11th January 2009, 05:05 | #3601 | Link | |
Mr. Sandman
11th January 2009, 14:58 | #3603 | Link | |
Even a fresh installation of megui doesn't solve this. I've tried everything. |
11th January 2009, 18:28 | #3605 | Link |
Just FYI on interface problem in Vista 64. I know you don't support it, but I have lost Gui buttons in the past but was able to get around it. This one is a killer...
I lost the Avisynth save button before, but was about to work around. Have not had the Aspect ratio button either. Not sure why this is happening, just thought you should know. I went back to core 0.3.0.3004 to get the DV2 Creator fixed, so it was lost with a change since then. |
11th January 2009, 18:51 | #3606 | Link |
Hello.
I ripped Transformer Blu-Ray and encoded it to 1080p no problem. But then I decided I wanted it to be 720p to save some space on HD. I was too lazy to re rip the Blu-Ray, so I decided to use the 1080p source, but something very weird happened. Instead of desire 4000 bitrate, it came up with 300 average bitrate at end! I used x264: Standalone-Blu-ray, the only thing I changed was the bitrate from 8000 to 4000. I'm thinking that its x264 bug or what? Thanks for help. PS Just noticed there's new version of x264, will download it and try 1st pass of 2nd pass and see what's output's stats is. Last edited by SeeChestlickRun; 11th January 2009 at 18:54. |
11th January 2009, 21:38 | #3607 | Link |
Forum Member
In the Nero ACC configuration, is "improve accuracy using 32 bit & flow computations" recommended to be enabled or disabled?
Is turning it on or off based on the encoder configuration used and file input? (I.E - LC vs HE and 128 kbit/s vs 256 kbit/s or 16bps vs 24bps with 44.1kHz vs 48kHz). Or should it remain enabled regardless? Thanks. |
12th January 2009, 08:23 | #3608 | Link |
Hmm for some reason when I encode audio to .mp4 using FAAC, the audio comes out very "static-y/noisey", in the past this never happened, and now I am useing Nero as the alternative.
Anyone know why this happens? And when using the Nero encoder, how does the VBR work? As it is b decimal, ex. .5, if on the FAAC I used 90, would that be equivalent to .9? NOt too sure. Thanks. |
12th January 2009, 09:19 | #3609 | Link | |
It was ArcSoft TotalMedia Theater's fault!!! I was using it to watch my ripped Blu-Ray, but it wasn't until 3 or 4 days after I started to using MeGUI again. Look like ArcSoft's codec was having some conflict with ffdshow. After uninstalling ArcSoft program, the bitrate came out right! Downside, I probably would have to find new Blu-Ray player on my computer. Hope this help some people out there. |
12th January 2009, 13:09 | #3610 | Link | ||
BTW, NeroAacEnc is now better encoder than Faac, use always Nero. Quote:
I recommend you use this ranges: <.31 -> to play with low quality audio equipment. .31-.35 ->to transcode ac3/dts with minimal lose of quality .36-.5 ->to compress lossless sources, good quality >.5 ->to compress lossless sources until insane quality
12th January 2009, 20:28 | #3612 | Link |
hi,
i try to downmix a 6ch ac3 track to stereo aac and i get a 3ch aac! here is the log: -[Information] Log for job22 (audio, Vicky_Cristina_Barcelona_688p_ac3.ac3 -> Vicky_Cristina_Barcelona_688p_ac3.m4a) --[Information] [1/12/2009 9:13:39 PM] Started handling job --[Information] [1/12/2009 9:13:39 PM] Preprocessing --[NoImage] Avisynth script ---[NoImage] NicAc3Source("F:\x264\Vicky_Cristina_Barcelona_688p_ac3.ac3")6<=Audiochannels(last)?x_stereoad747990273e4b049a3a6e8c0750cc10(ConvertAudioToFloat(last)):last ---[NoImage] 32==Audiobits(last)?ConvertAudioTo32bit(last):last ---[NoImage] return last ---[NoImage] function x_stereoad747990273e4b049a3a6e8c0750cc10(clip a) ---[NoImage] { ---[NoImage] fl = GetChannel(a, 1) ---[NoImage] fr = GetChannel(a, 2) ---[NoImage] c = GetChannel(a, 3) ---[NoImage] lfe = GetChannel(a, 4) ---[NoImage] sl = GetChannel(a, 5) ---[NoImage] sr = GetChannel(a, 6) ---[NoImage] l_sl = MixAudio(fl, sl, 0.2929, 0.2929) ---[NoImage] c_lfe = MixAudio(lfe, c, 0.2071, 0.2071) ---[NoImage] r_sr = MixAudio(fr, sr, 0.2929, 0.2929) ---[NoImage] l = MixAudio(l_sl, c_lfe, 1.0, 1.0) ---[NoImage] r = MixAudio(r_sr, c_lfe, 1.0, 1.0) ---[NoImage] return MergeChannels(l, r) ---[NoImage] } --[NoImage] Commandline used: -ignorelength -lc -br 128000 -if - -of "{0}" --[Information] [1/12/2009 9:13:39 PM] Encoding started --[Information] [1/12/2009 9:13:39 PM] Encode thread started --[Information] [1/12/2009 9:13:39 PM] Avisynth script environment opened --[Information] [1/12/2009 9:13:39 PM] Script loaded --[Information] Output Decoder ---[NoImage] Channels: 3 ---[NoImage] Bits per sample: 32 ---[NoImage] Sample rate: 48000 --[NoImage] Commandline: C:\Program Files\megui\tools\neroaacenc\neroAacEnc.exe -ignorelength -lc -br 128000 -if - -of "F:\x264\Vicky_Cristina_Barcelona_688p_ac3.m4a" --[Information] [1/12/2009 9:13:39 PM] Encoder process started --[NoImage] Output from encoder via stderr ---[NoImage] ************************************************************* ---[NoImage] * * ---[NoImage] * Nero AAC Encoder * ---[NoImage] * Copyright 2008 Nero AG * ---[NoImage] * All Rights Reserved Worldwide * ---[NoImage] * * ---[NoImage] * Package build date: Sep 17 2008 * ---[NoImage] * Package version: 1.3.3.0 * ---[NoImage] * * ---[NoImage] * See -help for a complete list of available parameters. * ---[NoImage] * * ---[NoImage] ************************************************************* --[Information] [1/12/2009 9:22:40 PM] Postprocessing --[Information] [1/12/2009 9:22:40 PM] Job completed _ L.E. Actually the source is 3ch ac3! Format : AC-3 Format/Info : Audio Coding 3 Codec ID : A_AC3 Duration : 1h 36mn Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 3 channels Channel positions : L C R Sampling rate : 48.0 KHz _ L.E.2 any sugestions how to downmix 3ch to stereo? _ Last edited by b66pak; 12th January 2009 at 20:36. |
13th January 2009, 00:15 | #3614 | Link |
Selecting a FLAC track in the bitrate calculator causes a fatal error of Value cannot be null. Funny thing is though, it fills in the bitrate field because the mediainfo wrapper supports FLACs.
How about that DTS bitrate issue, too? |
13th January 2009, 00:34 | #3615 | Link | |
There are many comparatives between audio codecs and in this thread is off topic. Maybe 0.3 and 0.5
13th January 2009, 00:46 | #3616 | Link | |
NicAc3Source("F:\x264\Vicky_Cristina_Barcelona_688p_ac3.ac3", 2).Normalize() NicAudio can downmix 3-6 channels to 2 channels internally.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 13th January 2009 at 00:55. |
13th January 2009, 19:42 | #3617 | Link |
@tebasuna51 thanks a lot...
_ @Kurtnoise13 handling exceptions and errors is a VERY important part of a program! if megui cant handle anything but 6ch>>2ch a warning must be done to prevent losing time and unwanted results... _ |
13th January 2009, 22:09 | #3619 | Link | |
Swallowed in the Sea
should be ok in the next release... |
megui |
