Old 30th May 2019, 21:39   #581  |  Link
attachment need approval please upload the image somewhere else.
because both potplayer and mpc-hc use EVR or a variant of it as a default renderer can you test madVR?
Old 31st May 2019, 23:48   #582  |  Link
Nintendo Maniac 64
Nintendo Maniac 64's Avatar
Originally Posted by el Filou View Post
If all you want is bit-exact output, MPC's internal audio renderer supports WASAPI exclusive mode which provides it.
...as long as you aren't using an Asus or Creative audio device as their drivers "cheat the system" and make WASAPI exclusive be, well, non-exclusive.
(this can be easily tested in a program like foobar2000 with it configured to output via WASAPI exclusive - simply try playing back an audio file with a weird sampling rate like 43210Hz, and if your audio device handles WASAPI exclusive properly then foobar2000 will throw up an error, but if it cheats and eliminates the exclusive functionality then foobar2000 will play the according audio without issue)
____HTPC____  | __Desktop PC__
2.93GHz Xeon x3470 (4c/8t Nehalem) | 4.6GHz Pentium G3258 (2c/2t Haswell)
Radeon HD5870  | Intel iGPU
2x2GB+2x1GB DDR3-1333 | 4x4GB DDR3-1600
Win7 x64
Nintendo Maniac 64 is offline   Reply With Quote
Old 3rd June 2019, 14:11   #583  |  Link
crunchlab
crunchlab's Avatar
Asmodian
Originally Posted by Asmodian View Post
Wants "native" (?) HDR to SDR tone mapping but is not interested in madVR?
What's so confusing about it? Yes, native as in I wouldn't need to install another piece of software for the sole purpose of playing 10 seconds HDR video on SDR display once a month (which is the only madVR feature I require). I'm fine with EVR and how it's integrated with MPC-HC.
chros
Yes, I know that MPC-BE supports it. I suppose I should have mentioned I am not interested in MPC-BE either, at least for now.
crunchlab is offline   Reply With Quote
Old 3rd June 2019, 19:27   #584  |  Link
Asmodian
I just find it odd that you want people to implement things for you that have already been implemented. You don't want to use any of the good solutions already available, but for no particular reason. madVR is a very lightweight install and it is well integrated with MPC-HC, just give it a try. If you want HDR tone mapping in MPC-HC that is how to get it.
madVR options explained
Old 8th June 2019, 22:40   #585  |  Link
Nintendo Maniac 64
Quick question about the built-in youtube-dl vertical resolution setting and the following 2.37 aspect ratio video: https://www.youtube.com/watch?v=2ClvOQTke7w
When I select 1080p on the actual YouTube web page as normal, you get 1920x810 as is to be expected as YouTube's quality/resolution labels are actually a slight misnomer since YouTube decides a given quality/resolution based on the horizontal or the vertical resolution. Since fmt137 (AVC 1080p30) and/or fmt248 (VP9 1080p30) maxes out at 1920x1080, this means both 1920x810 and 1440x1080 videos would still be considered "1080p".
However, the built-in youtube-dl vertical resolution setting in MPC-HC does not seem to follow this same pattern as the actual YouTube web page.
When this MPC-HC youtube-dl setting is set to 1080p, rather than playing fmt137 or fmt248, it will actually play fmt271 (the format YouTube labels "1440p" which supports a maximum resolution of 2560x1440), because the wide aspect ratio results in a resolution of 2560x1080 whereby the vertical resolution is 1080 pixels.
So my question is very simple - is this in fact the intended behavior in MPC-HC's implementation of youtube-dl?
Win7 x64
Old 8th June 2019, 23:40   #586  |  Link
clsid
It is obviously not intended. But I am not going to add even more options. Seem to me that this wide video is a rare occurrence on YT.
Old 9th June 2019, 00:53   #587  |  Link
Nintendo Maniac 64
I never expected you to add more options, rather just perhaps tweak the current implementation so that it also takes into account the horizontal resolution behind-the-scenes when choosing a given quality.
My idea was that setting the option (1080 in our example) would have it work like it currently does where it looks at the vertical resolution, but it then also takes said value (1080 in this case) and multiplies it by 1.8 (resulting a value of 1944) to use for the horizontal resolution, and then only selects the video resolution that is equal to or smaller than the two given values.
Win7 x64
Old 14th June 2019, 19:40   #588  |  Link
empleat
Someone know if you can disable auto loading subtitles ? But not disable them completely. It is annoying to have to press 2 times s everytime video opens, while it is lagged yet.
empleat is offline   Reply With Quote
Old 17th June 2019, 03:27   #589  |  Link
shae
The stuff under Options\Subtitles\Misc might do what you want.
shae is offline   Reply With Quote
Old 17th June 2019, 06:49   #590  |  Link
empleat
Strange i disable prefer forced and external checkbox and subtitles still loading by default. So annoying...
Old 17th June 2019, 09:34   #591  |  Link
sneaker_ger
Try:
During playback click "Play"->"Filters"->"LAV Splitter"->"Properties". Set "Subtitle Selection Mode" to "No Subtitles".
Old 17th June 2019, 12:22   #592  |  Link
clsid
You can also toggle subtitles on/off with W.
Old 17th June 2019, 13:38   #593  |  Link
sneaker_ger
This is really one of the weaknesses of MPC-HC. The several options influencing this clattered throughout the GUI. LAV isn't integrated well, i.e. you have MPC-HC priority for audio/subtitle and a separate one for LAV.
Old 17th June 2019, 17:02   #594  |  Link
chros
chros's Avatar
Well, maybe it's true, but the same applies to every other DS player that can utilise LAV
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz)
Old 17th June 2019, 17:59   #595  |  Link
Klaus1189
Try:
I use MPC-BE and LAV Filters, sneaker_ger is right and I disable this one as well:
https://drive.google.com/file/d/1CJs...ew?usp=sharing
Old 20th June 2019, 05:25   #596  |  Link
empleat
Try:
This fixed it for me, thank you so much !
Old 24th June 2019, 16:17   #597  |  Link
pfff74
Hello people. I hope if I'm posting in the right thread, I apologize if I am not.
I'm trying to get "compact" view on MPC-HC when playing audio files. I have two versions of MPC-HC: 1.7.13 (2017) and 1.7.0 (2013). On the older version when playing an audio file, the OSD becomes "compact" but in the newer version playing an audio file would still display the MPC-HC logo screen like a video. I tried searching in settings or the View but did not find anything to enable compact OSD on the newer build. Anyone know how to?
This is a screenshot showing the newer version (top) and older version (bottom) https://imgur.com/a/LghTz2T
pfff74 is offline   Reply With Quote
Old 24th June 2019, 18:39   #598  |  Link
Klaus1189
I just downloaded MPC-HC 1.8.6 x64 to check for you. Advanced settings (last page) and set CoverArtSizeLimit to 0. But if you have any file(s) with CoverArt, this is disabled by this setting. This is also the difference between your two versions. CoverArt support was added. Be sure to check latest MPC-HC 1.8.6 with additional features and bugfixes and worth a try to check MPC-BE as well (my favourite videoplayer).
For audio files I can recommend foobar2000 (I use it also for many years), I use MPC-BE for special audio filetypes, because it is designed as videoplayer primarily, and so is MPC-HC.
Hope it helps
Old 25th June 2019, 01:17   #599  |  Link
pfff74
Hope it helps
Thank you, it worked! I love the classic compact WMP design. I think CoverArtSizeLimit should probably default to 0, but oh well.
1.8.6? I thought I was on the latest version since development stopped. EDIT: OK it seems that MPC-HC is still being updated! I wonder what it offers, as I don't usually expect much from an update of such program.
I personally use Winamp as my (library) music player, but set MPC-HC as the default Windows audio file player for playing files from Explorer. I like to keep Winamp as strictly my entire music collection. Once again, thanks!
Old 25th June 2019, 16:01   #600  |  Link
clsid
There is a changelog in the first post of this topic...
tldr; It has updated internal codecs and lots of other fixes and improvements.
