tested with ffdshow 3277 x86 build on xvidvideo.ru and foobar 1.0 with latest convolver component. Source audio spec: 48000Hz, 16bit, Stereo; the Urei impulse file: 44100Hz, 16bit, mono. I have tried to resample my source to 44100Hz before sending it over the convolver filter inside ffdshow, same thing happens.
Home PC: Core i5-2400, 8GB RAM, nVidia GTX560Ti, Windows 7 64bit SP1. Work PC: Intel Xeon X3220 (Core 2 Q6600), 4GB RAM, Intel G45, Windows 7 64bit SP1. |
