12th December 2011, 17:16 | #13781 | Link |
i have a problem... (sorry for my english)
i have a bluray that has a very little item (26mb) and the bdrebuilder crashes everytime is encoding that particular item i copy the log [04:25:03] BD Rebuilder v0.39.04 (beta) - Source: TAKE_THAT_PROGRESS_LIVE - Input BD size: 38.89 GB - Approximate total content: [02:40:29.002] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [04:25:10] PHASE ONE, Encoding - [04:25:10] Processing: VID_00000 (1 of 3) - [04:25:10] Extracting A/V streams [VID_00000] - [04:57:11] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 244,411 frames - Bitrate: 13,234 Kbs - [04:57:13] Reencoding: VID_00000, Pass 1 of 1 - [08:45:32] Video Encode complete - [08:45:32] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (eng): Keeping original audio - [08:45:32] Multiplexing M2TS - [08:59:38] Processing: VID_00001 (2 of 3) - [08:59:38] Extracting A/V streams [VID_00001] - [09:02:41] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1280x720 - Rate/Length: 59.940fps, 83,761 frames - Bitrate: 13,035 Kbs - [09:02:41] Reencoding: VID_00001, Pass 1 of 1 - [09:26:46] Video Encode complete - [09:26:46] Processing audio tracks - Track 4352 (eng): Keeping original audio - [09:26:46] Multiplexing M2TS - [09:28:48] Processing: VID_00007 (3 of 3) - [09:28:48] Extracting A/V streams [VID_00007] - [09:28:54] Reencoding video [VID_00007] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 60 frames - Bitrate: -7,968 Kbs - [09:28:55] Reencoding: VID_00007, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.39.04 (beta) - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.11.96.14, Ok - FFDSHOW: 3882, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [10:46:51] - Failed video encode, aborted |
12th December 2011, 21:46 | #13783 | Link | |
14th December 2011, 00:35 | #13784 | Link |
Trying to rebuild The Smurfs using v39.04, but I am getting the following errors after selecting the source:
Error Condition BD Rebuilder experienced an error 2501 SourceCheck() 00009 2501 followed by: Illrgal Source Selected source is not BD fomat 100 plus rebuilds without any errors until now. Could be a bad backup, but video files play on my computer just fine. |
14th December 2011, 01:06 | #13785 | Link |
did you swap a mounted iso / change the source when it was scanning the directories? That's an error i've seen personally and only happened when i accidentaly swapped mounted iso's when it was already scanning the first mounted one, or when i aborted the source selection
14th December 2011, 02:36 | #13786 | Link | |
14th December 2011, 02:37 | #13787 | Link | |
14th December 2011, 15:53 | #13789 | Link |
BD Rebuilder v0.39.05 (beta)
I have updated the links in the first post of this thread to a new version of BD Rebuilder (v0.39.05). Changes for this release:
- Added code to check and correct for leading M2TS file audio weirdness when building to movie-only from a multipart source. - Added a hidden option "BEEP_SOUNDFILE". This item can be set to the path of an alternate .WAV file to be used as the "Job Completion" beep. See HIDDENOPTS.TXT. - Corrected an error in which the "keeping audio" messages are incorrectly printed for all streams when "KEEP_HD_AUDIO". The audio was processed correctly -- but was incorrectly reported in the status log. - Corrected an issue in which some AVS settings may be set incorrectly when processing a non-480i source when the hidden flag "IVTC_480i" is set. - Added new code to better prioritize playlists in determination of main feature. - Modified menu identification routines with the intent of improving accuracy. - Added code to check vbv-bufsize when vbv-maxrate has been modified (due large audio inclusion) and ensure the 1 sec buffer limit is always enforced. - Corrected problems with filter prefixes that could cause incorrect application. - Added a new filter prefix. An "s:" prefix tells BD Rebuilder to include this filter for secondary video. Note: When used the "s:" should be the first prefix listed. - Added inclusion of chapters ALTERNATE/MKV file output. Chaptering can be disabled by using the new hidden option "MKV_CHAPTERS=0" (see HIDDENOPTS) - Modified ALTERNATE rebuilding routines to save time when using single source (non-mulipart) sources by not performing the "PT 1" multiplexing. - Updated the included version of X264.EXE to the latest release (r2120). - Updated the included version of X264-64.EXE to the latest release (r2120). - Other minor corrections and cosmetic fixes. |
14th December 2011, 17:05 | #13790 | Link |
39.0.5 Inspect
JDobbs...
Just downloaded and installed latest beta and, as usual, I ran Inspect just to make sure all is well. To my surprise it got: - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.11.96.14, Ok - FFDSHOW: 3882, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.39.0.5, Ok - X264: Wrong version found - AFTEN: Wrong version found - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok Any ideas? I keep a few old versions and went back and tested the Inspect on them and no reported problems. I did notice that this beta does have different versions of those two apps. |
14th December 2011, 17:13 | #13791 | Link | |
I'll update INSPECT.EXE and repost. |
14th December 2011, 23:03 | #13792 | Link |
Whooptiedoo, custom notification sounds. All i need now is a third "output folder" browse button and i'll be a very happy camper But care to elaborate the use? is it relative to the BDRB folder or to the C:\ root drive?
14th December 2011, 23:06 | #13793 | Link | |
The "Whooptiedoo" comment is not appreciated. I spend a lot of time on this software with no return on that labor investment. Smart-ass comments just make me rethink whether it is worth it. Last edited by jdobbs; 14th December 2011 at 23:12. |
14th December 2011, 23:17 | #13794 | Link |
My apologies, it's worth it for me. Now i won't have to walk back and forth all the time to see if the job is finished or not? But care to explain how it works?
is the path relative to BDRB like would BEEP_SOUNDFILE=success.wav work, if success.wav was included in the rootfile, does it work with path's like BEEP_SOUNDFILE=..\imgburn\sounds\success.wav or does it need the whole path? Oh and i'll try to make an effort and make some kind of donation to ya, with the newyears bonus coming up . I've been using this amazing app for a while now, it's more then worth it. |
14th December 2011, 23:34 | #13796 | Link | |
14th December 2011, 23:38 | #13797 | Link |
So BEEP_SOUNDFILE=succes.wav would not work? (technically it is a full path) i would move the file in the BDRB root folder or would it be best to use BEEP_SOUNDFILE=C:\Program Files (x86)\BD_Rebuilder\Success.wav ? (succes.wav i use is the IMGBurn one, maybe offer the choice to users to use that one if IMGBurn is installed. Kinda similar to BDRB being able to send commands to IMGburn )
15th December 2011, 05:59 | #13799 | Link | |
You don't give a lot of information for me to work with. No title, no logs, no settings, no useful information. I guess I could try to read tea leaves to figure out your problem -- but I don't have any. Last edited by jdobbs; 15th December 2011 at 06:01. |
15th December 2011, 06:20 | #13800 | Link |
I said "famous" because I've seen it in the forum other times but I didn't want to offend you.
There´s no much information to say, I mean just download the zip file and uncompress into a folder but when I run BDRB.exe I get the error. I can't even start the program, no logs, no settings and when I run Inspect everything is ok. As I said It doesnt happens with any other version, just with this new one. I'll still using the 0.39.04. English is not my native language so excuse if there's any misunderstanding. |
